Old 07-18-2009, 10:02   #1 (permalink)
Crazy Poster
Member: 997777
Sonork: 686671
Thanks Meter: 10
3120 c cmt error can help plz.......
3120C FLASHING LOGO ON DEAD USB IN JAF I try f bus cable same
Fhone Type:
FILES SET FOR FLASHING:
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-365\rm364__09.41.mcusw
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-365\rm364__09.41.ppm_f
CNT Flash file: NONE
APE Variant file: NONE
Languages in ppm: English,German,Hebrew,Arabic,Russian
Phone Type:
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-365\rm365__09.41_ISM_009.image_f_chestnut_brown
Detected P-KEY: 9002A24C
P-key nokia module version 01.02
Init usb communication...
PRESS POWER ON NOW!
Searching for phone...Found
Sending RAW loader...
Using 06.02.002
Elf2flash 07.14.000
CMT RAW loader...
Patching RAW boot step1...
Patching RAW boot step2...
Patching RAW boot step3...
Sending RAW Loader...
...................Loader Sent!
Stage 2 starting.......................................... ...................................Loader Sent!
Stage 3 starting..................Phone prepared OK!
Waiting for the phone to boot...
Phone failed to boot in flash mode CMT...
help me plzzzz.........
Old 07-18-2009, 10:21   #2 (permalink)
mahbubalfa's Avatar
Member: 1003058
Sonork: 100.1589274/mahbubalfa
Thanks Meter: 26,433
Bro...use 7pin cable...& flash...
if not ok..
rehot flash ic..................
Old 07-18-2009, 10:54   #3 (permalink)
Crazy Poster
Member: 997777
Sonork: 686671
Thanks Meter: 10
sir,
plz.... give me explained diagram ..............
Old 07-18-2009, 10:54   #4 (permalink)
Crazy Poster
Member: 997777
Sonork: 686671
Thanks Meter: 10
3120 c
sir,
Old 07-18-2009, 10:58   #5 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,928
Fhone Type:
Phone Type:
PRESS POWER ON NOW!
Using 06.02.002
Elf2flash 07.14.000
CMT RAW loader...
use proper cable
cmd error is normally cable fault
Old 07-18-2009, 12:36   #6 (permalink)
hajji1's Avatar
Member: 212683
Thanks Meter: 115
Fhone Type:
Phone Type:
PRESS POWER ON NOW!
Using 06.02.002
Elf2flash 07.14.000
CMT RAW loader...
If you use ufs box for connecting then its problem creats or your cable is not working properly ,use 7pins cable and jaf box use your problem solved
Old 07-18-2009, 19:56   #7 (permalink)
Member: 1040038
Thanks Meter: 23
ashad bhai giv me location of flash ic 3120c.........
Old 07-21-2009, 09:47   #8 (permalink)
BCcommunication's Avatar
Member: 76456
Sonork: 100.1678368
Thanks Meter: 60
ur flash ic ok its ur cable problum usb 7pin ok cable
Old 07-21-2009, 10:42   #9 (permalink)
Member: 638003
Thanks Meter: 18
i have try the usb .ufs cable. univesal cable problem is same to also cmt ero
Old 07-21-2009, 10:49   #10 (permalink)
haji rahim's Avatar
Member: 723410
Sonork: 📱 100.1592732
Thanks Meter: 3,374
bro change the cable i had same problem ....
Old 08-03-2010, 10:49   #11 (permalink)
Member: 959567
I have same problem with.i've reball ic flash,rap.but the problem still "phone failed to boot in flash mode CMT....".
any other solution?
All you here an no1 can help.plz help mc_denz BB5KING for (BB5BOX) 1 12-24-2008 13:08
6233 cmt error please help ..::Nokian CareŽ::.. Nokia Hardware & Hardware Repair 2 04-26-2008 17:44
P1i error urgent help plz zigma300 Universalbox 33 11-22-2007 09:56
I need a jobe, who can help plz? faissal30 Off Topic Zone 4 09-21-2007 04:46
Page generated in 0.19086 seconds with 9 queries
