Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > DC Unlocker
Old 10-17-2017, 15:50   #16 (permalink)
Member: 1916900
Sonork: .::NIGAM::.
Thanks Meter: 81
Originally Posted by haydernaz View Post
how to repair imei
Found Applications port COM110
Found modem : E5573Cs-609
Model : Huawei AuthVer 4 modem (New)
IMEI : 000000000000000
Serial NR. : 5LL7S17401002140
Firmware : 21.318.03.00.778
Compile date / time : Jun 12 2016 15:33:53
Hardware ver. : CL1E5573CSM Ver.B
Dashboard version : WEBUI_17.100.08.01.983
Web UI version : WEBUI_17.100.08.01.983_MRE5
SIM Lock status : unlocked
Wrong codes entered : 0 (unlock attempts left : 10)
We do not have imei repair for it.
Originally Posted by nduka View Post
Does this unlock needs test point
What about imei calculation
Need answer from supporter
No it does not need it, can not calculate anything for them.
how to solve bro E5573s-606 error
Originally Posted by CONCORDIA GSM View Post
whats wrong with this modem i tried on many. same failed
DC - Unlocker 2 Client 1.00.1390
Detecting modem :
selection :
manufacturer - Huawei modems
model - Huawei AuthVer 4 modem (New)
Selected Applications port COM91
Selected Diagnostics port COM22
Found modem : E8372
IMEI : 866280027577338
Serial NR. : R7EDU17807004765
Firmware : 21.327.62.00.1460
Dashboard version : WEBUI_17.100.18.01.1460_RE5
Web UI version : WEBUI_17.100.18.01.1460_RE5
SIM Lock status : Locked (Card Lock)
Unlocking, please wait ...
Failed read NVitem
Error code 75
unlock failed !
Detecting modem :
selection :
model - Auto detect (recommended)
Found Applications port COM91
Found modem : E8372
IMEI : 866280027577551
Serial NR. : R7EDU17807004787
Error code 376
unlock failed !
Provide username or dongle id.
Detecting modem :
selection :
Found Applications port COM130
Found modem : E5577s-321
IMEI : 860782035404344
Serial NR. : F5DDU17706007469
Firmware : 21.326.62.00.429
Dashboard version : WEBUI_17.100.18.01.429_MRE5
Web UI version : WEBUI_17.100.18.01.429_MRE5
Warning! IMEI Log fail!
AT command error
Error code 37
unlock failed !
AT command error
Error code 37
unlock failed !
Yours is customized from what it looks like.
Detecting modem :
selection :
Found modem : E5577s-932
IMEI : 866852025598548
Serial NR. : X8BDW16B01004570
Firmware : 21.318.03.00.1367
Dashboard version : WEBUI_17.100.15.04.1367_MRE5
Web UI version : WEBUI_17.100.15.04.1367_MRE5
AT command error
Error code 37
unlock failed !
Only not customized modems supported.
error 37 how to slove it
Check update info, only not customized modems available for unlock
Originally Posted by .:Towhid:. View Post
Can I Unlock This Model?
IMEI : 866852022455593
Serial NR. : X8BDU15B11005050
Firmware : 21.200.09.00.76
Dashboard version : WEBUI_17.100.09.01.76_MRE5
Web UI version : WEBUI_17.100.09.01.76_MRE5
No, STC one is not available for unlock.
Old 10-17-2017, 15:57   #17 (permalink)
mubarak2344's Avatar
Member: 2001848
Sonork: 100.1658212
Thanks Meter: 581
DRIVER ISSUE.....
Install huawei mobile connect drivers....
Old 10-17-2017, 16:00   #18 (permalink)
Member: 255472
Thanks Meter: 5
Found Applications port COM330
IMEI : 866852020709165
Serial NR. : X8BBY15601001518
Wrong codes entered : 10 (unlock attempts left : 0)
Waiting modem/phone to be ready ...
Modem successfully unlocked !
Credits left : 0
still locked modem and crd gone?????
pls refound crd or unlock my modem
Old 10-17-2017, 16:00   #19 (permalink)
Member: 1916900
Sonork: .::NIGAM::.
Thanks Meter: 81
Originally Posted by mubarak2344 View Post
DRIVER ISSUE.....
give driver link bro i am tired of installing driver but not done still yellow in device manager
Old 10-17-2017, 16:04   #20 (permalink)
Member: 2023196
Thanks Meter: 1,892
DRIVER ISSUE.....
All available drivers that we have are on our support area.
Credits left : 0
Credit added back, please read update info, only not customized modems supported for unlock.
Old 10-17-2017, 16:09   #21 (permalink)
Member: 2001848
Sonork: 100.1658212
Thanks Meter: 581
http://www.driverscape.com/files/mis....8.10.2606.exe
OR
http://unlockclub.ru/downloads/FcSerialDrv.rar
If u use 64bit os then make disable driver signature enforcement.
The Following User Says Thank You to mubarak2344 For This Useful Post:
Old 10-17-2017, 16:15   #22 (permalink)
Member: 1916900
Sonork: .::NIGAM::.
Thanks Meter: 81
sir which driver i have to install from support i cant see E5573s driver there look pls help me for unlock this dongle
Old 10-17-2017, 16:24   #23 (permalink)
Member: 2001848
Sonork: 100.1658212
Thanks Meter: 581
use this driver
100% ok tested...
if u use 64 bit pls make disable driver signature enforcement
The Following 2 Users Say Thank You to mubarak2344 For This Useful Post:
Old 10-17-2017, 16:35   #24 (permalink)
Member: 330490
Sonork: 100.1596361
Thanks Meter: 40
not work with me
Found Applications port COM779
Found modem : E5577Cs-321
IMEI : 864695030363818
Serial NR. : D2LDW17311003759
Firmware : 21.316.01.00.1029
Dashboard version : WEBUI_17.100.13.02.1029_MRE5
Web UI version : WEBUI_17.100.13.02.1029_MRE5
Wrong codes entered : 4 (unlock attempts left : 6)
AT command error
Error code 37
unlock failed !
Old 10-17-2017, 16:55   #25 (permalink)
Member: 2023196
Thanks Meter: 1,892
Can try driver packs from same type devices.
Originally Posted by nser5 View Post
not work with me
AT command error
Error code 37
unlock failed !
Yes, only not customized modem version available at the moment for direct unlock.
Old 10-17-2017, 17:20   #26 (permalink)
Member: 1741973
Thanks Meter: 115
Need unlock huawei e5330cs-82 ,zte mf65m,65+ modem
Old 10-17-2017, 17:28   #27 (permalink)
Member: 86802
Thanks Meter: 457
Unlocked one more E5577Cs-321
Thanks to DC team
Old 10-17-2017, 19:47   #28 (permalink)
nduka's Avatar
Member: 1943439
Sonork: 100.1669578
Thanks Meter: 214
How to know customized modems
thanks
Old 10-17-2017, 20:02   #29 (permalink)
dan0007's Avatar
Member: 38050
Thanks Meter: 61
E5578 unlock fail
Detecting modem :
selection :
Selected Applications port COM704
Found modem : E5578s-932
IMEI : 866166020766384
Serial NR. : M3Y7N16607003326
Firmware : 21.316.01.00.334
Dashboard version : WEBUI_17.100.14.00.334_MRE5
Web UI version : WEBUI_17.100.14.00.334_MRE5
AT command error
Error code 37
unlock failed !
Old 10-18-2017, 05:38   #30 (permalink)
klmamn's Avatar
Member: 986273
Thanks Meter: 397
thanks
good question in fact i have too
The Following 3 Users Say Thank You to klmamn For This Useful Post:
Page generated in 0.30838 seconds with 9 queries
