Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | ★ Wholesale Unlock ★ | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #107 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2017 Location: on google.com
Member: 2771307 Status: Online Thanks Meter: 744 | After load and temporary unlock bootloader phone should turn on in fastboot mode. You do all like is in instruction that advice you product supporter? https://www.dc-unlocker.com/dcphoeni...ock-bootloader |
The Following User Says Thank You to IMEI_info For This Useful Post: |
![]() | #108 (permalink) | |
Crazy Poster ![]() ![]() ![]() Join Date: Mar 2020 Location: africa
Member: 2949792 Status: Offline Thanks Meter: 5 | Quote:
- Then temporary unlock bootloader - Device reboots to Fastboot mode after bootloader unlock - I load firmware files and click Update in Fastboot mode - Program writes Rescue recovery partition to phone in Fastboot mode - The program is then supposed to reboot the phone into UPGRADE MODE to write the full firmware - Phone does not go into UPGRADE MODE even with key press Phone is dead | |
![]() | #109 (permalink) | |
Product Supporter ![]() ![]() ![]() Join Date: Sep 2013
Member: 2023196 Status: Offline Thanks Meter: 1,889 | Quote:
![]() | #113 (permalink) | |
![]() FLASH ERROR ![]() Will flashing board firmware help? If yes, which file? | |
![]() | #115 (permalink) |
Junior Member Join Date: Aug 2011
Member: 1631840 Status: Offline Sonork: fredy Thanks Meter: 0 | Before operation turn phone to TestPoint mode: Turn off phone, then short TestPoint on phone pcb and plug USB cable Wait for device "HUAWEI USB COM 1.0" in Ports Read phone info 2021-02-04 00:39:58.775 Selected Cpu/Bootloader - Kirin970_T1_A8.0_V1 2021-02-04 00:39:58.777 Connecting to server... 2021-02-04 00:39:59.468 Connected! 2021-02-04 00:40:00.052 HUAWEI device in Test Point mode Not found! 2021-02-04 00:40:18.154 Found device in fastboot mode! 2021-02-04 00:40:18.161 Unlocking bootloader... 2021-02-04 00:40:18.164 Reading Certify data... 2021-02-04 00:40:30.227 Reading info... 2021-02-04 00:41:06.367 USB Write failed Fastboot provided info: SN: UBV7N18C24000495 2021-02-04 00:41:06.377 USB Write failed Memo log saved to C:\Users\THEWIZ~1\AppData\Local\Temp\Rar$EXb15760. 49101\Logs\20210204_004106_HCU_ReadInfo_.txt can helpe wiith this error USB WRITE FAILED |
![]() | #116 (permalink) | |
![]() | #119 (permalink) |
Junior Member Join Date: May 2010 Location: Belgium
Member: 1315316 Status: Offline Thanks Meter: 0 | Hi all, i always getting an error if i want to repair my imei ( have the original cert) and other things like serial number. Its a Mate 20 and original with demo software it was bricked and flashed new software. Now its working except the imei. What can i do? 2021-03-04 18:37:23.067 Missing signed files in secure partition! 2021-03-04 18:37:27.864 Repair Model and Vendor/Country currently not supported for this model, skipped! |
![]() | #120 (permalink) | |
Member: 2771307 Status: Online Thanks Meter: 744 | Quote:
