Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L )
Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) Nokia Legacy Models Like 1011, 1610, 211x, 2x20, 6050, 3110, 8110, NKxxx , 2100, 3210, 3310, 3330, 3410, 5110, 5210, 5510, 6110, 6150, 6210, 6250, 7110, 8210, 8250, 8850 also 9110 & 9210
Old 10-07-2001, 16:13   #1 (permalink)
Member: 4403
Post problem with battery
i have a 3210 and when i charge the battery, they life is about 12 h. works fine till now. which is the cause? is the battery or hardware? battery is about 3-4 month old. can help me any1?
<br />best regards
[ 07 October 2001: Message edited by: mrENigma ]</p>
Old 10-09-2001, 12:50   #2 (permalink)
Member: 2628
Post
It sounds to me that it is the batteri that have the problem, try to change it.!!!
<br />Good luck
Old 10-10-2001, 06:23   #3 (permalink)
Member: 4403
Post
i think about it. and i buy a new one. this time an original one. yes the battery it was doom. ehhh.... made in taiwan.... <img src="smile.gif" border="0"> <img src="smile.gif" border="0"> <img src="smile.gif" border="0">
thx anyway zizo.
best regards
Old 10-10-2001, 08:48   #4 (permalink)
Member: 2628
Post
Great to hear that it works now. Do not buy a batteri from taiwan or honkong or someting like that. If u have a nokia phone buy always a batteri from Finland (nokia batteri) or from germany ( it also a nokia batteri) There a 3 countrys how make the nokia phones there are:
Finland ( home country)<br />Germany<br />USA
<br />Good luck!
Old 10-10-2001, 15:41   #5 (permalink)
Member: 4403
Post
with this new one after fully drain and one recharge after 12 h i have half life? is something wrong? or what? damm battery.... pls tell me. or i see the effects after 3 fully drain and recharges?
<br />best regards
Old 10-10-2001, 18:18   #6 (permalink)
Member: 2628
Post
Hello mrENigma,
If we start from the beging, first u have to get a battery as I told u before, a Nokia orginal battery and no b**** battery. We u get it so first time charging u have to charge the battery at least 15 h full time. Then u have to leve the phone on untill the battery finish by it self if u know what I meen. At the second time u charge the battery normaley untill the phone says it finish (normal charging) and LEAVE the phone on until the phone get off. U do the same charging again like the second one and aftet that u can charge the phone and shout it off as u like.
That was the "rule" about the new battey but remember u get the full effect when u have a nokia orignal battery.
For ur problem it sound to me that u have something strange in ur charger or the components around the charger contact in ur phone. If ur charge work for 100 % so I recomend u to go a nokia center to fix it for u cause it is very hard to check the componetns by it self if u know what I meen. Check the battery first I meen take ur battery to another phone and test, if u get the same problem u will know that the problem are the battery. Do the same for ur charger use it on another phone and test. And if all this test work 100 % i think that u have problem in ur phone so my friend go to nokia center to fix it for u.
<br />Good luck my friend and do not forget to tell me what happend <img src="smile.gif" border="0">
Sony Ericsson T610 problems, no charge, not a problem with battery or adapter ultrajosh Sony Ericsson Hardware Repair 2 12-10-2008 12:46
6600 problem with batterie fethi Nokia Hardware & Hardware Repair 2 12-11-2007 06:09
Problems with Battery Connector Christobol_007 DreamBox 2 06-15-2006 01:23
problems with battery after flashing sakhin x1x to x45/x50 3 12-09-2002 10:16
Problem with battery indicator on 3210 cole Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 04-19-2002 04:03
Page generated in 0.14120 seconds with 9 queries
