Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > xtc2cliP
Old 09-13-2016, 21:16   #31 (permalink)
dam1inc's Avatar
Member: 1866487
Thanks Meter: 113
Originally Posted by xtc2clip View Post
dam1inc has exceeded their stored private messages quota and cannot accept further messages until they clear some space.
I will contact you on Skype then.
sorry, i've cleared my Inbox for PM
skype: Dam1inc.
Old 09-18-2016, 14:49   #32 (permalink)
Member: 2414762
Thanks Meter: 47
Hi i have M8 Sprint and i am in Iran, i use XTC2Clip to SimUnlock and it Done but when i want to use 4G my signal is gone and i can only use 2G what can i do to use 4G ?
Old 09-19-2016, 19:23   #33 (permalink)
dam1inc's Avatar
Member: 1866487
Thanks Meter: 113
Still waiting for a response. Sprint HTC A9 originally converted to Euro everything ok. Now trying to reverse back to sprint the same phone and no matter what it bootloops. Ive changed the MID CID back to sprint manually and also using XTC Clip, ive flashed sprint roms via TWRP, ive formatted partitions...in FTM XTC clip always says euro to sprint conversion done with 2 errors.
Old 09-20-2016, 20:24   #34 (permalink)
Member: 2416253
Thanks Meter: 4,162
Please contact me on skype xtc2clip
I will assist you.
The Following User Says Thank You to xtc2clip For This Useful Post:
Old 09-21-2016, 15:52   #35 (permalink)
Member: 2620840
Thanks Meter: 6
Hello I am new on this forum and I had the same issue with my A9: converted to EU and then back to Sprint, it had some problems with radio malfunctioning, had no signal and no data. The user xtc2clip did the magic and now it's up again. So I want to say many thanks!! so guys, no worries - your devices will be alive with help of this magician Thanks again
The Following User Says Thank You to bandura For This Useful Post:
Old 09-27-2016, 18:14   #36 (permalink)
dam1inc's Avatar
Member: 1866487
Thanks Meter: 113
XTC Clip Thank you so much for getting this fixed for me. anyone have issues fear not XTC Clip2 is the best. they WILL help you just be patient. thanks again XTC
Old 09-28-2016, 08:44   #37 (permalink)
Member: 2424855
Thanks Meter: 17
For Your Information:
It's seems I have to manually change some parameters after ran FTM (with flex inserted) and successfully converted to EU variant.
Old 09-28-2016, 20:57   #38 (permalink)
maremestera's Avatar
Member: 691388
Thanks Meter: 371
Pls post solution for 01000000 error or fix your software
Old 09-29-2016, 18:30   #39 (permalink)
Member: 2416253
Thanks Meter: 4,162
Which parameters do you mean?
Old 09-29-2016, 18:31   #40 (permalink)
Member: 2416253
Thanks Meter: 4,162
On which operation do you get this error?
Old 09-29-2016, 19:09   #41 (permalink)
Member: 691388
Thanks Meter: 371
Unlock HTC A9 European version.
[IMG]фотохостинг бесплатный[/IMG]
The same error with S-OFF and SuperCID.
I did unlocked my phone using version 1.15 witch is the first to support A9 unlock.
Old 09-30-2016, 19:22   #42 (permalink)
Member: 2416253
Thanks Meter: 4,162
Hello,
Please use 1.26, thank you.
Old 12-28-2016, 19:37   #43 (permalink)
Member: 2346185
Thanks Meter: 4
how do i s-off and supercid htc a9 ?
i made a clip drive with 2 files cid and s-off but no matter what i do they do nothing in download mode in bootloader mode in ftm mode ... but special unlock works
Old 12-28-2016, 20:35   #44 (permalink)
Member: 2346185
Thanks Meter: 4
UPD* I did S-OFF and SuperCID my Sprint HTC A9
I was using Tool version 1.29
i used special Unloack tab to generate files for A9 Sprint "Convert Sprint A9 to European A9"
connected everything and rebooted to FTM
phone did its job but finished with 01000000 ERROR
now the phone boots up and blank screen
i can get it to download mode, bootloader mode
when i boot to ftm it just shows me a lock
so i cant flash it now back to Sprint via FTM and clip
clip now shows the device to be htc_hiaewhl
what can i do to unbrick my device now ? can you help me somehow ? the phone isnt mine and i followed instructions exactly ... so what to do ?
Old 12-29-2016, 10:45   #45 (permalink)
Member: 2346185
Thanks Meter: 4
UPD **
The phone still gets charge - shows percentage
Phone boots to download mode but SD NOT MOUNTED (even with clip inserted in phone)
Phone reboots to bootloader from download mode
Phone boots to recovery mode from bootloader mode
Phone boots to RUU mode using clip&PC
Phone CAN NOT boot to FTM (shows a locked lock that looks like s-off lock)
Phone CAN NOT boot to OS
i dont know what to do ...
maybe i should try to flash a RUU or zip
as now it thinks it's a htc_hiaewhl .. i should try its RUU or what ? ... hel me out please
i triple checked and did everything by the book as the instructions told
Page generated in 0.26209 seconds with 8 queries
