Old 12-07-2004, 20:04   #1 (permalink)
Member: 84978
help, 3210 not charging
i have nokia 3210 and when you plug charger, it will display "Not Charging" pls anyone with solution to this. Both battery and charger are ok.
thanks
Old 12-07-2004, 20:06   #2 (permalink)
Member: 59489
Thanks Meter: 55
Hi,
Did you check your battery pin connectors?
Old 12-08-2004, 13:04   #3 (permalink)
Member: 63385
Thanks Meter: 3
Ey check out with old posts with this ancient Phone... Joke!... Anyway just resolder the battery terminal pins maybe they looseen up...
Chill!...
merulez29
Old 12-08-2004, 13:16   #4 (permalink)
chowdary's Avatar
Member: 91102
Thanks Meter: 34
thanks
when u plug the charger in and it says not charging it means it does recognize that the charger is plugged in there are two things that u can do check the voltage of your charger it should not be higher that 3.6v if the charger is the right voltage3.6v then just replace the battery it will be fine
best regards
Old 09-14-2005, 04:45   #5 (permalink)
silveraxe's Avatar
Member: 166746
Thanks Meter: 86
hi,
bruce said that both the batt and charger are fine,(which means he tested it)
hence, the next problem to troubleshoot is the batt connectors which are 8 / 10 times lose or not making contact.
many thanks
3210--Not Charging!!!pls help topnoyze Nokia Hardware & Hardware Repair 6 10-24-2004 11:35
3210 not charging with car-charge fiZ Nokia Hardware & Hardware Repair 4 10-18-2002 14:52
3210 not charging platte Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 22 02-06-2002 22:40
3210 not charging! aspog Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 10 07-06-2001 08:45
3210 not charging ambot Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 05-06-2001 21:41
Page generated in 0.25167 seconds with 9 queries
