Old 06-18-2009, 07:33   #1 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Thanks Meter: 12,469
My nokia hardware repairing technics second part
MY NOKIA HARDWARE REPAIRING TECHNICS SECOND PART
NOKIA DCT4+ HANDSETS POWER ON WITH FBUS CABLE(WITH BOXS)
FLASHING,UNLOCKING,FULL FACTORY WORKING WELL
BUT NOT POWER ON WITH BATTERY BECOZ SECOND LOACL CRYSTAL OSILLATION WORKING NOT PROPER
JUST CHANGE THIS CRYSTAL PROBLME 100%SOLVED
CHECKING STEP BY STEP
1)CHANGE BATTERY
2)CHECK BATTERY BSI CONNECTOR
3)CHECK BSI RESISTER
4)CHANGE CRYSTAL
PROBLEM SAME FACED?
5)CHECK UPP
BUT UPP CHANCE ONLY 40%.
MORE UPDATE COMING SOON........
1650
1680
2330
2630,2600C,5000
2660,2670
2680S
The Following 76 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 06-18-2009, 07:37   #2 (permalink)
akhil_bbsr's Avatar
Member: 271478
Sonork: 1590868
Thanks Meter: 1,070
vary nice ...thnx lots .u both
The Following User Says Thank You to akhil_bbsr For This Useful Post:
Old 06-18-2009, 07:53   #3 (permalink)
s.s.s.s.'s Avatar
Member: 988641
Sonork: sanjay chaudhary
Thanks Meter: 342
bro,
again good job keep it up. we waiting for u to see as our new moderater.........
The Following User Says Thank You to s.s.s.s. For This Useful Post:
Old 06-19-2009, 10:48   #4 (permalink)
NIMESHFONOTLY's Avatar
Member: 760274
Thanks Meter: 146
very nice and valuable post........thanks........
Old 06-19-2009, 11:08   #5 (permalink)
gsmshare's Avatar
Member: 429569
Thanks Meter: 1,543
yes really ood work,,u always hard work,,for that THANKS MAN
hope u more share more solution,,,,
The Following User Says Thank You to gsmshare For This Useful Post:
Old 06-19-2009, 12:01   #6 (permalink)
vishal123123's Avatar
Member: 463150
Thanks Meter: 91
well i will test and post result soon....................
The Following User Says Thank You to vishal123123 For This Useful Post:
Old 06-19-2009, 13:28   #7 (permalink)
jaleelkuttikkar's Avatar
Member: 591669
Sonork: 110011
Thanks Meter: 687
nokia 5800 water damage!no short in board.,conect in jaf sync error! sir my next cheack in were starting?pls ..............help
The Following User Says Thank You to jaleelkuttikkar For This Useful Post:
Old 06-22-2009, 08:16   #8 (permalink)
Member: 351924
Study this details then easy to find schecmatics
a/d-converter---anologue to digitel converter
adsp------------application dps
asic------------application specific interface circuit
bb--------------baseband
bsi-------------battery size indicator
cbus------------mcu controlled serial bus connected to upp,wd2,uem and zocus
cpu-------------central processing unit
dbus------------dsp controlled serial bus connected between upp,wd2 and helgo
dsp-------------digitel signal processor
emi-------------electromagnetic interference
esd-------------electrostatic discharge
i/o-------------input/output
ichar-----------charger current
mcu-------------micro controller unit
omap------------operation,maintrnance and administration part
purx------------power up reset
rf--------------radio frequency
rtc-------------real time clock
rx--------------radio receviver
saram-----------single access ram
sdram-----------synchronous dynamic random access memory
sid-------------security id
smps------------switch mode power supply
sram------------static random access memory
tcxo------------temerature controlled ascillator
tiku------------finnish for chip,successor of the upp
uem-------------universal energy management chip
upp-------------universal phone processor
vbatt-----------battery voltage
vchar-----------charger voltage
vco-------------voltage controlled oscillator
vctcxo----------voltage controlled temperature compensated crystal oscillator
vcxo------------voltage contorlled crystal oscillator
vpp-------------peak to peak voltage
wd--------------watchdog
zocus-----------current sensor(used to monitor the current flow to and from the battery
The Following 17 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 06-22-2009, 09:07   #9 (permalink)
Member: 165303
Sonork: 100.1580123
Thanks Meter: 57
vey use full infoo................................
The Following User Says Thank You to nvad For This Useful Post:
Old 06-22-2009, 09:57   #10 (permalink)
arifksarmali's Avatar
Member: 259084
Thanks Meter: 232
neeed help
[code]Version Info:
MCU SW version: V 07.21 05-11-08 RM-237 (c) Nokia.
HW version: 2008
RFIC version: 17211721
DSP version: ICPR61_08w10
PPM version: V 07.21 05-11-08 RM-237 (c) Nokia. MR
Retu version: 32
Tahvo version: 53
Product Info:
Production serial number: 7G1985250
Product code: 0514950
Module code: 0203291
Basic production code: 0542523
Serial Numbers:
IMEI plain: 359343xxxxxxxxx
IMEI spare to net: 3A 95 43 03 52 04 62 05
IMEI SV to net: 33 95 43 03 52 04 62 25 F5
Other Info:
Model : Nokia 3110c (Classic Phone)
BSI: 4.3 KOhm
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
[code]
The Following User Says Thank You to arifksarmali For This Useful Post:
Old 06-22-2009, 10:07   #11 (permalink)
Member: 351924
Originally Posted by arifksarmali View Post
[code]Version Info:
HW version: 2008
Retu version: 32
Tahvo version: 53
Product Info:
Serial Numbers:
Other Info:
BSI: 4.3 KOhm
Counter: 0/3, 0/10
[code]
brother,wht problem u faced now
wht is the set condition
The Following 2 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 06-22-2009, 13:15   #12 (permalink)
Member: 554531
Thanks Meter: 85
nokia 3110c flashing complete with ufs jaf and mxkey but not power on. voltage on power switch is ok. ?
The Following User Says Thank You to dilipnachna For This Useful Post:
Old 06-22-2009, 13:31   #13 (permalink)
Member: 1040615
Thanks Meter: 23
Thanks Sir, Its very Useful Information
The Following User Says Thank You to pradipbarua For This Useful Post:
Old 06-23-2009, 05:21   #14 (permalink)
Member: 351924
bro,post flashing log
post result
The Following User Says Thank You to SHIJILFONOTLY For This Useful Post:
Old 06-24-2009, 06:02   #15 (permalink)
Member: 259084
Thanks Meter: 232
sir i have this 3110c and it is simlock and security test ok but cant do sx4 in mx key and jaf also pls what i do i have full rpl backup of 20 kb pls
The Following 2 Users Say Thank You to arifksarmali For This Useful Post:
My Nokia Hardware Repairing Technics SHIJILFONOTLY Nokia Hardware & Hardware Repair 1548 11-29-2023 19:50
Nokia Hardware Repairing Technics akashub Nokia Hardware & Hardware Repair 1 02-25-2010 08:36
Nokia Hardware Repairing Technics Vinci_PL Nokia Hardware & Hardware Repair 2 09-20-2009 23:50
My Nokia Hardware Repair Technic udayangacnu Nokia Hardware & Hardware Repair 0 07-06-2009 13:26
Page generated in 0.25561 seconds with 10 queries
