02-23-2009, 12:27 | #496 (permalink) | ||
Product Supporter Join Date: Sep 2006 Location: Kerala-India Age: 46
Member: 351924 Status: Offline Thanks Meter: 12,469 | Quote:
whts is the frist condtion ur hand? | ||
02-24-2009, 07:31 | #497 (permalink) | ||
OR REMOVE BLUE MARKED CAPACITOR CHECK ALSO CHARGING CONNECTOR POST RESULT | ||
The Following 4 Users Say Thank You to SHIJILFONOTLY For This Useful Post: |
02-24-2009, 07:45 | #498 (permalink) |
No Life Poster Join Date: Jan 2008 Location: sai baba shirdi Age: 44
Member: 670629 Status: Offline Sonork: 100.1590208 Thanks Meter: 431 | sir jaf bb5 king info JAF box ATmega firmware version: 1B1 Searching for phone ... Phone found on FBUS interface Reading phone info ... SP LOCK status: Block 1: OPEN Type 5 Data: FFFFFF Block 2: OPEN Type 5 Data: FFFFFF Block 3: OPEN Type 5 Data: FFFFFF Block 4: OPEN Type 5 Data: FFFFFF Block 5: OPEN Type 5 Data: FFFFFF Block 6: OPEN Type 5 Data: FFFFFF Block 7: OPEN Type 5 Data: FFFFFF Read Phone Info OK Operation time: 00:12. Successfully done. Thread phone exit. and __________________________________________________ __________________________________________________ __________________________________________________ _____________ give me halp |
02-24-2009, 08:03 | #499 (permalink) | |
i dont understand wht is the problem faced now post software section ur problems http://forum.gsmhosting.com/vbb/showthread.php?t=683634 | |
02-24-2009, 13:26 | #501 (permalink) | ||
remove that ic then check ur phone u must read my question carefull am asking wht is the first condition ur handset? | ||
02-24-2009, 16:36 | #502 (permalink) |
Junior Member Join Date: Dec 2006
Member: 403650 Status: Offline Thanks Meter: 3 | handset - work but was err charge not support, i change betty, usb con with ...(i dont know this element in english) but it still not charge and i think change r2007, and then it didnt power on. |
02-25-2009, 05:47 | #503 (permalink) | |
after betty change phone power on? charger not support VARIABLE RESISTER 47K Btemp REALTED make this problem hardware reapir time u must check normal part first second try high part like retu,avilma,tahvo,betty,rap,omap etc.................................. u have jaf just connect and use check button then post that screen shot some hardwrae problem handsets ufs connecting time show first boot error.BUT JAF IS SOME DIFFERENT POST RESULT | |
02-25-2009, 05:57 | #504 (permalink) |
Freak Poster Join Date: Jul 2006 Location: egypt
Member: 309944 Status: Offline Sonork: 1628185 Thanks Meter: 40 | hello i have problem with nokia 6500s when i turned it on shows only nokia and then it shut down automatic i have flashed it with jaf with highest ver but problem still exist ........... i noticed some thing during flash process *the flash process is very slow * i think it is hardware and i diidnt know where to start thanks for ur help dr.lolo |
02-25-2009, 07:07 | #505 (permalink) |
Member: 351924 Status: Offline Thanks Meter: 12,469 | My other technics with nokia 6500s,5610 etc.....restart solved with out flashing MY OTHER TECHNICS WITH NOKIA 6500S,5610 ETC.....RESTART SOLVED WITH OUT FLASHING MANY NOKIA BB5 PHONES SHOW RESTART,NOKIA LOGO ONLY,TIME AND DATE FIXING TIME RESTARTED,HAND SHAKE TIME RESTARTED ETC............ HOW TO SOLVED THIS PROBLEM VIA JAF WITH OUT FLASHING STEP1-REMOVE BACK COVER AND BATTERY SETP2-FIX 7.1 RESISTER LIKE THIS PICTURE (BSI TO GND FIX THIS 7.1 RESISTER WITH BATTERY) STEP3-INSERT BATTERY WITH HANDSET STEP4-POWER ON THE PHONE STEP5-THIS TIME PHONE SHOW LOCAL MODE STEP6-CONNECT USB CABLE STEP7-OPEN JAF SOFTWARSTEP8-SELECT COMMUNICATION MODE TO USB STEP9-USE FULL FACTORY RESET(FACTORY RESET DONE) STEP10-DISCONNECT PHONE THEN POWER ON WITH OUT SIM STEP11-GO PHONE SETTINGS RESET COMPLETE PHONE UR PROBLEM SOLVED 100%............. TESTED BY ME ABOVE 1000 PHONES CNT FILE MAKE THIS RESTART PROBLEM |
The Following 13 Users Say Thank You to SHIJILFONOTLY For This Useful Post: |
02-25-2009, 07:38 | #507 (permalink) | |
Freak Poster Join Date: May 2006 Location: Ajmer, India Age: 36
Member: 280646 Status: Offline Thanks Meter: 45 | Quote:
i mean why we need to modify battery? is it only for getting local mode? by the way i'll try this trick also. thnx for sharing. | |
The Following User Says Thank You to danish_aziz18 For This Useful Post: |
02-25-2009, 08:07 | #509 (permalink) | |
i think u dont understand my methode | |
My nokia hardware repairing technics second part | SHIJILFONOTLY | Nokia Hardware & Hardware Repair | 85 | 08-02-2014 15:52 |
Nokia Hardware Repairing Technics | akashub | Nokia Hardware & Hardware Repair | 1 | 02-25-2010 08:36 |
Nokia Hardware Repairing Technics | Vinci_PL | Nokia Hardware & Hardware Repair | 2 | 09-20-2009 23:50 |
My Nokia Hardware Repair Technic | udayangacnu | Nokia Hardware & Hardware Repair | 0 | 07-06-2009 13:26 |
My 1st hardware repair. | -luigi- | Hardware Repair by brands | 1 | 09-23-2008 00:37 |
