Go Back   GSM-Forum > Non GSM/Mobile Related Forums > Bluetooth > Bluetooth-Software
Old 05-01-2006, 06:26   #1 (permalink)
Member: 265040
Thanks Meter: 6
patch of the IVT bluesoleil 2.1.3.0 VoIP Release 060429
patch was only tested with my bt devices. so i wish u can be fortunately enough to use this patch....if u r the unlucky guy,so, plz tell me.
this is the link to download the original software :
http://www.bluesoleil.com/download/d...luesoleil_voip
and this is the release note and changelogs:
http://www.bluesoleil.com/download/i...p_release_note
The following significant changes have been made to BlueSoleil 2.1.3 VoIP since it is build 2.1.2 VoIP:
Automatically show ever-connected devices on UI after BlueSoleil starts. //good news...
Bug fix: DUN fails on windows 2000 OS.
Bug fix: BlueSoleil does not support Nokia new phones (e.g. N series).
Bug fix: For some Bluetooth devices, BlueSoleil still runs in evaluation mode after registering a license key.
Bug fix: PAN cannot find physical network cards on some machines.
Bug fix: "End program -IVT Corporation..." dialog is shown when the system is being shut down.
Bug fix: BlueSoleil cannot run when there is no taskbar.
Bug fix: When "Welcome to Bluetooth" is shown at the first run, BlueSoleil behaves abnormally after standby/resume the system.
Bug fix: When PC suite 6.7 is installed and BlueSoleil is not set to auto-run on startup, more than one instance of BlueSoleil can run at the same time.
Bug fix: On media center OS, if there are too many com ports, LAP does not work.
The Following User Says Thank You to lidouf For This Useful Post:
Old 05-01-2006, 08:57   #2 (permalink)
Member: 267626
I dont know how to thank you! I really want Bluesoleil VOIP version, I cant seem to buy from their site. I even offered to pay more for their service, they turned me down. This is really a life saver. Thanks
Old 05-01-2006, 16:22   #3 (permalink)
Member: 237093
Tanks, its works great!!!
Old 05-01-2006, 21:12   #4 (permalink)
Member: 269097
Thank you very much!
I tried your other patch of bluesoleil 2.1.2.0 VoIP and it works also great!
Maybe we can get more patches for future releases?
Bluesoleil works great with my CSR-Dongle and Plantronics Pulsar 590a Headset.
With WIDCOMM (even with 5.0.1.2500) I was not successful.
Thanks again!
Old 05-03-2006, 01:01   #5 (permalink)
Member: 68768
2 lidouf
Is it pissible to use your patch for NON VoIP version?
Old 05-03-2006, 01:06   #6 (permalink)
Member: 68768
this is not a patch. it's only a patched file?
Old 05-03-2006, 05:34   #7 (permalink)
Amir-SkillZ's Avatar
Member: 91045
Thanks Meter: 8,696
Patched Licensed File Actually
Can i use By ISSC harlos with it .???...At now i am using Widcomm soft
Reply Fast Any one?
Old 05-03-2006, 05:57   #8 (permalink)
Member: 265040
Thanks Meter: 6
i'm poor in English..so the title of this post should be some confusion..I'm sorry for this...I restate as the following:
->this is only a cracked(patched) file(i wanna make a keygen at first, but its algorithm is some complex, so i give up this idea)..
->i didn't test on NON VoIP version..but I guess it can work fine..
->it's ok for ISSC dongle, for mine is.
Old 05-03-2006, 13:17   #9 (permalink)
Member: 91045
Thanks Meter: 8,696
thankx Lidouf So Cofirmation
Old 05-03-2006, 14:22   #10 (permalink)
Member: 104980
Thansk works like a charm and atleast it has good a2dp support *cought* widcomm *cough*.
Old 05-03-2006, 14:32   #11 (permalink)
Member: 104980
C'mon if you want to use cracked software use it but don't give some bogus reason... You can buy the VoIP version of their site (just click on Store) for $15.
Old 05-03-2006, 18:16   #12 (permalink)
Member: 262949
thanks work much much better than widcomm
Old 05-03-2006, 19:49   #13 (permalink)
Member: 267626
I understand your skepticism, but please do not jump on to conclusion right away. Please go to Bluesoleil's forum, and check out my thread with the admin. Their software simply refuse to allow me into the "Purchase Page", stating that my bluetooth device is "incompatible". WHICH is total bull-crap, since the trial version worked perfectly.
So yeah, before you accuse me of stealing, check your facts first. BTW, even with the patched version, I did send $15 cheque to Bluesoleil China.
Old 05-06-2006, 18:31   #14 (permalink)
Member: 246984
Thanks for the patch, for some reason tho, when I copy over the patched file and run the VOIP plugin, it says voip not suppored by this version...did I do something wrong?
Thanks again
Old 05-09-2006, 00:58   #15 (permalink)
Member: 273183
I cannot install these patch. please they help me (Guidance)
[IMG] code is Off
v3.2 revision 3.0, Public-Release not work in bb5 model prakashmborana MXKEY Nokia Flasher and Unlocker (by Alim Hape) 20 07-16-2009 04:42
MXKEY v3.2 revision 3.0, Public-Release MANOLE Service Products News & Updates 0 07-01-2009 20:22
QuickOffice 2.1.3.0 Krogoth Nokia Multimedia 10 09-09-2007 13:52
Patch of IVT bluesoleil 2.1.2.0 voip-does anyone need? lidouf Bluetooth-Software 13 07-14-2007 08:26
IVT Bluesoleil 2.0 EDR Hodo Bluetooth-Software 9 01-07-2006 18:12
Page generated in 0.21469 seconds with 10 queries
