03-31-2020, 15:14 | #1 (permalink) |
Product Supporter Join Date: Sep 2013 Location: Lithuania, Kaunas
Member: 2023196 Status: Offline Thanks Meter: 1,892 | DC-Phoenix v132 update -Version bypass added -Improved algo for Downgrade/Upgrade -New option to not reboot after flash -New FRP bypass files in support -Now possible automatically or manually save Verlist files on server for program to auto-use them on next flash *Additional protection from possible user error In order to downgrade or change firmware it is necessary for server to know current version of your phone. There are many already uploaded version files on server. Missing versions will be added automatically while flashing phones as software has an in-built self learning mechanizm. FRP bypass and downgrade suitable firmwares has "FRP_bypass" words in file names Note: stock roms may have sub files such as customizaions and preload files that are also necessary for the process. This downgrade method should work for all Huawei Hisilicon mobiles! If downgrade is unseccessful, before flashing your phone put a check mark on "update Verlist to server on file load" box, then load to program all firmware files that are suitable for your mobile. And only then load firmware you target to downgrade to. Renewed feature table here Download here Last edited by Namelocked; 05-29-2020 at 14:51. |
The Following 46 Users Say Thank You to Namelocked For This Useful Post: |
04-01-2020, 12:57 | #3 (permalink) |
Junior Member Join Date: Dec 2017 Location: Casablanca
Member: 2794304 Status: Offline Sonork: Sonork Client Thanks Meter: 3 | HI Please support the protection of Huawei ID For phones devices that do not have files OEMINFO |
The Following User Says Thank You to ayoubzaouadi For This Useful Post: |
04-01-2020, 15:47 | #8 (permalink) |
Member: 2023196 Status: Offline Thanks Meter: 1,892 | Files available on support can check here Use rescue recovery option and bypass version check options. You may use original firmware files from manufacturer for this, do not need anything special. Last edited by Namelocked; 04-01-2020 at 15:53. |
The Following User Says Thank You to Namelocked For This Useful Post: |
04-01-2020, 16:12 | #10 (permalink) | |
No Life Poster Join Date: Jun 2006 Location: Philippines
Member: 302596 Status: Offline Thanks Meter: 784 | who is the copy cut here ? HDE dongle the same features with DC unlocker ? Quote:
The Following User Says Thank You to maxieboy For This Useful Post: |
04-01-2020, 17:09 | #14 (permalink) |
No Life Poster Join Date: Jun 2010 Age: 14
Member: 1315677 Status: Offline Thanks Meter: 1,439 | Please be more verbose If it is possible, please make a video tutorial so for example, if I need to reset the frp for p30 pro VOGUE-L29C I have to flash at once Code: VOGUE-L29C_9.1.0.185(C432E4R2P2)_9.0.0_r3_EMUI9.1.0_05015THQ_FRP_bypass.APP update_preload_VOG-L29_9.1.0.185(C432E4R2P2)_hw_eu.APP update_VOG-L29_9.1.0.185(C432E4R2P2)_hw_eu.APP "rescue recovery" and "bypass version check" ticked after that i should use safe mode method Please correct me, if I am wrong Thank you for this wonderful update |
04-01-2020, 17:33 | #15 (permalink) | |
selective member DC - Unlocker Join Date: Feb 2001 Location: Lithuania
Member: 3431 Status: Offline Thanks Meter: 12,477 | Quote:
If you will have error in verlist, you may need firmware version what is in phone select first once. Server will automatically updated with new version, and then can downgrade. | |
The Following 3 Users Say Thank You to Arve For This Useful Post: |
