Go Back   GSM-Forum > Non GSM/Mobile Related Forums > Bluetooth > Bluetooth-Software
Old 12-21-2009, 15:48   #1 (permalink)
SLB
Member: 104816
Toshiba Bluetooth Stack Version 7.10.04 is now available
hey all,
on Toshiba's support site I found this version running well on Seven.
CU
Steve
The Following User Says Thank You to SLB For This Useful Post:
Old 12-21-2009, 19:45   #2 (permalink)
Nasir Mobiles's Avatar
Member: 355782
Thanks Meter: 1,265
where is link????? please give a working link.
Old 12-21-2009, 21:07   #3 (permalink)
Member: 887480
Thanks Meter: 2
I found it here
Windows 2000 / Windows XP / Windows VISTA / Windows 7 x32/x64
7.10.04 x32 (x86 ) & 7.10.04 x64
Haven't tried jet ...
I'm using 6.2.1.500, later when finish downloading will update
The Following User Says Thank You to Avram83 For This Useful Post:
Old 12-21-2009, 21:18   #4 (permalink)
Member: 887480
Thanks Meter: 2
Edit:
These stacks are for TOSHIBA notebooks only !
Simply wont work on other BT devices...
If you got the spare time try it,
maybe works for some other BT-s...
On mine wont...
Old 12-22-2009, 19:56   #5 (permalink)
Member: 1143610
is there a "cure" ?
Old 01-02-2010, 05:19   #6 (permalink)
Member: 726732
Does anybody have "remedy" for that version ?
Old 01-27-2010, 20:05   #7 (permalink)
Gix
Crazy Poster
Member: 112022
Thanks Meter: 125
Finnaly found a way to make a "cure"
The Following 17 Users Say Thank You to Gix For This Useful Post:
Old 02-01-2010, 03:26   #8 (permalink)
Member: 726732
Works fine.
Many thanks to Gix !
Old 02-16-2010, 05:50   #10 (permalink)
Member: 886284
Anyone get alot of noise inserted on the bt headset transmit end? I get that when I use it, then leave the computer on for 24 hours.
Old 03-04-2010, 15:37   #11 (permalink)
Member: 1249743
x64 drivers
Hi, do you know if the patches work for the x64 version??
Old 03-04-2010, 15:43   #12 (permalink)
Member: 1249743
x64 drivers
Old 03-27-2010, 19:19   #13 (permalink)
Member: 1267962
Works great, thanks.
Old 06-10-2010, 07:52   #14 (permalink)
Member: 1321729
Worked great on Win 7 x64 Pro.
Adapter is Dell 360 BT module (Manufacturerd by CSR)
Old 06-10-2010, 08:22   #15 (permalink)
Member: 1321729
Just for clarification, the version installed was 7.10.12
[IMG] code is Off
Toshiba Bluetooth Stack Version 7.00.05 Tseng Bluetooth-Software 16 10-31-2010 22:32
Now Available: Toshiba Bluetooth Stack Version 6.40.00 armond Bluetooth-Software 21 02-02-2010 16:35
Toshiba Bluetooth Stack Version 7.00.16 Tseng Bluetooth-Software 1 12-18-2009 04:18
Toshiba Bluetooth Stack Version 7.00.10 Tseng Bluetooth-Software 8 11-21-2009 03:45
Toshiba Bluetooth Stack 5.10.06 available ulysse Bluetooth-Software 19 06-08-2009 08:10
Page generated in 0.20966 seconds with 10 queries
