Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #46 (permalink) | |
Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2016 Location: EFT Dongle
Member: 2536865 Status: Offline Sonork: 100.1584728 Thanks Meter: 19,542 | Quote:
![]() | #47 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2011 Age: 57
Member: 1564612 Status: Offline Thanks Meter: 12,285 ![]() | Quote:
Can Active FTP file server instead of purchase "easy-firmware", very chip price and for 1 years. EFT dongle allowe you of active all update of EFT Pro. And many other things that you can do only with one dongle purchased only one time. You named UNLOCKTOOL where haven't any warranty and each update Damage the previous, like Xiaomi working with MI Assistent or Sideload mode only when released update, (later not work more), go to get one eye in % of success of all XIAMI, 1%. EFT Pro work also w/o dongle, read carefully, pay Activaction, register and start to work. At the end each one is free of choice, if for you this UnlockTool, (should be MULTIBRAND), is more good of EFT Pro not buy and remain with you UnlockToll w/o one minim of Support, if have one problem, nobody, except others users help you, but for them you issue can stay Years w/o answer. Good lucky with you tool | |
The Following 2 Users Say Thank You to allumts For This Useful Post: |
![]() | #51 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2005 Age: 43
Member: 120029 Status: Offline Thanks Meter: 14 | Hello. Yesterday i did a factory reset via Diag mode SPD on tablet Vonino Magnet 50 with Unisoc t610. The software said that it all went ok but the tablet now is in bootloop. I can't find firmware anywhere. Now it says just this: Waiting for server.....OK Waiting For Device Connection.....OK USB PORT: SCI USB2Serial (COM57) Port: SCI USB2Serial (COM57) OPEN COM PORT......OK Handshake...OK Read Device Info......FAIL! Operation {Factory Reset} ID: CD8AB04102941715 Elapsed time 00:05 -- Version 4.4.3 Build 008 Can i solve my problem? |
![]() | #53 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2007 Location: pakistan Age: 40
Member: 653398 Status: Offline Sonork: 100.1619594 Thanks Meter: 642 | Realme c21y frp reset done Waiting For Device Connection... USB PORT: SPRD U2S Diag (COM6) Port: SPRD U2S Diag (COM6) Manufacturer: DriverCoding Corporation OPEN COM PORT... OK Load fdl loaders... OK Handshake FDL... OK Boot id: SPRD3 Sending FDL... OK Handshake NAND_FDL... OK Boot version: Spreadtrum Boot Block version 1.1 Sending NAND_FDL... OK Disable transcode... OK Reading Partition Table... OK Read Build Prop Info... FAIL Read Internal Storage Info... OK USERDATA: 48.81 GB USERDATA: ENCRYPTED RESET FRP... OK Reboot... OK Elapsed Time: 576 msecs |
The Following User Says Thank You to haroon454 For This Useful Post: |
![]() | #55 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2011
Member: 1484663 Status: Offline Thanks Meter: 337 | Hi, my EFT Pro soft it's not working. I download update, not working, update old EFT_Pro.exe, Not working. Soft opens, EFT Pro 4.4.3 Build 009. Them it start "UPGRADE" and on 18% it closes. What's wrong? it Never happened this before. Please Help |
![]() | #56 (permalink) | |
Not use Win7 but Win10, (win 11 i listen there's some issue with all boxs with drivers), Ceck Firewall or put Manually in Exclusion from Firewall. At the end change PC and try from other pc, issue is from you side. | |
![]() | #59 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2020 Location: Nigeria
Member: 2947987 Status: Offline Sonork: Null Thanks Meter: 45 | Anytime I close and open EFT dongle it prompt out new update after updating it if I close and open again it will prompt update again how can I stop it Sent from my CPH1727 using Tapatalk |
![]() | #60 (permalink) |
Member: 1484663 Status: Offline Thanks Meter: 337 | ![]() Well, I helped myself... The problem was the update in the Data folder that creates EFT Pro. I open the EFT Pro.exe in another PC , the tool update the Data folder OK and copy it into my work Pc. Thanks to myself! |
The Following User Says Thank You to Bscaine For This Useful Post: |
