iPad , iPod , Apple TV iPad 1 , iPad 2 , iPad 3 , iPad Mini , iPad 4 / iPod Classic , iPod Nano , iPod Touch / Apple TV |
02-13-2021, 00:12 | #1 (permalink) |
Crazy Poster Join Date: Nov 2015 Location: USA Chicago
Member: 2485239 Status: Offline Thanks Meter: 11 | a1538 SN CHANGE NOT ACTIVATE i bought a sn with wifi and bluetooth for the above mentioned ipad. It is using the a8 chip. I used irepair p10 to write the 3. Everything is ok until i have to activate. Then it fails to activate. I have tried 3 different combos and 3 other ipads. Yesterday i did a a1701 and no problems. Anyone can help? Am willing to pay to learn what im doing wrong. |
02-22-2021, 10:49 | #4 (permalink) |
Member: 2485239 Status: Offline Thanks Meter: 11 | I am using another iPad data. The information matches because I use it on another A8 device and it activated with out a problem. It seems as though it’s only affecting the mini 4. Also if I write back the original data it will work because it asks for the iCloud. Text me on WhatsApp 17736562196 |
02-22-2021, 10:49 | #5 (permalink) |
02-22-2021, 11:43 | #6 (permalink) | |
Freak Poster Join Date: Jan 2010 Location: türkiye
Member: 1207296 Status: Offline Sonork: 100.1609587 Thanks Meter: 74 | Quote:
after jailbreak bypass | |
03-07-2021, 22:57 | #8 (permalink) |
No Life Poster Join Date: Jul 2005 Location: sarcelles Age: 47
Member: 161061 Status: Offline Thanks Meter: 568 | because your ipad is cellular you need to remove transistor it will be activate after just see in youtube how to remove transistor beware but your ipad will be wifi only he will not able to read sim |
03-12-2021, 15:59 | #9 (permalink) | |
Junior Member Join Date: Aug 2016
Member: 2613325 Status: Offline Thanks Meter: 3 | Quote:
The problem is that all of the devices with iOS 14.4 cannot be activated after SN change, regardless if it's WiFi or cellular. BTW, anyone come across a solution for this yet? | |
03-13-2021, 12:04 | #12 (permalink) |
No Life Poster Join Date: Jun 2002 Location: Portugal.Chelas Age: 39
Member: 12966 Status: Offline Thanks Meter: 133 | Tested all ipad except ipad 3 and 4 none activate i copy my own ipad mini 3 4 and ipad 10.5 clean serial write on them and still fail to activate |
The Following User Says Thank You to ChelasGsm For This Useful Post: |
03-15-2021, 15:18 | #14 (permalink) | |
No solution yet for A8 and newer. | |
