07-28-2021, 05:14 | #2281 (permalink) |
Product Manager Join Date: Apr 2008 Location: Whitehole throught Blackhole!
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | Huawei FRL-L23 (Y9A 2021) both IMEI repaired successfully by Hydra Tool Huawei FRL-L23 (Y9A 2021) both IMEI repaired successfully by Hydra Tool 1. Run Hydra MTK Module and choose Sosc. 2. Choose Brand and Module. 3. Go to "Service"->"Repair IMEI" Tab. 4. Tick "IMEI changing is illigal ." 5. Choose "Huawei FlashMode" from the drop down menu. 6. Type both IMEI written as battery housing and tick both IMEI boxes 7. Click on "Repair IMEI" 8. Connect the computer to the USB data cable 9. Wait until the process is complete. Screen Short: BR Dipendra Pathak |
07-28-2021, 05:24 | #2282 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | Xiaomi Redmi Note 9 (Merlin) Find Device Successfully Removed by Hydra tool Xiaomi Redmi Note 9 (Merlin) Find Device Successfully Removed by Hydra tool 1. Run Hydra MTK Module and Sosc. 2. Choose Brand and Module. 3. Go to "Service">"Tool" Tab. 4. Choose "Xiaomi". 5. Click on "Find Device" from drop down menu. 6. Click "Execute" button 7. connect device to the computer with USB Data cable 8. Wait until the process is completed. Screen Short: BR Dipendra Pathak |
07-29-2021, 01:08 | #2283 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | OPPO A15 (CPH 2185) No More Dead Now From TP-1 by Hydra Tool OPPO A15 (CPH 2185) Fix Dead From TP-1 by Hydra Tool 1. Run MTK Hydra tool. 2. Choose Correct Module and Brand. 3. Go to "Service" -- > Tool" 4. Choose "Oppo" tool from universal option. 5. choose "Fix dead from TP-1" from "Method / Option" drop down menu 6. Click on "Execute" and connect device with computer using USB cable. 7. Wait until the process is completed. Screen Short: BR Dipendra Pathak |
07-29-2021, 01:26 | #2284 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | Oppo MTK6765 FRP successfully removed using manual boot (preloader Oppo any MTK6765 manual boot (preloader) makes and removes FRP using by Hydra Tool 1. Run MTK tool of Hydra Dongle. 2. Choose Correct Boot File ie preloader.bin file Note: Even you do not have boot file, you can make boot or preloader.bin file using Hydra Tool. For this, you have to go "EXPLOIT" tab and use "(BROM) Dump preloader Flash Init." function. 3. Choose "Auto Broom Exploit" 4. Go to "Service" -- > "Tool" 5. choose "Factory Reset Protection - FRP". 6. Choose "AUTO" from "Method / Option" of drop down menu. 7. Click on "Execute" and connect device with computer using USB cable. 8. Wait until the process is completed Screen Short: BR Dipendra Pathak |
07-29-2021, 01:41 | #2285 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | Xiaomi Redmi Note 8 Pro (Begonia) successfully flashed by Hydra Tool Xiaomi Redmi Note 8 Pro (Begonia) successfully flashed by Hydra Tool 1. Run Hydra MTK Module, 2. Select Brand and Model 3. Tick "Auto Broom Exploit" 4. Tick "Enable UBL Loader" (Note: You can use this option if it the device does not boot properly by Hydra Tool) 5. Go to "Flash" tab 6. Choose correct file from its location and load it. 7. Untick "Enable write Preloader" if you do not write it. 8. Execute and connect the device to the computer with data cable 9. wait until the process is completed. Screen Short: BR Dipendra Pathak Last edited by Dipendra Pathak; 07-29-2021 at 01:47. |
07-29-2021, 02:13 | #2286 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | Oppo F3 (CPH 1609) Factory Reset or Format user data successfully done by Hydra Tool Oppo F3 (CPH 1609) Factory Reset or Format user data successfully done by Hydra Tool 1. Run MTK Tool and choose "Sosc" Screen Short:2. Choose Brand and Module or "Auto" 3. Choose "Auto Broom Exploit" 4. Go to "Service"> "Tool" from Universal Option 5. Choose "Factory Reset / Format user data" 6. Choose "Auto" from "Method / Option" drop down menu. 7. Connect device to computer using USB Data Cable. 8. Wait until the operation is completed BR Dipendra Pathak |
07-29-2021, 15:12 | #2287 (permalink) |
Product Manager Join Date: Aug 2018 Location: Ukraine / Harkov
Member: 2857401 Status: Online Thanks Meter: 6,861 | Redmi 9C (angelica) IMEI Repair by Hydra Dongle Xiaomi Redmi 9C (angelica) IMEI Repair by Hydra Dongle No need Unlock Bootloader | No Need Root | No Need Auth Last edited by Hydra Tool; 07-29-2021 at 15:25. |
07-30-2021, 01:49 | #2288 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | Vivo Y71 (1724) FRP and safe format EMMC method successfully done by Hydra Tool Vivo Y71 (1724) FRP and safe format EMMC method successfully done by Hydra Tool 1. Run Qualcomm Tool and choose "Sosc" 2. Choose Brand and Module. 3. Go to "Service"--> "Vivo" 4. Choose "Factory Reset" from drop down menu 5. Choose "Safe Format EMMC" from Flash Mode 6. Tick "Include FRP" 7. Click on "Execute" 8. Connect device to computer using USB Data Cable. 9. Wait until the operation is completed. Screen Short: BR Dipendra Pathak |
07-30-2021, 01:54 | #2289 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | Redmi Note 8 (Ginkgo) Mi Account successfully removed by Hydra Tool Redmi Note 8 (Ginkgo) Mi Account successfully removed by Hydra Tool 1. Run Hydra Qualcomm Module. 2. Choose Brand and Module. 3. Go to "Service">"Xiaomi" Tab. 4. Choose "Mi Account" from drop down menu. 5. Choose "Remove Mi Account" flash Mode. 6. Tick "Include FRP" 7. Disassemble the cellphone (Device) 8. Click "Execute" button 9. Connect Two Test Point using Twister or Short it. 10. connect device to the computer with USB Data cable 11. Wait until the process is completed. Screen Short: BR Dipendra Pathak |
07-30-2021, 01:59 | #2290 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | Oppo A37f Factory Reset Protection -FRP successfully removed by Hydra Tool Oppo A37f Factory Reset Protection -FRP successfully removed by Hydra Tool 1. Run Hydra Qualcomm Module. 2. Choose Brand and Module. 3. Go to "Service">"Universal" Tab. 4. Choose "Factory Reset Protection" from drop down menu. 5. Choose "Zero wipe" flash Mode. 6. Click "Execute" button 7. connect device to the computer with USB Data cable 8. Wait until the process is completed. Screen Short: BR Dipendra Pathak |
07-30-2021, 02:07 | #2291 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | Huawei ATU-L22 (Y6 2018) Zero Wipe FRP successfully done by Hydra Tool Huawei ATU-L22 (Y6 2018) Zero Wipe FRP successfully done by Hydra Tool 1. Run Hydra Qualcomm Module. 2. Choose Brand and Module. 3. Go to "Service">"Huawei" Tab. 4. Choose "Factory Reset" from drop down menu. 5. Choose "Remove FRP" flash Mode. 6. Click "Execute" button 7. connect device to the computer with USB Data cable 8. Wait until the process is completed. Screen Short: BR Dipendra Pathak |
07-30-2021, 10:10 | #2292 (permalink) | |
No Life Poster Join Date: Feb 2012 Age: 39
Member: 1724862 Status: Offline Thanks Meter: 448 | Xiaomi Redmi Note 8 ginkgo IMEI Repair by Hydra Dongle Xiaomi Redmi Note 8 ginkgo IMEI Repair by Hydra Dongle Steps : Root your device by TWRP Enable Diag and Connect Device or Flash ENG Rom by EDL (Testpoint) then Repair IMEI Quote:
07-30-2021, 17:03 | #2293 (permalink) |
Freak Poster Join Date: Apr 2008 Location: A_1st Support Age: 38
Member: 758981 Status: Offline Sonork: 100.1592091 Thanks Meter: 232 | Xiaomi Redmi 9 (Lancelot) Unlock BootLoader Success Xiaomi Redmi 9 (Lancelot) Unlock BootLoader Success Code: Searching for MTK Device...Found Port Identification :Flashmode BROM FriendlyName :MediaTek USB Port (COM22) Device :6&2b93e363&0&1 SymbolicName :\??\USB#VID_0E8D&PID_0003#6&2b93e363&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Driver Ver :01/22/2016,3.2 Handshaking...Ok Identifying Hardware ID..... Reading Device hardware info.. hw code : 0707MT6768 [6768] hw subcode : 8A00 hw version : CA00 sw version : 0000 Target config : E7 SBC : 01 (True) SLA : 02 (True) DAA : 04 (True) SWJTAG : 06 (True) EPP : 00 (False) CERT : 00 (False) MEMREAD : 20 (True) MEMWRITE : 40 (True) CMD_C8 : 80 (True) Exploiting Device... Exploit Sent.. Successfully Exploited... Handshaking...Ok Identifying Hardware ID..... Reading Device hardware info.. hw code : 0707MT6768 [6768] hw subcode : 8A00 hw version : CA00 sw version : 0000 Target config : 00 SBC : 00 (False) SLA : 00 (False) DAA : 00 (False) SWJTAG : 00 (False) EPP : 00 (False) CERT : 00 (False) MEMREAD : 00 (False) MEMWRITE : 00 (False) CMD_C8 : 00 (False) MEID : 4FF873B7D5374A183BEF9F4D112132FE Stage 1..[Size:256504] Sending : Please wait.. Accepted Identifying Protocol... Protocol : New Synchronization...SYNC Preloader Initialization... Parsing preloader_lancelot.bin Init : Accepted Executing : SYNC Reading Device UniqueID, RAM and Flash Chip Info... UNIQUE ID : A5E956D37B12E49DCF95D2605813FEB5 ERAM Size : 0x0000000000070000 -448 KB IRAM Size : 0x0000000100000000 -4 GB eMMC BOOT1 : 0x0000000000400000 -4 MB eMMC BOOT2 : 0x0000000000400000 -4 MB eMMC RPMB : 0x0000000001000000 -16 MB eMMC USER : 0x0000000E8F800000 -58.242 GB eMMC CID : 1501004450364441420356AF681847C5 - DP6DAB Executing : ACCEPTED... Reading GPT-EMMC [0x00008000] 130 Items Autobackup Partitions -preloader[0x00000000]512 KB ->preloader.bin...Ok -> Renaming Preloader.... preloader_lancelot.bin Creating Scatter file... C:\Hydra Tool\\Backup\Auto\0707__073021180027\MT6768_Android_scatter.txt -pgpt[0x00000000]32 KB ->pgpt.bin...Ok -frp[0x05508000]1024 KB ->frp.bin...Ok -nvdata[0x0C4A2000]64 MB ->nvdata.bin...Ok -persist[0x104A2000]48 MB ->persist.bin...Ok -protect1[0x164A2000]8 MB ->protect1.bin...Ok -protect2[0x16CA2000]11.367 MB ->protect2.bin...Ok -nvram[0x19F80000]64 MB ->nvram.bin...Ok Done!!! C:\Hydra Tool\\Backup\Auto\0707__073021180027 MTK Phone Loader is NOW RUNNING. Reading Device UniqueID, RAM and Flash Chip Info... UNIQUE ID : A5E956D37B12E49DCF95D2605813FEB5 ERAM Size : 0x0000000000070000 -448 KB IRAM Size : 0x0000000100000000 -4 GB eMMC BOOT1 : 0x0000000000400000 -4 MB eMMC BOOT2 : 0x0000000000400000 -4 MB eMMC RPMB : 0x0000000001000000 -16 MB eMMC USER : 0x0000000E8F800000 -58.242 GB eMMC CID : 1501004450364441420356AF681847C5 - DP6DAB Reading GPT-EMMC [0x00008000] 130 Items ------------------------------------- Operation : Unlock Bootloader Processing... ------------------------------- Bootloader Status... Bootloader : Locked ------------------------------- Verifying status after operation... ------------------------------- Bootloader Status... Bootloader : Unlocked ------------------------------- Action Result : Ok Rebooting Device [Reboot To Normal] Reboot Done!! Elapsed Time : 00:01:48 |
07-31-2021, 02:00 | #2294 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | Samsung G532 (J2 Prime) Backing Up PIT file successfully done by Hydra Tool Samsung G532 (J2 Prime) Backing Up PIT file successfully done by Hydra Tool 1. Run Hydra Main Tool. Screen Short:2. Choose "Samsung" Tab. 3. Put the Device into DOWNLOAD Mode 4. Connect device to the computer using USB Data Cable. 5. Let the computer install device driver. 6. Choose "Port" that takes by Samsung Device. 7. Choose "Service" Tab 8. Choose "Partition Information Table" from drop down menu. 9. Choose Backup PIT" 10. Tick "Auto Reboot" 11. Click on "Execute" 12. Wait until the operation is completed. BR Dipendra Pathak |
07-31-2021, 02:03 | #2295 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | Hisilicon AGs2-L03 (MediaPad T5) FRP successfully removed by Hydra Main Tool Hisilicon AGs2-L03 (MediaPad T5) FRP successfully removed by Hydra Main Tool 1. Run Hydra Main Tool. Screen Short:2. Choose "Hisilicon" Tab. 3. Choose "Module" 4. UnTick "Auto Boot" 5.Choose CPU ID: Kirin 659 and Loader: Kirin 659.fb 6. Choose "Service" Tab 7. Choose "Factory Reset Protection / Account" from drop down menu. 8. Choose "Remove FRP" 9. Click on "Execute" 10. Connect the device to the compute with the help of Data Cable. 11. Wait until the operation is completed. BR Dipendra Pathak |
