Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 04-22-2016, 22:43   #1 (permalink)
ahmed koukou's Avatar
Member: 1981679
Thanks Meter: 86
Sony z2 only red light flashing solution.
Make this jumper tested 100%.
The Following 6 Users Say Thank You to ahmed koukou For This Useful Post:
Old 04-24-2016, 09:48   #2 (permalink)
Member: 48933
Thanks Meter: 104
can you pls repost picture?
wbr
Old 04-24-2016, 23:37   #3 (permalink)
Member: 1981679
Thanks Meter: 86
أرسلت من D6503 بإستخدام تاباتلك
The Following 11 Users Say Thank You to ahmed koukou For This Useful Post:
Old 05-12-2016, 14:45   #4 (permalink)
Member: 1561570
Thanks Meter: 4
tnx bro...i have 2 xperia z2 redlight only...i apply the jumper now its working,,,
Old 05-12-2016, 17:50   #5 (permalink)
Member: 1981679
Thanks Meter: 86
Know and let people know this is called helpful koukou
أرسلت من C6903 بإستخدام تاباتلك
The Following User Says Thank You to ahmed koukou For This Useful Post:
Old 06-01-2016, 21:15   #6 (permalink)
Member: 222721
hello, can you please help?
same problem, only red light, 3 red blinks when trying to turn on.
first i tried other software solutions from another forum, no chance.
then i tried hardware solutions. with the battery disconnected, and plugged the phone in charger. it showed on screen battery icon and charging for a few seconds and then it restarted. and nothing more.
then i tried your solution but i think i made a mistake. the phone will not blink 3 times red when battery connected and trying power button like before. and with battery disconnected, charger connected, lcd lights up but nothing is shown on screen now. i don't know what to do
Old 06-01-2016, 22:16   #7 (permalink)
Member: 1981679
Thanks Meter: 86
Hello,
Can you provide me a pictures of motherboard and phone when it led up.
Regards.AHMED KOUKOU
Old 06-02-2016, 01:48   #8 (permalink)
Member: 1981679
Thanks Meter: 86
Oops,disconnect battery tell you post the pictures.
Do this fast as fast not damage the phone because it seems it is a short between gnd and vbat.
Old 06-02-2016, 22:11   #9 (permalink)
jinist.smith's Avatar
Member: 2312863
Sonork: Not right now
Thanks Meter: 29
Red face
After doing this battery is heating
The Following 4 Users Say Thank You to jinist.smith For This Useful Post:
Old 06-02-2016, 23:20   #10 (permalink)
Member: 1981679
Thanks Meter: 86
Hello,
Upload pictures of your motherboard with jumper.
Your phone now have a short circuit remove the jumper after take pictures.
Regards,
AHMED KOUKOU
Old 06-03-2016, 18:36   #11 (permalink)
Member: 222721
sorry for bad image. this is the best i could take with another phone
at first try i didn't solder only the big contact, there was no connection with the small capacitor.
i had the connection redone by a professional guy and this is how it looks now
phone is not starting, when plugged in computer, pc companion recognizes the phone and gives me a message to disconnect and power on the phone but that doesn't help.
also, when holding power and volume up, there is no reset, it does not vibrate 3 times
i'm not sure why the image is not loading, here is the link http://imgur.com/RqMwwcd
Old 06-03-2016, 19:07   #12 (permalink)
Member: 222721
<< more info >>
when plugged in the computer, nothing happens for about 1 minute, after that the lcd backlight lights up, but without image and a blink of red led lights up behind the speaker. after this the pc tries to install MTP USB Device, another 3-4 seconds and the phone restarts and the process begins again... lcd backlight lighting up, no image on display, red led, driver install in pc
the only way i can stop this process is to unplug the battery connector from the motherboard
Old 06-03-2016, 19:11   #13 (permalink)
Member: 1981679
Thanks Meter: 86
It maybe battery voltage is too low.
Old 06-03-2016, 19:43   #14 (permalink)
Member: 222721
now it has been about 1 hour charging, still no response.
with battery disconnected from motherboard i tried to flash a ftf file and flashtool did it's job very well. so the software can be changed.
but still no response when trying to power on
Old 06-03-2016, 19:55   #15 (permalink)
Member: 1981679
Thanks Meter: 86
You have a power supply.?
Page generated in 0.28263 seconds with 9 queries
