Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GSMFABRICA Products > HYDRA TOOL
Old 07-01-2021, 05:21   #2131 (permalink)
Dipendra Pathak's Avatar
Member: 747989
Sonork: 100.1593052
Thanks Meter: 8,609
Huawei DRA-LX2 (Y5 Prime 2018) Both IMEI Repair successfully done by Hydra Tool
1. Run Hydra MTK Tool
2. Choose Brand and Module
3. Go to "Service"--> "Repair IMEI"
4. Tick "IMEI change....Illigal......
5. Choose "Huawei Flash Mode" from drop down menu.
6. Tick both IMEI to active box and type both IMEI as written in battery housing of the cellphone.
7. Click on "Repair IMEI"
8. Connect cellphone with computer using USB Data Cable.
9. Wait until the operation is completed.
Screen Short:
Dipendra Pathak
Old 07-01-2021, 05:28   #2132 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 8,609
Vivo V11 Pro (V1804) Zero Wipe FRP successfully removed by Hydra Tool
1. Run Qualcomm Module of Hydra Tool
2. Choose Brand and Model
3. Go to "Service"-->"Universal"
4. Choose "Factory Reset Protection" from drop down menu.
5. Choose "Auto" from flash mode.
6. Execute and insert the USB Data Cable
7. Wait until the operation is completed.
Screen Short:
Dipendra Pathak
Old 07-01-2021, 05:47   #2133 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 8,609
FRP and Format using Direct EMMC successfully removed by Hydra Main Tool
1. Run Main Tool of Hydra.
2. Choose "EMMC Direct" Tab.
3. Choose Platform as "Auto"
4. Dissemble cellphone or device
5. Connect it with wires as different places (as you have to do with EMMC)
6. Now, connect it with computer using usb cable.
7. Choose Port as it shows in your computer. Here is PhysicalDrive1.
8. Go to "Service"
9. Choose "Security Reset" from drop down menu.
10. Choose "Safe Format"
11. Tick "Remove FRP" just above "Execute" button
12. Click on "Execute" button
13. Wait until the operation is computed.
Screen Short:
Dipendra Pathak
Old 07-01-2021, 05:55   #2134 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 8,609
Xiamo Redmi 5 Plus (Vince) zero wipr FRP successfully Removed by Hydra Tool
1. Run Hydra Qualcomm Module.
2. Choose Brand and Module.
3. Go to "Service"-->"Universal" Tab.
4. Choose "Factory reset protection" from drop down menu
6. Click "Execute" button
7. connect device to the computer with USB Data cable
8. Wait until the process is completed
Screen Short:
Dipendra Pathak
Old 07-02-2021, 01:34   #2135 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 8,609
Xiaomi Redmi 9 (Lancelot) Mi Account and FRP successfully removed by Hydra Tool
1. Run Hydra MTK Module and Sosc.
3. Go to "Service"-->"Tool" Tab.
4. Choose "Xiaomi".
5. Click on "Remove Mi Account (Erased Method) + FRP" from drop down menu.
8. Wait until the process is completed.
Screen Short:
Dipendra Pathak
Old 07-02-2021, 01:42   #2136 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 8,609
Xiaomi Redmi 8 (Olive) Mi Account successfully patched by Hydra Tool
1. Run Hydra Quaocomm module.
3. Go to "Service"-->"Xiaomi" Tab.
4. Choose "Mi Account" from drop down menu.
5. Choose "Remove Mi Account (New Method)" from Flash Mode.
Screen Short:
Dipendra Pathak
Old 07-02-2021, 01:58   #2137 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 8,609
Xiaomi Redmi Note 9 Pro successfully flashed selected partition by Hydra Tool
1. Run Hydra Qualcomm Tool
2. Go to "Flash" Tab
3. Choose Flash file from "Image Path"
4. choose "Flash Mode"
5. Untick "Skip write security partition" if you do not want to write it.
6. Tick "Auto Backup EFS" if you really want it.
7. Click on "Execute"
8. Connect Device with Computer using USB Data Cable
9. Wait until the flashing process is completed.
10. Done
Screen Short:
Dipendra Pathak
Old 07-02-2021, 02:08   #2138 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 8,609
Xiaomi Redmi 6 (Cereus) Mi Account successfully removed by Hydra Tool
4. Choose "Xiaomi".
Screen Short:
Dipendra Pathak
Old 07-03-2021, 02:30   #2139 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 8,609
Xiaomi Redmi 9 (Lancelot) FRP successfully removed by Hydra Tool
1. Run Hydra MTK Module and choose "Sosc"
2. Select Brand and Model
3. Go to Service-->Tool
4. Choose "Factory reset protection FRP from universal menu.
5. Choose "Zero Wipe" from "Option / Method" drop down menu
6. Execute and connect the device to the computer with data cable
7. Click on "Execute".
8. wait until the process is completed.
Screen Short:
Dipendra Pathak
Old 07-03-2021, 02:54   #2140 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 8,609
Xiaomi Redmi Note 9 (merlin) Second IMEI successfully removed by Hydra Tool
1. Run Hydra MTK module and SOSc.
2. Choose Brand and Module as auto.
3. Go to "Service"--> "IMEI" Tab.
4. Tick "Changing IMEI changing is illegal .................."
5. Choose "Xiaomi Flash mode" from drop down menu
6. Tick "IMEI 2"
7. Type IMEI as written as battery housing.
8. connect device to the computer with USB Data cable
9. Wait until the process is completed
Screen Short:
Dipendra Pathak
Old 07-03-2021, 03:10   #2141 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 8,609
Xiaomi Redmi 9A (dendelion) FRP and Mi Account remove successfully done by Hydra Tool
4. Choose "Xiaomi".
Screen Short:
Dipendra Pathak
Old 07-03-2021, 03:29   #2142 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 8,609
4. Choose "Xiaomi".
Screen Short:
Dipendra Pathak
Old 07-03-2021, 03:34   #2143 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 8,609
Xiaom Redmi 9C (Angelica) Repair SECOND IMEI successfully done by Hydra Tool
4. Tick "Changing IMEI changing is illegal......................"
6. Tick "IMEI 2"
Screen Short:
Dipendra Pathak
Old 07-04-2021, 02:09   #2144 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 8,609
Oppo A5S (CPH 1909) Factory Reset or removed use data successfully done by Hydra_edit
1. Run MTK Tool and choose "Sosc"
3. Go to "Service"–> "Tool"
4. Choose "Ultra Option"
5. Choose "Auto " from "Method / Option" drop down menu.
6. Click on "Execute"
7. Connect device to computer using USB Data Cable.
8. Wait until the operation is completed.
Screen Short:
Dipendra Pathak
Old 07-04-2021, 02:15   #2145 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 8,609
Huawei MRD-LX2 (Y6 2019) Zero wipe FRP partition successfully done by Hydra Tool
1. Run MTK tool.
2. Choose Correct Module and Brand.
3. Go to "Service" -- > Tool"
4. Choose "Factory Reset Protection" tool from universal option.
5. choose "Zero wipe" .
6. Click on "Execute" and connect device with computer using USB cable.
7. Wait until the process is completed.
Screen Short:
]BR
Dipendra Pathak
Page generated in 0.20360 seconds with 9 queries
