DC-UNLOCKER DETECTED MONITORING SOFTWARE Pleasee uninstall all monitoring software Further monitoring software using may damage your dongle modem phone and you will be bloked by server Plese help my ID 01322CCF |
Block now removed. If you do not know what service/software on your machine causes this then can only suggest to use dc-unlocker from another pc. Note: receiving multiple blocks for same reason may end up with a permanent block. |
Access denied (for using protocol monitoring software) my dongle ID: 0000B695 Can You help again please? Is it blocked just now? I have not used any USB sharing etc, I have checked now running services, and only suspicious I can see: ModemListener.exe which really not sure yet which app is causing it. I was in process of unlock Huawei E585, not sure how to unlock it as when connected by usb, it takes over my network card, in result I'm connected to WiFi but OFFLINE, as my Windows7 is trying to connect to websites via connected Huawei E585 in result I cannot unlock it anyway as "error server" in DC-Unlocked, no connection to server after few seconds... |
This is a second time you getting blocked for same reason. Your computer runs usb activity scanning/sharing service, therefore you got blocked. You must remove such service/software from computer before using DC-unlocker otherwise you will get blocked again. Block now removed. If you do not know what service/software on your machine causes this then can only suggest to use dc-unlocker from another pc. Note: receiving multiple blocks for same reason may end up with a permanent block. |
Thank You so much for quick response. I won't use it again on same machine to be on safe side Thank You |
help dc_unlocker SN/:20069517 Access denied (for using protocol monitoring software) |
help dc_unlocker sn/00040539 Access denied (for using protocol monitoring software) |
Help dc_unlocker My ID 01322CCF Access denied (for using protocol monitoring software) |
