Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 06-04-2016, 11:32   #16 (permalink)
Member: 222721
no power supply, connected to the pc with battery disconnected from motherboard, flashtool works
Old 06-04-2016, 18:42   #17 (permalink)
Member: 222721
WORKING!!!!
my problem was the connector to the left of the battery connector, on the motherboard. that was not pressed fully and was making contact only at times. my phone is now working, the short circuit from the picture above was the solution to the red light problem!
Thank you ahmed koukou!
Old 06-04-2016, 19:00   #18 (permalink)
ahmed koukou's Avatar
Member: 1981679
Thanks Meter: 86
Originally Posted by tgg2k View Post
WORKING!!!!
Hello,
No thanks
I'm pleased to help people.
Best regards,
Ahmed koukou.
أرسلت من C6903 بإستخدام تاباتلك
The Following User Says Thank You to ahmed koukou For This Useful Post:
Old 06-11-2016, 21:31   #19 (permalink)
Member: 125632
Thanks Meter: 233
i av red light,on z2 ur fix fixed this,..mob works great,but do not charge,...it will show charging,but not charge the battery...battery charge up with a universal adapter,so the battery is ok
Old 06-11-2016, 23:48   #20 (permalink)
Member: 1981679
Thanks Meter: 86
Hello,
Upload a picture of your motherboard and measure the voltage ⚡ on battery 🔋 connector while charger plugged in
And show me.
Old 06-27-2016, 16:59   #21 (permalink)
wykie's Avatar
Member: 36126
Thanks Meter: 311
Thanks for the jumper worked like a charm
WBR
wasim
Old 06-27-2016, 18:13   #22 (permalink)
Member: 1981679
Thanks Meter: 86
WBR
wasim
My pleasure.
By AHMED KOUKOU
Old 10-14-2016, 09:07   #23 (permalink)
Member: 2636678
it is work , thanks you very much
The Following User Says Thank You to minhnhat0201 For This Useful Post:
Old 02-08-2017, 18:26   #24 (permalink)
Member: 702604
Thanks Meter: 12
Shoukran my friend,your solution work perfect..
The Following User Says Thank You to arthur1964 For This Useful Post:
Old 02-09-2017, 20:09   #25 (permalink)
Member: 1798661
Sonork: 1669055
Thanks Meter: 110
Wink
Originally Posted by jinist.smith View Post
After doing this battery is heating
model number of your phone
Old 02-09-2017, 23:49   #26 (permalink)
Member: 1981679
Thanks Meter: 86
Hello,
Model d6503,d6502
Make sure of your connection the jumper connect to positive side of capacitor if connected to other side it will make a short circuit and it will make phone heating.
أرسلت من E2333 بإستخدام تاباتلك
Old 04-02-2017, 03:46   #27 (permalink)
karlleeto's Avatar
Member: 383592
Thanks Meter: 88
Originally Posted by ahmed koukou View Post
Make this jumper tested 100%.
Hi, do you have jumper for xperia c6603? I have same problem red led blinking three when power button press. I successfully flash but same problem.
Old 04-02-2017, 10:06   #28 (permalink)
Member: 1981679
Thanks Meter: 86
Hello,
What is the reason of your problem.
Regards.
Old 04-02-2017, 13:29   #29 (permalink)
karlleeto's Avatar
Member: 383592
Thanks Meter: 88
Hello,
Regards.
Red led blinking three time when i push power button. I also change battery but same problem.
The Following User Says Thank You to karlleeto For This Useful Post:
Old 04-02-2017, 14:31   #30 (permalink)
Member: 1981679
Thanks Meter: 86
Hello,
Upload high quality image for your mobile mainboard.
أرسلت من HUAWEI P7-L10 بإستخدام تاباتلك
Page generated in 0.22511 seconds with 9 queries
