Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GSMFABRICA Products > HYDRA TOOL
Old 08-02-2021, 16:45   #16 (permalink)
Member: 89550
Thanks Meter: 8
Originally Posted by Hydra Supporter View Post
click dongle reset
Best Regard / Hydra Team
******* Dongle Info *******
Version : Hydra Tool v 1.1
Serial : 190900002354
Initialize : OKAY
Status : Activated
Life : 0 [10-0-0-0-0]
=========== HYDRA DONGLE ALERT ===============
Error : LOCKED and NOT USABLE
TAKE NOTE
ATTEMPT TO PLAYDONGLE/SEND WRONG INITKEY
PLEASE STOP OR ELSE YOUR DONGLE WILL BE BLOCKED
same
Old 08-03-2021, 10:11   #17 (permalink)
Hydra Tool's Avatar
Member: 2857401
Thanks Meter: 6,861
Initialize : OKAY
Status : Activated
TAKE NOTE
same
Hello,
Sent you a PM, Please check your inbox.
Best Regards | Hydra Team
Old 11-18-2021, 20:44   #18 (permalink)
Member: 750902
Thanks Meter: 5
Hydra Update Manager Tool Ver 1.0.2 Build 16
Windows 10 (Version 10.0, Build 19043, 64-bit Edition)
Intel(R) Core(TM) i3 CPU M 380 @ 2.53GHz
Intel(R) HD Graphics
Ram Installed : 4 GB
Windows Access Right Admin
Software Run As Admnistrator
Official Website : http://hydra-dongle.com/
Gsmhosting product support : http://forum.gsmhosting.com/vbb/f1065/
Facebook Page : https://www.facebook.com/hydratool/
Official DistributorS and Resellers : http://forum.gsmhosting.com/vbb/f106...llers-2506619/
Official Support Group
Facebook : https://www.facebook.com/groups/246863286031193/
Telegram : https://t.me/joinchat/KdEOGFMjQlPnzmk8e_ltRw
Official Download site
Hydra Tool Softwares
https://drive.google.com/open?id=15r...ULrweV-TBV_fFb
Version : Hydra Tool v 1.2
Serial : 210900017996
plz my dongle not active
Old 11-20-2021, 07:48   #19 (permalink)
Hydra Supporter's Avatar
Member: 2977290
Thanks Meter: 702
Uninstalled old setup and delete folder C:/Hydra Tool
first installed smart card driver Alcor
download new Setup and installed
Run Humtool
Best Regard | Rashi Hydra Tool
Old 12-22-2021, 12:56   #20 (permalink)
Member: 592081
Thanks Meter: 16
Originally Posted by Hydra Tool View Post
Blocked Dongles & Error : LOCKED and NOT USABLE
*** Warning Hydra Dongle ****
ERROR : Hydra Dongle Locked and NOT USABLE
Please TAKE NOTE OF THE FOLLOWING:
  1. Please connect directly to pc/laptop usb port. If you use USBHub make sure cable is not too long or must be supported by power supply.
    *WE HAVE MULTIPLE ENCRYPTION INSIDE OUR APPLET. IT TAKES FEW SECONDS TO PROCESS*
  2. Avoid running hydra if you have sniffers/debuggers and other cracking tools installed in your pc.
  3. Please ALWAYS USE THE UPDATED Hydra Software Versions. We make it automatic update so we can fix whatever bugs and errors reported by users to avoid dongle error.
  4. DO NOT CHANGE PC TIME.
DO NOT USE THE OUTDATED SOFTWARE VERSIONS.
if you are see This life at log :
Life : 0-[10-0-0-0-0]
Its blocked, with Master Reset buton which at HumTool you can fix it,
Master Reset allow 2 time to reset it.
if Life become like this : Life : 2-[10-0-0-0-0]
Its mean your card blocked and you are already use 2 time Master Reset Buton, Please contact with us for Rebuild your card, it will take 5-7 working days
Thank you.
Hydra Update Manager Tool Ver 1.0.2 Build 18
Windows 10 (Version 10.0, Build 19042, 64-bit Edition)
Intel(R) Core(TM) i7 CPU 870 @ 2.93GHz
ATI Radeon HD 4600 Series
Serial : 191200003173
it is not active, it stays like this, help
Old 12-28-2021, 04:56   #21 (permalink)
Member: 2977290
Thanks Meter: 702
you need installed alcor driver from web,or follow this path C:\Hydra Tool\Driver\Smartcard\Alcor_Smartcardreader
Best Regard | Hydra TeaM
Old 02-21-2022, 07:37   #22 (permalink)
siang8788's Avatar
Member: 205283
Thanks Meter: 80
hi my dongle ask for activate,but already activated before..
Serial : 191200002974
Old 04-14-2022, 04:58   #23 (permalink)
Member: 2977290
Thanks Meter: 702
first installed alcor driver from C:\Hydra Tool\Driver\SmartCardReader_Alcor
Old 05-21-2022, 07:46   #24 (permalink)
Member: 2123463
Sonork: 100.1652545
Thanks Meter: 29
Humble request
nowadays mtk now security problem
and that is brom mode
plz add latest vivo infinix and all other mtk phone force preloader to brom
hydra is still failed in this function
thaks
Old 07-14-2022, 06:08   #25 (permalink)
Member: 1979008
Thanks Meter: 133
in all , hydra tool does not surpot windows 10/ 11 64bits!!!!! It only surports all 32bits windows......
Old 07-14-2022, 06:14   #26 (permalink)
Member: 1979008
Thanks Meter: 133
Hydra Dongle Smartcard Driver
VERSION
1.7.26.0
BIT
32
ALSO YOUR HYDRA TOOL SMARTCARD DRIVERS ARE 32BITS NO 64BITS
Old 07-16-2022, 06:30   #27 (permalink)
Member: 2977290
Thanks Meter: 702
VERSION
1.7.26.0
BIT
32
follow this path and only installed setup.exe
Old 07-26-2022, 14:37   #28 (permalink)
Member: 794428
Thanks Meter: 80
Hydra Update Manager Tool Ver 1.0.2.28
Windows 10 (Version 1809, OS Build 17763.3165, 64-bit Edition)
AMD Ryzen 5 PRO3500U w/ Radeon Vega Mobile Gfx
AMD Radeon(TM) Vega 8 Graphics
Ram Installed : 14 GB
Connecting to Hydra Server...All Countries...Ok
Serial : 190700001576
" Wrong length Le: 224 expected. "
This error can be fixed by the following:
1. Directly plug Hydra Dongle in your pc USB Port.
2. You need to install alcor driver.
3. Your card reader is slow, You need to replace it with fast one.
Old 07-26-2022, 19:34   #29 (permalink)
Techy147's Avatar
Member: 2331209
Thanks Meter: 2,726
Hello please Install alcor drivers or Use Good quality card reader.
Old 09-24-2022, 05:13   #30 (permalink)
Member: 1227219
Sonork: 100.1662069
Thanks Meter: 21
Serial : 200100003328
Initialize : OKAY
Status : NOT Activated
please help how to solve with this dongle. already activated and i used it but it comes out with that problem.
Page generated in 0.28255 seconds with 9 queries
