Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | ★ Wholesale Unlock ★ | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #1936 (permalink) | |
Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2008 Location: Whitehole throught Blackhole!
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,609 | Cherry Mobile Flare S8 FRPpartition successfully removed by Hydra Tool Cherry Mobile Flare S8 FRPpartition successfully removed by Hydra Tool 1. Run Hydra MTK Module 2. Select Brand and Model 2. Go to "Service"-->"Tool" 3. Choose "Factory Reset Protection FRP" 4. Choose "Auto" from "Method / Option" from drop down menu 5. connect the device to the computer 6. wait until the process is completed. Screen Short: ![]() Logs: Quote:
Dipendra Pathak | |
![]() | #1937 (permalink) | |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,609 | Huawei Honor MOA-LX9N (Honor 9A) restire OEM Infor successfully done by Hydra Tool Huawei Honor MOA-LX9N (Honor 9A) restire OEM Infor successfully done by Hydra Tool 1. Run MTK Hydra Tool. 2. Choose "Brand" and "Module". 3. Go to "Service"--> "Tool" 4. Choose "Huawei" 5. Chose "Restore OEM Info" from "Method/ Option" drop down option. 6. Click "Execute". 7. Connect Device to computer using USB Data Cable. 8. Wait until the operation is completed. Screen Short: ![]() Logs: Quote:
Dipendra Pathak | |
The Following User Says Thank You to Dipendra Pathak For This Useful Post: |
![]() | #1938 (permalink) | |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,609 | Huawei FRL-23 (Y9A 2021) 2 IMEI repaired successfully done by Hydra Tool Huawei FRL-23 (Y9A 2021) 2 IMEI repaired successfully done by Hydra Tool Screen Short: ![]() Logs: Quote:
Dipendra Pathak | |
![]() | #1939 (permalink) | |
Dipendra Pathak | |
![]() | #1940 (permalink) | |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,609 | Ragentek M5 Safe Universal Format successfully done by Hydra Tool_ Ragentek M5 Safe Universal Format successfully done by Hydra Tool_ 1. Run Hydra MTK Module Screen Short:2. Select Brand and Model as "Auto" 2. Go to "Service"-->"Tool" 3. Choose "Ultra Power Option" 4. Choose "Auto" from "Method / Option" from drop down menu 5. connect the device to the computer 6. wait until the process is completed. ![]() Logs: Quote:
Dipendra Pathak | |
![]() | #1941 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2011
Member: 1562854 Status: Offline Sonork: 1245 Thanks Meter: 255 | Reset done cph1989 Code: 1.0.3 Build 42 Windows 7 Service Pack 1 (Version 6.1, Build 7601, 32-bit Edition) Pentium(R) Dual-Core CPU E5800 @ 3.20GHz Jeu de puces Express Intel(R) G41 (Microsoft Corporation - WDDM 1.1) Ram Installed : 2 GB Windows Access Right Admin Software Run As Admnistrator ******* Dongle Info ******* Version : Hydra Tool v 1.2 Serial : 200700004667 Initialize : OKAY Status : Activated Life : 0 [0-0-0-0-0] ===================================== Searching for MTK Device...Found Port Identification :Flashmode BROM FriendlyName :MediaTek USB Port_V1632 (COM50) Device :5&136f0554&0&2 SymbolicName :\??\USB#VID_0E8D&PID_0003#5&136f0554&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Driver Ver :01/22/2015,3.0.1504.0 Handshaking...Ok Identifying Hardware ID..... Reading Device hardware info.. hw code : 0788MT6771 [6771] hw subcode : 8A00 hw version : CA00 sw version : 0000 Target config : E5 SB : 01 (True) SLA : 00 (False) DAA : 04 (True) Exploiting Device... Exploit Sent.. Successfully Exploited... Handshaking...Ok Identifying Hardware ID..... Reading Device hardware info.. hw code : 0788MT6771 [6771] hw subcode : 8A00 hw version : CA00 sw version : 0000 Target config : 00 SB : 00 (False) SLA : 00 (False) DAA : 00 (False) FUSEID : 00000000 SECURE VERSION : 05 BL VERSION : FE NORMAL BOOT Preparing Download Agent.. DA : [Not Exist] Trying Default 6771.bin Agent: MTK_DOWNLOAD_AGENT -HYDRA Ver : MTK_AllInOne_DA_v3.3001.2020-11-03.22:07_536568 Init : Loader [1] Sending : Accepted Identifying Protocol... Protocol : New Synchronization...SYNC Mode : brom Preloader Initialization... Parsing Reno_2F_preloader_oppo6771.bin Init : Accepted Execute Secondary Loader Init : Loader [2] Executing : SYNC Reading Device UniqueID, RAM and Flash Chip Info... UNIQUE ID : DA9AF5D21E66715A646201900DB92680 ERAM Size : 0x0000000000039000 -228 KB IRAM Size : 0x0000000200000000 -8 GB UFS LU0 Size: 0x0000000000400000 -4 MB UFS LU1 Size: 0x0000000000400000 -4 MB UFS LU2 Size: 0x0000001DCB000000 -119,172 GB UFS CID : Î☺KM8V7001JM-B810 UFS UNIQID : 00330039006500320035003100620030 DA Speed : high-speed Reading GPT-UFS [0x00008000] 130 Items Reading System Info ID : QP1A.190711.020 SDK : 29 Release : 10 ABI : arm64-v8a CPU abilist : arm64-v8a,armeabi-v7a,armeabi Locale : en-US Description : full_oppo6771-user 10 QP1A.190711.020 7604ad4e2b1328a1 release-keys Display ID : QP1A.190711.020 release-keys Security Patch : 2021-04-05 StorageType : mtp Userdata State : Not Encrypted Autobackup Partitions -preloader[0x00000000]512 KB ->preloader.bin...Ok -> Renaming Preloader.... preloader_oppo6771.bin Creating Scatter file... C:\Hydra Tool\\Backup\Auto\0788__053021092518\MT6771_Android_scatter.txt -pgpt[0x00000000]32 KB ->pgpt.bin...Ok -frp[0x0DE88000]1024 KB ->frp.bin...Ok -nvdata[0x0FF88000]64 MB ->nvdata.bin...Ok -protect1[0x15F88000]8 MB ->protect1.bin...Ok -protect2[0x16788000]8,469 MB ->protect2.bin...Ok -persist[0x17800000]48 MB ->persist.bin...Ok -nvram[0x26D00000]64 MB ->nvram.bin...Ok Done!!! C:\Hydra Tool\\Backup\Auto\0788__053021092518 MTK Phone Loader is NOW RUNNING. Reading Device UniqueID, RAM and Flash Chip Info... UNIQUE ID : DA9AF5D21E66715A646201900DB92680 ERAM Size : 0x0000000000039000 -228 KB IRAM Size : 0x0000000200000000 -8 GB UFS LU0 Size: 0x0000000000400000 -4 MB UFS LU1 Size: 0x0000000000400000 -4 MB UFS LU2 Size: 0x0000001DCB000000 -119,172 GB UFS CID : Î☺KM8V7001JM-B810 UFS UNIQID : 00330039006500320035003100620030 Reading GPT-UFS [0x00008000] 130 Items Reading System Info ID : QP1A.190711.020 SDK : 29 Release : 10 ABI : arm64-v8a CPU abilist : arm64-v8a,armeabi-v7a,armeabi Locale : en-US Description : full_oppo6771-user 10 QP1A.190711.020 7604ad4e2b1328a1 release-keys Display ID : QP1A.190711.020 release-keys Security Patch : 2021-04-05 StorageType : mtp Userdata State : Not Encrypted ------------------------------------- Operation : Auto Processing... ZeroWipe FRP Partition... Ok Elapsed Time : 00:01:07 |
The Following 2 Users Say Thank You to rai14 For This Useful Post: |
![]() | #1942 (permalink) | |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,609 | Xiaomi Redmi 9A (dandelion) Remove Mi Account (Patch Method) successfully removed by Xiaomi Redmi 9A (dandelion) Remove Mi Account (Patch Method) successfully removed by 1. Run Hydra MTK Module and Sosc. 2. Choose Brand and Module. 3. Go to "Service"-->"Tool" Tab. 4. Choose "Xiaomi". 5. Click on "Remove Mi Account (Patched Method)" from drop down menu. 6. Click "Execute" button 7. connect device to the computer with USB Data cable 8. Wait until the process is completed. Screen Short: ![]() Logs: Quote:
Dipendra Pathak | |
![]() | #1943 (permalink) | |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,609 | Oppo F3 (CPH1609) safe format successfully done by Hydra Tool Oppo F3 (CPH1609) safe format successfully done by Hydra Tool 1. Run MTK Tool and choose "Sosc" 2. Choose Brand and Module as "Auto" 3. Go to "Service"--> "Tool" from Universal Option 4. Choose "Factory Reset / Format user data" 5. Choose "Auto" from "Method / Option" drop down menu. 6. Connect device to computer using USB Data Cable. 7. Wait until the operation is completed Screen Short: ![]() Logs: Quote:
Dipendra Pathak | |
![]() | #1944 (permalink) | |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,609 | Infix X682C (HOT 10) safe format universal OKAY by Hydra Tool Infix X682C (HOT 10) safe format universal OKAY by Hydra Tool 1. Run MTK Tool and choose "Sosc" 2. Choose Brand and Module as "Auto" 3. Go to "Service"--> "Tool" from Universal Option 4. Choose "Factory Reset / Format user data" 5. Choose "Auto" from "Method / Option" drop down menu. 6. Connect device to computer using USB Data Cable. 7. Wait until the operation is completed Screen Short: ![]() Logs: Quote:
Dipendra Pathak | |
![]() | #1945 (permalink) | |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,609 | Huawei MED-LX9X (Y6P 2020) Restore OEM info successfully done by Hydra Tool Huawei MED-LX9X (Y6P 2020) Restore OEM info successfully done by Hydra Tool 1. Run MTK Hydra Tool. 2. Choose "Brand" and "Module". 3. Go to "Service"--> "Tool" 4. Choose "Huawei" 5. Chose "Restore OEM Info" from "Method/ Option" drop down option. 6. Click "Execute". 7. Connect Device to computer using USB Data Cable. 8. Wait until the operation is completed. Screen Short: ![]() Logs: Quote:
Dipendra Pathak | |
![]() | #1946 (permalink) | |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,609 | Xiaomi Redmi Note 4 disabe Mi Account Anti-relock ADB METHOD done by Hydra Tool Xiaomi Redmi Note 4 disabe Mi Account Anti-relock successfully done by Hydra Tool 1. Run Hydra MTK Module and choose "Sosc" 2. Select Brand and Model as "Auto" 3. Go to Service-->Tools-->Xiaoami 4. Choose "Disable Mi Account Anti Lock" from "Method / Option" drop down menu 5. Execute and connect the device to the computer with data cable 6. wait until the process is completed. Screen Short: ![]() Logs: Quote:
Dipendra Pathak | |
![]() | #1947 (permalink) | |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,609 | Huawei Y9 Pro factory reset protection FRP successfully removed by Hydra Tool Huawei Y9 Pro factory reset protection FRP successfully removed by Hydra Tool 1. Run MTK tool of Hydra Dongle. 2. Choose Correct Module and Brand or choose "Auto". 3. Go to "Service" -- > "Tool" 4. choose "Factory Reset Protection (FRP)". 5. Choose "Auto" from "Method / Option" drop down menu. 6. Click on "Execute" and connect device with computer using USB cable. 7. Wait until the process is completed. Screen Short: ![]() Logs: Quote:
Dipendra Pathak | |
![]() | #1948 (permalink) | |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,609 | Xiaomi Redmi 6A (Cactus) Safe Formet Universal Okay by Hyda Tool Xiaomi Redmi 6A (Cactus) Safe Formet Universal Okay by Hyda Tool 1. Run Hydra MTK Module, 2. Select Brand and Model 3. Go to Service-->Tool 4. Choose "Ultra Power Option" 5. Choose "Safe Format Method 1" from drop down method 6. Execute and connect the device to the computer with data cable 7. wait until the process is completed. Screen Short: ![]() Logs: Quote:
Dipendra Pathak | |
![]() | #1949 (permalink) | |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,609 | Vivo Y91i (1820) erasing FRP Partition is successfully done by Hydar Tool Vivo Y91i (1820) erasing FRP Partition is successfully done by Hydar Tool 1. Run Hydra MTK Tool. 2. Choose Brand and Module. 3. Go "Service"-->"Tooll" 4. Choose "Factory Reset Protection FRP" from universal menu.. 5. Choose "Format / Erase" from drop down "Method / Option" 6. Click "Execute" 7. Connect cellphone to computer with the help of USB Data Cable. 8. Wait until the operation is completed. Screen Short: ![]() Logs: Quote:
Dipendra Pathak | |
![]() | #1950 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,609 | Huawei FRL-L22 Y9A 2021 IMEI Repair by Test Point Huawei FRL-L22 Y9A 2021 IMEI Repair by Test Point You can reach and know everything of Hydra Tool yourself - we are transparent! [/CENTER]What is hydra Tool - visit the hyper link: https://www.hydra-dongle.com/resellers/ Modules Hydra tool supports - visit the hyper link: https://www.hydra-dongle.com/modules/ Brands Hydra tool supports - visit the hyper link: https://www.hydra-dongle.com/brands/ Downloading Hydra Software - visit the hyper link: https://www.hydra-dongle.com/download/ Manual of Hydra Tool - visit this hyper link: https://www.hydra-dongle.com/help/ Drivers of Hydra Tool - visit the hyper link: https://www.hydra-dongle.com/drivers/ Hydra Face Book site - visit the hyper link: https://www.facebook.com/hydra.tool.37 Support of Hydra Tool - visit the hyper link: https://www.hydra-dongle.com/contact/ Reseller of hydra Tool - visit the hyper link: https://www.hydra-dongle.com/resellers/ BR Dipendra Pathak Last edited by Hydra Tool; 06-01-2021 at 10:32. |
