05-25-2006, 12:43 | #32 (permalink) |
Junior Member Join Date: Apr 2006
Member: 265040 Status: Offline Thanks Meter: 6 | rst0x0d, That's all right now. I was very angry at first for your assumption. But It's ok now. I'm very glad to hear any criticism on the warez itself, But plz don't assume that I have bad morality. Thanks superfrog's explanation for this question and the effective solution. |
05-25-2006, 14:41 | #33 (permalink) |
Junior Member Join Date: May 2006
Member: 282343 Status: Offline Thanks Meter: 0 | bluesoleil w/voip causing avg/outlook error. please advise when i open the bluesoleil voip using the patch and have outlook open i get an error that says cannot load avgxchange32.dll (exact filename not sure off) this message pops up as an outlook error. this box will not go away and says i should try detect and repair... i did that and same thing when reopening BS voip. when i close BS voip my computer returns to almost normal. after reboot back to normal. running 2000 advanced server and runs like a tank normally. any advice or suggestions as to what prob might be? previously had basic BS that came with dongle and that works no prob. i hope someone is still monitoring this. maybe has straight key or key gen by now? woodalia |
05-25-2006, 14:50 | #34 (permalink) |
Member: 282343 Status: Offline Thanks Meter: 0 | Forgot something. Potentially very stupid question why are there 3 rar files for patch? which to use? all 3? how? am i missing something? i believe i extracted 1st and replaced exe in /ivt/bluesoleil... hope someone out there can explain. maybe this is why i had above problems with avg/outook. woodalia |
05-27-2006, 01:14 | #35 (permalink) |
Member: 283444 Status: Offline Thanks Meter: 0 | Yes, I would also like help knowing what the 3 individual .rar files are for and which ones they replace in the folder, and how they are renamed. It will be awesome to get this sorted as BlueSoleil sure don't make it easy to purchase their products. Thanks in advance! |
05-29-2006, 17:16 | #38 (permalink) |
Member: 283444 Status: Offline Thanks Meter: 0 | Thanks so much, this rocks. (to any new people, you need to download the files, unzip them and install the new files into the existing bluesoleil directory, overwriting any files that may have the same name) |
06-01-2006, 20:32 | #40 (permalink) |
Member: 281789 Status: Offline Thanks Meter: 0 | Alright, in my quest to enabled headset operation on my dongle I tried bluesoliel. 1. Found clean system 2. Installed bluesoliel software 2b. copied over the new .exe file 3. modifed inf file in driver directory of install to include my vid&pid 4. modifed ini file to include my vid&pid in an [HWxx] section 5. Plugged in device and installed driver (worked ok and ID'd as Broadcom 2035 in Dev manager) 6. ran bluesoliel Bluesoliel environment opened and paused for a bit, then displayed that it could not find any devices. Grumble...this dongle was not worth the $10... |
06-01-2006, 20:38 | #41 (permalink) | |
Junior Member Join Date: Jun 2006
Member: 286718 Status: Offline Thanks Meter: 0 | Quote:
i've got the same problem... please send me first file... [email protected] | |
06-02-2006, 01:41 | #42 (permalink) |
Member: 265040 Status: Offline Thanks Meter: 6 | http://www.moshoo.com/bbs/read.php?tid-180.html maybe something error... anyone can't dl here can also dl from this page. But u must register & post a reply then u can dl... |
06-19-2006, 00:13 | #44 (permalink) | |
Member: 296270 Status: Offline Thanks Meter: 0 | Quote:
v3.2 revision 3.0, Public-Release not work in bb5 model | prakashmborana | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 20 | 07-16-2009 04:42 |
MXKEY v3.2 revision 3.0, Public-Release | MANOLE | Service Products News & Updates | 0 | 07-01-2009 20:22 |
QuickOffice 2.1.3.0 | Krogoth | Nokia Multimedia | 10 | 09-09-2007 13:52 |
Patch of IVT bluesoleil 2.1.2.0 voip-does anyone need? | lidouf | Bluetooth-Software | 13 | 07-14-2007 08:26 |
IVT Bluesoleil 2.0 EDR | Hodo | Bluetooth-Software | 9 | 01-07-2006 18:12 |
