04-20-2006, 15:42 | #1 (permalink) |
Freak Poster Join Date: Aug 2005 Location: turkey Age: 51
Member: 174769 Status: Offline Thanks Meter: 19 | kzf 1.8e does not work with hwk modul pls help. Last edited by erkan06us; 04-20-2006 at 16:19. |
04-20-2006, 19:41 | #2 (permalink) |
No Life Poster Join Date: Sep 2003 Location: Ukraine Age: 51
Member: 40400 Status: Offline Thanks Meter: 1,250 | Remove HWK from your box and update firmware with UFS3Tool , then connect HWK and use HWKTools for update ( repair) your HWK . I think this steps can help you . |
04-20-2006, 22:18 | #3 (permalink) |
Freak Poster Join Date: Jun 2003 Location: egypt
Member: 31136 Status: Offline Thanks Meter: 97 | To make your UFS Open UFS_Maintenance Conect-Boot UFS & Get Info-Update UFx Firmware and put atach "1" after that push Initialise UFx NVM close Open UFS3Tools Conect- Put to update Firmware and eeprom in V2.5 and push Fix&Updare Close Open UFS_DCTx_1.3J Conect-it ask you yo update push "yes" conect- you'll see: UFxBoot V2.2 (c) SarasSoft 2003. Id: 62 CF 1 7 UFS_USB V2.6 (c) SarasSoft 2005. S/n: xxxxx (xxxxx - is number of your box) Licence : True Features: 00000001 after that you'll see mistake -32, you need to push ok push update firmware and put this file "Reg.fbi", and in C:\Program Files\Nokia\Phenix it was created xxxxx.reg (xxxxx - is number of your box) Open UFSTools-FBI Calculator- put file "xxxxx.reg" (xxxxx - is number of your box) you need to save in xxxxx.fbi C:\Program Files\Nokia\Phenix in (xxxxx - is number of your box) Open UFS_DCTx_1.3J Conect, you'll see mistake, push ok or yes push update firmware and push file xxxxx.fbi at C:\Program Files\Nokia\Phenix you'll see: UFxBoot V2.2 (c) SarasSoft 2003. Id: 62 CF 1 7 UFS_USB V2.6 (c) SarasSoft 2005. S/n: xxxxx (xxxxx - is number of your box) Licence : True Features: 00000001 BOX_KEY Updated then use HWKtool to active your hwk goooood luck |
04-21-2006, 09:20 | #6 (permalink) | |
Member: 174769 Status: Offline Thanks Meter: 19 | Quote:
i tried ur method.still same problem! | |
04-21-2006, 09:27 | #7 (permalink) | |
04-21-2006, 09:44 | #8 (permalink) |
Member: 174769 Status: Offline Thanks Meter: 19 | i ve dctx 1.3I and i tried with this.and also i didn't see mistake-32 .there was no created a reg.fbi file in c/programfiles/nokia/phoenix.i had to stopped that step. Last edited by erkan06us; 04-21-2006 at 10:17. |
04-21-2006, 16:04 | #9 (permalink) |
Member: 40400 Status: Offline Thanks Meter: 1,250 | Use UFS3Tool with this options. ( press ''connect , select '' Write firmware'' , ''write eprom'' , ''write 93c46'' then press ''Fix and update '' ) Second step : You must calculate codes for your SN . You can use UFS3Tool also : after calculation press ''write eprom'' ONLY (not '' Write firmware'' ,''write 93c46'' ) and press ''Fix and update '' . Then use ''HWK Tool'' for repair HWK . Try this and write here what happened . You have very strange HWK ... HID with first digit like 00000.... - its for emulator of HWK . |
04-21-2006, 18:20 | #10 (permalink) | |
Member: 31136 Status: Offline Thanks Meter: 97 | Quote:
04-28-2006, 11:47 | #11 (permalink) | |
YesSim does not work with iphone 3G? i tried every version lost signal!!! pls respond | virtue | YESSIM | 2 | 01-01-2009 01:56 |
Help!!!Search in Macroreader does not work with updating MC60!!! | asdv | E-Gold Based Phones | 0 | 07-03-2005 11:47 |
N500 works with Airtel( 1800mhz) but does not work with BPL,Orarange( 900 mhz)service | sunil9200 | VLSI, Conexant, Skyworks and Old Models | 1 | 03-01-2004 09:32 |
wulfgang does not work with normal data cable | tecra | Panasonic | 2 | 05-17-2001 11:10 |
