04-06-2010, 06:27 | #46 (permalink) | |
Product Supporter Join Date: Sep 2006 Location: Kerala-India Age: 46
Member: 351924 Status: Offline Thanks Meter: 12,469 | Quote:
************************************************** ********* how many crystal inside mobile phone PCB? ************************************************** ******* 1)RTC---real time crystal(time contorll) ************************************************** ******* 2)VTCCXO(Voltage Controlled Temperature Compensated Crystal Oscillator)(second local Oscillator) ************************************************** ********** VCTCXO---have a wide range of applications in wireless telecommunications such as portable telephone, VHF/UHF, CATV, instrument for GPS, PLL circuits, AFC circuits, and Radio Frequency (RF) modules. ************************************************** ********* | |
The Following 8 Users Say Thank You to SHIJILFONOTLY For This Useful Post: |
04-08-2010, 04:31 | #47 (permalink) | |
Freak Poster Join Date: Jul 2007 Location: nachna,jaisalmer[rajasthan] Age: 42
Member: 554531 Status: Offline Thanks Meter: 85 | Quote:
i think this is problem of omap ic. shijil sir help plz. | |
04-12-2010, 06:34 | #48 (permalink) |
No Life Poster Join Date: Sep 2007 Location: :::::::EMIRATES:::::::
Member: 591669 Status: Offline Sonork: 110011 Thanks Meter: 687 | 6300 contact service change retu...................same problem.......... self test log : Phone Type: RM-217 SW version: V 07.21 05-11-08 RM-217 (c) Nokia. ID Test name Startup Result 3 EAR_DATA_LOOP Y !NO SIGNAL(06) 12 SIM_CLK_LOOP Y PASSED(00) 13 SIM_IO_CTRL_LOOP Y PASSED(00) 15 SLEEP_X_LOOP Y PASSED(00) 46 UEM_CBUS_IF Y PASSED(00) 7 KEYBOARD_STUCK N PASSED(00) 22 CAMERA_IF N !FAILED(01) 20 BACKUP_BATT N PASSED(00) 21 LPRF_IF N PASSED(00) 44 LPRF_AUDIO_LINES N !NOT EXECUTED(03) 2 CURRENT_CONS N !NOT EXECUTED(03) 42 RADIO Y PASSED(00) 69 BACKLIGHT Y PASSED(00) 33 SIM_LOCK N PASSED(00) 93 SECURITY N PASSED(00) 71 BT_WAKEUP N !NOT EXECUTED(03) 96 HOOKINT N !NOT EXECUTED(03) 88 TAHVOINT Y PASSED(00) |
04-13-2010, 08:12 | #49 (permalink) | |
but one think pcb inner side print broken u faced this same problem | |
05-04-2010, 09:38 | #52 (permalink) |
Member: 591669 Status: Offline Sonork: 110011 Thanks Meter: 687 | 2680s not working lcd................and lcd light keypad light is ok.. change lcd,flat cable and lcd ic............ conecter very clear.............but need lcd way thanks advance |
05-26-2010, 08:40 | #58 (permalink) |
Member: 591669 Status: Offline Sonork: 110011 Thanks Meter: 687 | 7610 only white and off............. here is bus check log: UEM ID: 0044B3BA:2984DA7E ASIC type: 5 UEM Imei: 35000000629653 Flash Imei: 35000000629653 MasterCode: 7051712027 RPL saved to "C:\mobileEx\3.4\data\backup\35000000629653_BA CK.r pl" Phone Type: RH-51 (Nokia 7610) SW Version: V 2006_wk41 11-10-06 RH-51 (c) Nokia. Imei plain: ??????????????-? Cellular System: GSM ASIC ID: 0x1081, type: 5 Language Pack: - not available. Imei plain is invalid !!! Imei net: FFFFFFFFFFFFFF Version: SIMLOCKLIB VERSION 2.29 Counter: 0/3, 0/10 CONFIG_DATA: 5555555555555555 PROFILE_BITS: 0000000000000000 SIMLOCK_DATA corrupted! unlocking log: Imei net: FFFFFFFFFFFFFF Version: SIMLOCKLIB VERSION 2.29 Counter: 0/3, 0/10 CONFIG_DATA: 5555555555555555 PROFILE_BITS: 0000000000000000 SIMLOCK_DATA corrupted! Imei net is empty, process aborted. rpl writing log: Performing Flash Authentication ...OK UEM ID: 0044B3BA:2984DA7E Programming FLASH Imei ... FLASH programmed successfully. Phone Type: RH-51 (Nokia 7610)SW Version: V 2006_wk41 11-10-06 RH-51 (c) Nokia. Imei plain: ??????????????-?Cellular System: GSMASIC ID: 0x1081, type: 5 Language Pack:- not available. Imei plain is invalid !!! Imei net: FFFFFFFFFFFFFFVersion: SIMLOCKLIB VERSION 2.29Counter: 0/3, 0/10 CONFIG_DATA: 5555555555555555PROFILE_BITS: 0000000000000000 SIMLOCK_DATA corrupted! orginal imei:358330006296330 backup:35000000629653_BACK.rpl were is error......pls help |
My Nokia Hardware Repairing Technics | SHIJILFONOTLY | Nokia Hardware & Hardware Repair | 1548 | 11-29-2023 19:50 |
Nokia Hardware Repairing Technics | akashub | Nokia Hardware & Hardware Repair | 1 | 02-25-2010 08:36 |
Nokia Hardware Repairing Technics | Vinci_PL | Nokia Hardware & Hardware Repair | 2 | 09-20-2009 23:50 |
My Nokia Hardware Repair Technic | udayangacnu | Nokia Hardware & Hardware Repair | 0 | 07-06-2009 13:26 |
