Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Sharp
Old 08-23-2006, 16:25   #76 (permalink)
Member: 335985
Originally Posted by Platijet View Post
no you can't.read 1st post-cable is same with gx15/gx25
I've read it twice. However, what is the diffrent between the "simple" cable which You explained on first 1st post and one which I want to use.
Don't push me, I'm n00b here.
Pisiukas
The Following User Says Thank You to pisiukas For This Useful Post:
Old 08-30-2006, 19:56   #77 (permalink)
Member: 185111
Hello
I have original cable for NEC E228. Will is work??
Old 09-01-2006, 06:05   #78 (permalink)
Member: 341086
nobody says that external power needed for this cable sharp 905sh
can i unlock sharp 703?
Old 10-11-2006, 05:34   #79 (permalink)
Member: 368181
As regards to info below, if I make the cable connection in pic one will I be able to use it as a data cable for my sharp Gx17 please.... thanks...
GX15-GX17-GX25:
only USB cable,not COM.for data and unlock use sipmle original USB cable.
FOR FLASH YOU NEED NEC 3G CABLE OR USB CABLE WITH CHARGING FUNCTION(see pic1).
caution:usually you can't use flash cable for unlock.
Old 10-15-2006, 14:47   #80 (permalink)
Member: 237245
Cruiser
hi,
Can I unlock a gx-17 with a cruiser cable?if yes what software should I use and which drivers?
thks
Old 10-16-2006, 04:05   #81 (permalink)
baboom's Avatar
Member: 59935
Thanks Meter: 131
Originally Posted by kubunt View Post
hi,
thks
Do you try to connect the GX 17 with a "cruiser cable" ????
Which connector you will use ?????
Old 10-16-2006, 11:48   #82 (permalink)
realmadrid's Avatar
Member: 201648
Thanks Meter: 19
any one chow us the cable for sharp 802
Old 10-16-2006, 12:44   #83 (permalink)
Platijet's Avatar
Member: 26279
Thanks Meter: 274
read 1st post...............
About Sharp 802SH Unlocking with Cruiser NeTRaW Cruiser Suite 21 05-09-2006 10:56
about Sharp 3G Tool v1.1, EUROPE and CHINESE Flash files in Support Area UnlockerPT SonyEricsson (USB-Smart) 7 09-16-2005 15:24
Question about Sharp 902 franklee628 Cruiser Suite 0 06-14-2005 02:00
i havequestion about sharp gx10i's IrDa Brandon_lee Sharp 0 05-01-2005 12:27
New site about Sharp (tools, unlocking, flashing) FreaX Sharp 132 03-23-2005 13:56
Page generated in 0.17989 seconds with 10 queries
