Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 04-03-2017, 05:00   #31 (permalink)
karlleeto's Avatar
Member: 383592
Thanks Meter: 88
Originally Posted by ahmed koukou View Post
Hello,
Upload high quality image for your mobile mainboard.
أرسلت من HUAWEI P7-L10 بإستخدام تاباتلك
Please check these and let me know
Old 04-03-2017, 14:39   #32 (permalink)
ahmed koukou's Avatar
Member: 1981679
Thanks Meter: 86
Hello,
I do not have a board like yours for now, but your problem as i think in battery connector v+ way.
make a test by avo meter when charger on phone and let me know measurements.
Regards.
The Following User Says Thank You to ahmed koukou For This Useful Post:
Old 04-03-2017, 15:24   #33 (permalink)
Member: 1981679
Thanks Meter: 86
Hello,
try this and post result.
https://drive.google.com/open?id=0Bw...VBPRUdVVXZPRGc
Regards.
Old 04-08-2017, 07:31   #34 (permalink)
karlleeto's Avatar
Member: 383592
Thanks Meter: 88
Hello,
Regards.
I used meter to check for continuity's where you place your jumper and all seem to be ok. I get 100% continuity's where you suggest jumper to be made. So i believe that jumper isn't needed there!! Am i correct?
Old 04-08-2017, 07:34   #35 (permalink)
karlleeto's Avatar
Member: 383592
Thanks Meter: 88
Hello,
Regards.
This chip become heated when i connect charger to board.
Old 04-08-2017, 07:39   #36 (permalink)
karlleeto's Avatar
Member: 383592
Thanks Meter: 88
Hello,
Regards.
There is no output voltage here after connect charger
Old 04-08-2017, 18:02   #37 (permalink)
Member: 1981679
Thanks Meter: 86
Hello,
This chip is baseband and ram that is heating with charger that's mean you have a short circuit or baseband damaged.
Regards.
Sent from my G630-U10 using Tapatalk
Old 04-15-2017, 03:04   #38 (permalink)
Member: 2706829
Hello ahmed
My phone was upgrading from WiFi lollipop to marshmallow but it hanged while upgrading ana I have restated it by power and vol up
And since then it didn't walk up again no fast boot no flash mode no xperiA companion no red sim button
Model d5603
I have opened that back cover removed the bAttery nothing but red led light that may light up for minute or more then it drop of
Old 04-17-2017, 09:00   #39 (permalink)
Member: 2706829
Hello,
Regards.
?????? help please sd
Old 06-25-2017, 09:15   #40 (permalink)
Member: 2727754
Hello,
Upload pictures of your motherboard with jumper.
Your phone now have a short circuit remove the jumper after take pictures.
Regards,
AHMED KOUKOU
أرسلت من C6903 بإستخدام تاباتلك
canu post sony c3 dual motherboard with jumper. please
Old 02-20-2018, 10:35   #41 (permalink)
Member: 2347501
Thanks Meter: 2
Make this jumper tested 100%.
thanks bro
it actually worked
The Following User Says Thank You to rem786 For This Useful Post:
Old 07-27-2018, 06:25   #42 (permalink)
pazeth™'s Avatar
Member: 74519
Thanks Meter: 79
أرسلت من D6503 بإستخدام تاباتلك
It's work perfect for me! many thanks brother
The Following User Says Thank You to pazeth™ For This Useful Post:
Old 08-30-2018, 05:22   #43 (permalink)
Member: 1635543
Sonork: 100.1676415
Thanks Meter: 15
Arrow
this is working perfectly 100000000000%
thanx bro
The Following User Says Thank You to gsmserverkpm For This Useful Post:
Page generated in 0.23610 seconds with 9 queries
