Old 02-08-2011, 04:01   #1 (permalink)
Member: 828494
Sonork: kruger selection
Thanks Meter: 18
help x6 vibrate only and will not power on
hi teachers, i have a nokia x6 which only vibrates when you press the power key but will not come on or powered up, plsss what will i do, even after flashing still the same. which i,c is responsible. thanks
The Following User Says Thank You to tol4ray For This Useful Post:
Old 04-22-2011, 22:52   #2 (permalink)
Steamroller's Avatar
Member: 126197
Thanks Meter: 26
at first attempt to power on it only vibrate but if you try again in a few seconds does it vibrate again or you have to remove battery to vibrate again at power on ?
if it vibrate every time you try to power on without replace battery I think it's HW problem (BSI) , if it hangs after first attempt and only if you remove battery and try again it vibrate again I think it's SW problem...
I have one too... mine vibrate once and won't do anything until remove battery...
ANYONE can help me ? please.
Old 04-22-2011, 23:07   #3 (permalink)
Member: 1251348
Sonork: faizan dt
Thanks Meter: 5
rebal rep ic your problem will be solve
Old 04-23-2011, 08:42   #4 (permalink)
mahbubalfa's Avatar
Member: 1003058
Sonork: 100.1589274/mahbubalfa
Thanks Meter: 26,433
1.check bsi line.
2.try to flash same prodact code.
3.rehot rap ic.
try this solution one by one.
Old 04-26-2011, 16:14   #5 (permalink)
riyaz_deva's Avatar
Member: 565996
Thanks Meter: 13
Old 04-26-2011, 19:41   #6 (permalink)
Member: 904809
Sonork: 100.1615464
Thanks Meter: 738
i think first of all, u need to flash yr phone with eno files,,
and then reflash yr phone with latest firmware and same product,
post result,,
if still,,check hardware
reball rap,,also check, boot ic, bsi line,,
plzzzzzzz must post yr phone flashing logs with self test and info,if possible
The Following User Says Thank You to alkhaleejmobile For This Useful Post:
Old 05-02-2011, 07:43   #7 (permalink)
Member: 126197
Thanks Meter: 26
x6 only vibrate
so far I try to flash it several times including flash with ENO file or USB flashing with cyclone and mxkey
phone was v30.0.3 when it came to me but I can't find sw with same product code v30.0.0 or 31.0.4 so I reflash it with 30.0.3 , same problem . Then I try 31.0.4 , nothnig new...
then ENO , nothing new
then USB , nothnig new
Checked BSI - is OK
Checked + Lines - all ok
Try other batteryes - nothnig new
Checked current consumption when power up - seems to be the same as a good working set
PCB is looking good , no wather damage , no torsion , set looks as new...
try to remove camera like some peoples say on this forum - still only vibrate
try other LCD like some peoples say on this forum - still only vibrate
try to power up only with lcd connected - still only vibrate
the set is able to enter TEST or LOCAL mode only with box , flash seems to be ok , no error
the set won't power up when charger is inserted
at power up it vibrate BUT it won't vibrate if i try power up again untill I remove and reinsert battery ! (I tryed with a good one to isolate BSI and it vibrate every time I press power on so I eliminate BSI problem like that)
now... if someone has an answer to this problem is welcome to help !
here is the log : first one is info and shows actual status of the phone
and second is more complete and shows initial status , flashing logs more status etc
Old 08-04-2011, 15:06   #8 (permalink)
Member: 295112
Thanks Meter: 31
check this solution...good luck
The Following User Says Thank You to hack24_gsm For This Useful Post:
Old 08-04-2011, 15:26   #9 (permalink)
Member: 126197
Thanks Meter: 26
for me not working... I will check again BSI , Thank you for your intrest
problem still open...
Old 08-08-2011, 12:02   #10 (permalink)
Member: 33954
Thanks Meter: 10
same problem here any help is welcome
Checked BSI - is OK
i have same problem here any solution my phone power on with light after vibra but after few seconds turn off
Old 08-19-2011, 04:27   #11 (permalink)
MUTUAL's Avatar
Member: 160928
Thanks Meter: 338
this jumper is not working
Old 09-26-2011, 22:08   #12 (permalink)
pachicoo's Avatar
Member: 591052
Sonork: 100.1592747
Thanks Meter: 95
bsi line not present i tried this jumper but not working still any other saltuion.
The Following User Says Thank You to pachicoo For This Useful Post:
Old 09-28-2011, 23:20   #13 (permalink)
Member: 1621333
are ther soltion by sowft war
Old 01-05-2012, 18:30   #14 (permalink)
Member: 946381
Thanks Meter: 150
x6 vibration only when turn on-but in ufs set on and info ok-details as below
MCU SW : V ICPR72_10w42.1.2 17-03-11 RM-559 (c) Nokia
APE Core: V 32.0.002
APE Var : V 32.0.002V 32.0.002 V 32.0.002
Product : Nokia X6-00
Prd.Code: 0580466
Bpr.Code: 0589312
Prod.Sn : CWD723985
HW Vers : 1123
APE HW : 256
APE Adsp: 256
EM VILMA: 16
EM BETTY: 22
RFIC Ver: |Vapaus_5.1 | Aura_?.?
DSP Vers: ICPR72_10w33
WLAN Id : A0 4E 04 13 66 0A
IMEI : 352006-04-543474-4
SL Serv : SIMLOCK SERVER
SL Conf : 244-07-00000000000
SL Prof : 0000000000000000
SL Count: 00 00
BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
Provider: Nokia Test;Finland
set on menu come when connect to ufs-so i think it due to betty or avilma problem.customer set it occured during charging-so i think it betty problem.
am i right?
can i replace it from n73?
Old 01-10-2012, 19:29   #15 (permalink)
Crazy Poster
Member: 584215
Sonork: 9831735786
Thanks Meter: 14
Cool
[IMG]http://x6bsi line 10000% working test by me
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
IR between 6150 and IBM TP 600 favdijck Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-15-2011 13:08
Page generated in 0.29601 seconds with 10 queries
