09-18-2016, 14:49 | #32 (permalink) |
Freak Poster Join Date: Jun 2015 Location: Ramkon
Member: 2414762 Status: Offline Thanks Meter: 47 | Hi i have M8 Sprint and i am in Iran, i use XTC2Clip to SimUnlock and it Done but when i want to use 4G my signal is gone and i can only use 2G what can i do to use 4G ? |
09-19-2016, 19:23 | #33 (permalink) |
Freak Poster Join Date: Jan 2013 Location: socal
Member: 1866487 Status: Offline Thanks Meter: 113 | Still waiting for a response. Sprint HTC A9 originally converted to Euro everything ok. Now trying to reverse back to sprint the same phone and no matter what it bootloops. Ive changed the MID CID back to sprint manually and also using XTC Clip, ive flashed sprint roms via TWRP, ive formatted partitions...in FTM XTC clip always says euro to sprint conversion done with 2 errors. |
09-20-2016, 20:24 | #34 (permalink) | |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Quote:
I will assist you. | |
The Following User Says Thank You to xtc2clip For This Useful Post: |
09-21-2016, 15:52 | #35 (permalink) |
Junior Member Join Date: Sep 2016
Member: 2620840 Status: Offline Thanks Meter: 6 | Hello I am new on this forum and I had the same issue with my A9: converted to EU and then back to Sprint, it had some problems with radio malfunctioning, had no signal and no data. The user xtc2clip did the magic and now it's up again. So I want to say many thanks!! so guys, no worries - your devices will be alive with help of this magician Thanks again |
The Following User Says Thank You to bandura For This Useful Post: |
09-27-2016, 18:14 | #36 (permalink) |
Member: 1866487 Status: Offline Thanks Meter: 113 | XTC Clip Thank you so much for getting this fixed for me. anyone have issues fear not XTC Clip2 is the best. they WILL help you just be patient. thanks again XTC |
09-29-2016, 19:09 | #41 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Roumania
Member: 691388 Status: Offline Thanks Meter: 371 | Unlock HTC A9 European version. [IMG]фотохостинг бесплатный[/IMG] The same error with S-OFF and SuperCID. I did unlocked my phone using version 1.15 witch is the first to support A9 unlock. |
12-28-2016, 19:37 | #43 (permalink) |
Junior Member Join Date: Feb 2015
Member: 2346185 Status: Offline Thanks Meter: 4 | how do i s-off and supercid htc a9 ? i made a clip drive with 2 files cid and s-off but no matter what i do they do nothing in download mode in bootloader mode in ftm mode ... but special unlock works |
12-28-2016, 20:35 | #44 (permalink) |
Member: 2346185 Status: Offline Thanks Meter: 4 | UPD* I did S-OFF and SuperCID my Sprint HTC A9 I was using Tool version 1.29 i used special Unloack tab to generate files for A9 Sprint "Convert Sprint A9 to European A9" connected everything and rebooted to FTM phone did its job but finished with 01000000 ERROR now the phone boots up and blank screen i can get it to download mode, bootloader mode when i boot to ftm it just shows me a lock so i cant flash it now back to Sprint via FTM and clip clip now shows the device to be htc_hiaewhl what can i do to unbrick my device now ? can you help me somehow ? the phone isnt mine and i followed instructions exactly ... so what to do ? |
12-29-2016, 10:45 | #45 (permalink) |
Member: 2346185 Status: Offline Thanks Meter: 4 | UPD ** The phone still gets charge - shows percentage Phone boots to download mode but SD NOT MOUNTED (even with clip inserted in phone) Phone reboots to bootloader from download mode Phone boots to recovery mode from bootloader mode Phone boots to RUU mode using clip&PC Phone CAN NOT boot to FTM (shows a locked lock that looks like s-off lock) Phone CAN NOT boot to OS i dont know what to do ... maybe i should try to flash a RUU or zip as now it thinks it's a htc_hiaewhl .. i should try its RUU or what ? ... hel me out please i triple checked and did everything by the book as the instructions told |
