08-24-2009, 10:54 | #1232 (permalink) |
No Life Poster Join Date: Jan 2008 Location: sai baba shirdi Age: 44
Member: 670629 Status: Offline Sonork: 100.1590208 Thanks Meter: 431 | nokia 7210c coontect servers set is same water damej imei is ok spdata ok i writh pm with sx4 but same coofing key is ok---- self test is st faild and keybord test is faild???? pls halp me |
08-28-2009, 20:32 | #1233 (permalink) |
Freak Poster Join Date: Jun 2009
Member: 1057695 Status: Offline Thanks Meter: 29 | dear sir i have 5200 mobile the problem is that it show no network the manual search take 80 second and finally said (no opeartor foun ) i cheak the antenna connector very good i change fem and hot on network ic all that and there is no result i also flash the the phone withe the last flash plz help me and if there is any short instead of change fem and thanks |
09-04-2009, 05:30 | #1234 (permalink) |
No Life Poster Join Date: Apr 2006 Location: APPLE i Center Age: 39
Member: 264667 Status: Offline Sonork: 100.105892 Thanks Meter: 481 | N70 Contact The Retailer this phone have phone start-up fails contact the retailer... i flash so many times,having good Sim lock state,writing good pm.give some heat to PCB also............. Here is HWk info................... Code: MCU SW : V 05wk07v48.1 28-08-07 RM-84 (c) Nokia. APE Core: V 5.0737.3.0.1 13-09-07 RM-84 (C)Nokia APE Var : V 5.0737.3.0.1-28.01 13-09-07 RM-84 (c)Nokia. Prd.Code: 0539240 Bpr.Code: 0536420 Prod.Sn : CPI527473 HW Vers : 7003 APE HW : 256 APE Adsp: 16054 EM RETU : 32 EM TAHVO: 52 RFIC Ver: 150a160e DSP Vers: rolf_05wk07v29p1 LCD Type: 2727964 IMEI : 351862-01-117984-1 SL Serv : SIMLOCK SERVER VERSION 58 SL Conf : 244-07-00000000000 SL Prof : 0000000000000000 SL Count: 00 00 BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN Provider: Nokia Test;Finland |
09-18-2009, 10:21 | #1237 (permalink) | |
No Life Poster Join Date: Jun 2007 Location: INDONESIA
Member: 527741 Status: Offline Thanks Meter: 355 | Quote:
maybe 100% betty ic ................. | |
09-18-2009, 10:29 | #1238 (permalink) | |
Hi friends., Where you are now, we long for you to share your problems in this tread My Nokia Hardware Repairing Technics............... Saludos [email protected] | |
09-19-2009, 11:04 | #1239 (permalink) | |
No Life Poster Join Date: Jan 2008 Location: Kabul Afghanistan
Member: 687312 Status: Offline Thanks Meter: 290 | Quote:
WBR | |
09-20-2009, 08:14 | #1241 (permalink) |
Major Poster Join Date: May 2007
Member: 510973 Status: Offline Thanks Meter: 7 | sir,its my 7610 Init Local Mode Failed IMEI: ---, ASIC: User Area Format Failed 00000000: 00 00 00 00 00 00 00 00 ........ i try to erase flash,full flash,format user area with ufs but i cant a good result.why? 1st Boot: Ok, WD2, UPP: 1081 [Rh-51] [2.0.8.5] 2nd Boot: w3_2nd.fia, Ver: 4.76.0 Fl0: 0x00000000-0x01FFFFFF,00ECDDFE,Sam K8S5615ETA Fl1: 0x02000000-0x03FFFFFF,00ECEEFE,Sam K8S5615ETB Fl2: 0x04000000-0x047FFFFF,00EC2250,Sam K8S6415ETB Algorithm: w3_amd_b.fia, Ver: 4.76.0 Rebooting Mobile its first cheking. pls help in details. |
09-21-2009, 14:53 | #1243 (permalink) | |
No Life Poster Join Date: Sep 2002 Location: KERALA, india Age: 56
Member: 15903 Status: Offline Sonork: 100.1583162 Thanks Meter: 1,046 | Quote:
first check the voltage on the power swich= 1.8 if not ok u have to make a wire print as shown in figure attached in the picture there is yello colored circle. remove that capasitors as shown just scrach there you can see a copper dot make a wire connection from there to swich try this good luck regards, NEIL | |
09-21-2009, 18:15 | #1245 (permalink) | |
l b back soon see this too http://forum.gsmhosting.com/vbb/showthread.php?t=764648 regards, SHIJILFONOTLY&neilthirumuttam Last edited by neilthirumuttam; 09-21-2009 at 18:21. | |
My nokia hardware repairing technics second part | SHIJILFONOTLY | Nokia Hardware & Hardware Repair | 85 | 08-02-2014 15:52 |
Nokia Hardware Repairing Technics | akashub | Nokia Hardware & Hardware Repair | 1 | 02-25-2010 08:36 |
Nokia Hardware Repairing Technics | Vinci_PL | Nokia Hardware & Hardware Repair | 2 | 09-20-2009 23:50 |
My Nokia Hardware Repair Technic | udayangacnu | Nokia Hardware & Hardware Repair | 0 | 07-06-2009 13:26 |
My 1st hardware repair. | -luigi- | Hardware Repair by brands | 1 | 09-23-2008 00:37 |
