Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > DC Unlocker
Old 03-23-2021, 09:06   #16 (permalink)
Member: 2023196
Thanks Meter: 1,891
Originally Posted by abdoulgaf View Post
HI DC team still have freeze issu when read phone info in manufacture mode in this new version too. only hcu_362 worked well
Disable line(s) under "Android phone" then do detection in manufacture mode.
Old 03-23-2021, 23:54   #17 (permalink)
Member: 1813429
Thanks Meter: 11
please sir do a sreenshot of what your talking about
Old 03-24-2021, 13:42   #18 (permalink)
Member: 2023196
Thanks Meter: 1,891
Add screenshot of device manager with phone connected in manufacture mode and i will point out what needs to be disabled.
Old 03-24-2021, 14:12   #19 (permalink)
Member: 1813429
Thanks Meter: 11
i finally figured out what to do. and now it worked thanks. now i have another question. possible to active dual-sim function with this new version on recent huawei phone like mate 20 pro and p30 lite?
Old 03-24-2021, 14:15   #20 (permalink)
Member: 2023196
Thanks Meter: 1,891
No, it is not https://hcu-client.com/hcu-features-by-tp-xloader/
Old 04-02-2021, 16:52   #21 (permalink)
Member: 2793383
Thanks Meter: 56
Hello Hcu team Please Add latest MTK Cpu imei repair tab with test point methods
Old 04-26-2021, 10:50   #22 (permalink)
Member: 2906470
Thanks Meter: 22
Gives a successful message, but a network lock code is required after the device is turned on.
pot-lx1af
Old 04-26-2021, 16:29   #23 (permalink)
Member: 2023196
Thanks Meter: 1,891
pot-lx1af
Could you add a screenshot/picture of it please. Can send via PM if you do not want to post it in public.
The Following User Says Thank You to Namelocked For This Useful Post:
Old 04-27-2021, 10:19   #24 (permalink)
Member: 2906470
Thanks Meter: 22
I tried different software.
POT-L21AF_9.0.1.165(C185E8R1P11)
POT-L21AF_10.0.0.241(C185E3R4P1)
Potter-L21AF 9.1.0.263(C185E8R4P1)
Old 04-27-2021, 15:44   #25 (permalink)
Member: 2023196
Thanks Meter: 1,891
Your IMEI on mobile shows zeroes, have you repaired it? What do you see with *#06# two imeis or one? Your phone is set to double sim, and the problem may be related to firmware if it does not show double IMEI and from that may be network lock problem as well. You sure it is L21AF or you have rebranded it?
Old 04-27-2021, 17:53   #26 (permalink)
Member: 2906470
Thanks Meter: 22
An Imei is displayed on the phone, which is 0000.
These files are correct, they contain the Preloader and Cust files, the flash file is burned properly, either with Dc Phoenix or with a memory card, when I get the information with hcu in Testpoint mode imei and model and other information is correct
Phone Model Is Pot-lx1af
I backed up the Oeminfo partition and burned it again later.
Do you know another firmware?
Can You Help Me For Write Bordsofware(how To Do)
Old 04-28-2021, 16:15   #27 (permalink)
Member: 2023196
Thanks Meter: 1,891
Don't flash any board software into it. Please write your username/dongle id.
Old 04-29-2021, 08:07   #28 (permalink)
Member: 2906470
Thanks Meter: 22
my dongle id is:
039B902479
Old 04-29-2021, 13:16   #29 (permalink)
Member: 2023196
Thanks Meter: 1,891
my dongle id is:
039B902479
Please do this:
1. Restart HCU software.
2. Login with your account on software.
3. Right click on memo area make sure "enable debug logging" has a check mark.
4. Detect your device. Try to network/sim unlock, after attempt do rest of the steps
5. Right click on memo area and save "debug log file".
6. Send that file to me, please.
Old 04-30-2021, 09:36   #30 (permalink)
Member: 2906470
Thanks Meter: 22
Please do this:
i cant insert link here,i sent file link to your inbox
The Following User Says Thank You to ghayoum1 For This Useful Post:
Page generated in 0.23248 seconds with 9 queries
