04-29-2021, 23:35 | #122 (permalink) |
No Life Poster Join Date: Jul 2011 Location: Nairobi, Kenya
Member: 1610674 Status: Offline Sonork: 210921 Thanks Meter: 217 | Please 🙏 Many emi configuration missing in database... If possible add option to auto learn and save emi settings to database after first time connection . Some phones it's very hard to get their firmware For African market and middle East where mtk is more common need brands like Tecno, Infinix, itel, maizu, Gionee, wiko etc Also add direct memory tool ( partion manager) with option to read, write and wipe specific ( selected) partions by name. This will help us in resetting mi account , FRP and Huawei ID bypass, without need for scatter file to get the partion`s address (normal sp flash tool method). Add Device health check Add Remove/ Disable screen lock Add option for backup Factory ROM (factory userdata) other than backing up 64Gb userdata) partition Check button for Reset FRP during wipe user data Bug. Option of format+ download not working in many devices gives error formating |
05-03-2021, 10:27 | #126 (permalink) |
No Life Poster Join Date: Aug 2006 Location: gsmchaudhrayarshad Age: 43
Member: 328688 Status: Offline Thanks Meter: 2,283 | Need add disply id option when u read info LOOK LOG IT NOT SHOW DISPLAY ID Software version: 1.9 Code: Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Wait for device connecting... OK Device found at COM24 [PRELOADER] Open port... OK Send start cmd... OK Get HW code from device... 6580 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6580] Library Version [1] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Load DownloadAgent... OK Get sec config... OK [00000000] Get BROM version... OK Search DA... OK [5] Send bootloader... OK Start bootloader... OK Check bootloader answer... OK Wait for answer from bootloader... OK Wait for hw detection... OK Wait DA version... v4.2 Send BROM version... OK Send storage config... OK SyncBmtInfoWithDA... OK Set params... OK Sync with DA... OK Wait for DA H/W detection... OK EMMC INFO: EMMC_ID : 0x150100513758534142010F7BC8B79159 EMMC_BOOT1: 0x0000400000 (4,00Mb) EMMC_BOOT2: 0x0000400000 (4,00Mb) EMMC_RPMB : 0x0000080000 (512,00Kb) EMMC_USER : 0x01D2000000 (7,28Gb) RAM INFO: INT_SRAM: 0x0000020000 (128,00Kb) EXT_RAM : 0x0040000000 (1,00Gb) Read Flash Info done! Code: Product Brand : PREMIO Product Device : S81 Product Model : S81 Product Name : S81 Patch Level : QP1A.190711.020 Display ID : J106_KT6012B_PREMIO_S81_V01_20200805 Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2020-06-05 Build Time : 31.10.2020 Product Manfct : PREMIO Product Info : S81 Product Board : k80hd_bsp_fwv_512m Board Platform : mt6580 |
05-03-2021, 17:52 | #128 (permalink) |
Freak Poster Join Date: Mar 2016
Member: 2542848 Status: Offline Thanks Meter: 80 | Unlock bootloader Redmi 6a ? Hi This box can unlock bootloader Redmi 6a ? Who have phone in hand, please test and post results. If this Box can unlock bootloader Redmi 6a I will buy this Box. |
05-03-2021, 19:09 | #129 (permalink) | |
Insane Poster Join Date: Oct 2010
Member: 1418749 Status: Offline Thanks Meter: 45 | Quote:
https://forum.gsmhosting.com/vbb/f11...a-box-2957592/ you can try it , this will sure unlock bootloader xiaomi Phones i tried FRP Unlocked , so it should be unlock bootloader also | |
05-06-2021, 17:55 | #131 (permalink) |
No Life Poster Join Date: Apr 2003 Location: Torun, Poland Age: 40
Member: 25996 Status: Offline Thanks Meter: 254 | That depends on the phone, and not all are supported directly. For example, Y5p requires a testpoint to force bootrom mode, and is actually not supported unless you load a firmware file (scatter with correct preloader), while y5 2018 works fine just proper keys pressed during boot (vol- and power), except for bootloader unlock that doesn't seem to do anything for it at the moment. |
05-06-2021, 19:08 | #132 (permalink) |
Member: 1610674 Status: Offline Sonork: 210921 Thanks Meter: 217 | Please team this is the kind of update we need "BROM Port-Dump Preloader Flash Init. *This function will fix booting issue, if assigned or automatic EMI fails to work during booting" To auto dump preloader from phone and use it to boot . To save us the problem of looking for scatter firmware just to remove FRP |
05-09-2021, 01:42 | #133 (permalink) |
Freak Poster Join Date: Oct 2020 Location: Pakistan Age: 25
Member: 2971741 Status: Offline Thanks Meter: 38 | All Models IMEI Repair Add vivo & Oppo & Nokia Qualcomm & Motorola/moto & Alcatel & Fastboot To Edl without root and whithout unlock bootloader vivo & Xiaomi 💥💥💥 |
05-13-2021, 19:33 | #135 (permalink) |
Crazy Poster Join Date: Feb 2014
Member: 2121390 Status: Offline Thanks Meter: 12 | MOTO E6 Plus XT2025-1 add support network unlock Motorola Moto E6 Plus[2+32Gb] Motorola Moto E6 Plus[2+64Gb] CPU : MT6765 |
The Following User Says Thank You to ribebe For This Useful Post: |
