10-09-2009, 12:37 | #1261 (permalink) |
No Life Poster Join Date: Oct 2007 Location: nigeria kano
Member: 599669 Status: Offline Thanks Meter: 115 | |
10-09-2009, 12:37 | #1262 (permalink) | |
No Life Poster Join Date: Dec 2008
Member: 921036 Status: Offline Thanks Meter: 79 | Quote:
10-09-2009, 12:42 | #1263 (permalink) | |
Member: 599669 Status: Offline Thanks Meter: 115 | Quote:
The Following User Says Thank You to Teepat For This Useful Post: |
10-10-2009, 08:12 | #1266 (permalink) | |
Product Supporter Join Date: Sep 2006 Location: Kerala-India Age: 46
Member: 351924 Status: Offline Thanks Meter: 12,469 | Quote:
100%solved ur problem | |
10-10-2009, 15:13 | #1267 (permalink) |
Freak Poster Join Date: Feb 2007 Location: GONDAL
Member: 446289 Status: Offline Thanks Meter: 106 | 2626 vsim line short DEAR I HAVE FACE MANY 2626 ,IN THAT PHONE vsim line hort so sim oes not work all time phone was water damage , pls help meeeeeeeeeeeee |
10-11-2009, 05:45 | #1268 (permalink) | |
No Life Poster Join Date: Sep 2002 Location: KERALA, india Age: 56
Member: 15903 Status: Offline Sonork: 100.1583162 Thanks Meter: 1,046 | Quote:
at sim reader ? in most water tampered case power side may get over heat due to corrosion or impurities etc on the the surface of pcb and beneath of SMDs but this is strange Vsim line alone getting heat ! there is a capasitor in Vsim line whose other side connected to ground just remove that 1 and remove sim emi filter & then test whether the line getting heat ? and post your result good luck NEIL | |
10-11-2009, 10:39 | #1271 (permalink) |
Registered User Join Date: Oct 2009
Member: 1134120 Status: Offline Thanks Meter: 1 | Backing up SIMLOCK data... Setting local mode... Reading IMEI... C:\Program Files\ODEON\JAF\ProgData\355718028131009_CRT_backu p_137249.pm Done! Backup LCK OK! Setting local mode... Reading simlock data... Read SP error! any solution |
10-13-2009, 11:02 | #1274 (permalink) |
No Life Poster Join Date: Jan 2008 Location: sai baba shirdi Age: 44
Member: 670629 Status: Offline Sonork: 100.1590208 Thanks Meter: 431 | Nokia 6210c navigator flash problam -------------------------------------------------------------------------------- Processing file: rm367_05.304_prd_core.fpsx as MCU [BB5,XSR 1.5] size: 74.87 MB Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103 Phone must be switched off. Press phone's POWER button or connect a CHARGER now ! warning: Some new phones consume more power, please connect cable to USB host instead of USB hub. [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic-bc9c110 RAP SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.x] RAP EM1 ID: 00000295 RAP EM2 ID: 00000B22 RAP PUBLIC ID: 0B9000044E920158A56597FF152F41231781A28B RAP ASIC MODE ID: 00 RAP ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE RAP ROM ID: 4B9B75103E691FF8 [ADL] Flashing CMT Update Server Data, ULO: 0x3A40 bytes [ADL] Update Server code succesfully sent to phone [ADL] Flashing CMT Update Server Data, XSR: 0x213ACC bytes [ADL] RAP3NAND sent. [ADL] PASUBTOC sent. [ADL] UPDAPP sent. [ADL] Update Server code succesfully sent to phone [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic-19551aa1 [ADL] Verifying communication to device OK. Total erase size: 64.00 KB CMT ONENAND area [00040000-00082FFF] erased in 0.016 s CMT ONENAND area [00083400-0087FFFF] erased in 0.000 s CMT ONENAND area [00B80000-080FFFFF] erased in 1.031 s Format NAND Flash programming ... Selecting first PAPUB block with matching CMT RootKey CMT PAPUBKEYS, RAP Certificate 107 v1 written. Programming completed in 2 min 35.437 s Processing file: rm367_05.304_prd_v09_01_hispania.fpsx as PPM [BB5,XSR 1.5] size: 36.94 MB Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103 Total erase size: 37.12 MB CMT ONENAND area [053E0000-078FFFFF] erased in 0.328 s Flash programming ... Programming completed in 1 min 7.485 s Processing file: rm367_05.304_prd_vc00_01_Navigator.fpsx as CNT [BB5,XSR 1.5] size: 4.80 KB Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103 Total erase size: 8.00 MB CMT ONENAND area [07900000-080FFFFF] erased in 0.078 s Flash programming ... Programming completed in 0.047 s [ADL] Pooling for ADL device [ADL] Timeout, no device not found. Phone flashing succeeded, but could not verify communication ! [ADL] Pooling for ADL device [ADL] Timeout, no device not found. Flashing terminated with error(s) in 7 min 25.094 s RX Buffer: --------------------------------------------------------PLS HALP |
My nokia hardware repairing technics second part | SHIJILFONOTLY | Nokia Hardware & Hardware Repair | 85 | 08-02-2014 15:52 |
Nokia Hardware Repairing Technics | akashub | Nokia Hardware & Hardware Repair | 1 | 02-25-2010 08:36 |
Nokia Hardware Repairing Technics | Vinci_PL | Nokia Hardware & Hardware Repair | 2 | 09-20-2009 23:50 |
My Nokia Hardware Repair Technic | udayangacnu | Nokia Hardware & Hardware Repair | 0 | 07-06-2009 13:26 |
My 1st hardware repair. | -luigi- | Hardware Repair by brands | 1 | 09-23-2008 00:37 |
