12-08-2015, 11:26 | #1 (permalink) |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | GUIDE: Direct mode (S-OFF/IMEI/etc) phones with download mode (A9/M9/626/etc) Here is an information about how to work with new phones which have "Download mode". 1. What is a "Download mode"? Download mode is a new service mode introduced since HTC M9. You can flash and service your phone in this mode. 2. How do I get into this mode? 2 ways: a) While phone is powered OFF, hold VOLUME DOWN and POWER. b) Connect your phone to PC. Run XTC 2 Tool and press "Download" button in mode selection. How do I use XTC 2 Clip with these phones? First, you must connect your XTC 2 Clip to the phone, a connection example can be found here: http://forum.gsmhosting.com/vbb/f961...ample-1967566/ NOTE! Clip must be connected BEFORE phone is powered ON. If the clip was connected AFTER, then you need to reboot download mode. M9 in download mode, "SD NOT MOUNTED" = No SD card / XTC 2 Clip connected M9 in download mode, "GT_CONNECT_FAIL" = XTC 2 Clip connected, but probably you need to repair it M9 in download mode, no error = XTC 2 Clip connected and everything is ready for operation. You will also see additional options (Factory reset and Check smart SD (note - if the phone is S-OFF you'll see these options even without the clip) Now, when everything is ready - you can run XTC 2 Tool and open "Direct mode commands" tab: You can use the buttons from highlighted area (IMEI1/IMEI2/CID/MEID/S-OFF) Possible errors: NOT_FIND_SMART_IO - Your clip is not attached. VERIFY_GET_PATERN_FAIL - Make sure your clip is upgraded and activated. You can also try to repair clip. DECREASE_CYCLE_FAIL - Please contact us via PM or on skype: xtc2clip SIM UNLOCK Unfortunately you cannot unlock phones from direct mode. To remove sim lock, please use "Sprint" tab for Sprint phones and "Special unlock" tab for all other phones. This guide will be updated! Last edited by xtc2clip; 12-08-2015 at 16:19. |
The Following 16 Users Say Thank You to xtc2clip For This Useful Post: |
12-18-2015, 17:49 | #2 (permalink) |
No Life Poster Join Date: May 2002 Location: TX Age: 49
Member: 12427 Status: Offline Thanks Meter: 78 | Could you add some info about error SELECT_APPLET_FAIL? At first i got GT_CONNECT_FAIL, after repaired, now i get error "SELECT_APPLET_FAIL" (I inserted SD in phone then press download in tool) |
The Following User Says Thank You to abcchoier For This Useful Post: |
02-24-2016, 03:03 | #4 (permalink) |
Junior Member Join Date: Oct 2015
Member: 2468157 Status: Offline Thanks Meter: 6 | Hi, Sending oem clearsimlocktype ... (bootloader) [ERR] Command error !!! Execution time is 0(ms) OKAY Operation finished Always appear this error, help |
The Following User Says Thank You to norato001 For This Useful Post: |
