08-25-2007, 10:15 | #1 (permalink) |
Freak Poster Join Date: Jul 2005
Member: 162777 Status: Offline Thanks Meter: 1 | Problem with V3r unlock using prepare method Cheers DD SmartMoto 2.28 S-Card: 42492**** Smart-Clip dongle, v 1.41, assigned Smart-Clip: 73359**** Europe, initializing... OK Clip serial: 73359****, version: 3.19, initializing... OK Searching for phone... found Motorola Phone (V3r), getting test interface... OK Model V3r Firmware R4515_G_08.BD.43R Switching to flash mode... OK [S Flash Neptune LTE2] Reading phone boot version... A.30 Sending boot... OK Performing backup to temporary file Stored temporary backup to C:\Program Files\GsmServer\SmartMoto\temporary backup\bkp_79299727999545FA.bk_ Backup OK Erasing flash memory error 80 Searching for phone... found Motorola Phone (V3r), getting test interface... OK Switching to flash mode... OK [S Flash Neptune LTE2] Reading phone boot version... A.30 Sending boot... OK Erasing flash memory OK Sending firmware OK Searching for phone... found S Blank Neptune LTE2 Switching to flash mode... OK Reading phone boot version... 3.00 Reading flash id... ST - M30L0R8000B0 Reading flash id/2... none, OK Phone group: V235,V360,V360v,V3i,V3r,L7,L7e,L7v,L71,K1,Z3 Hardware IMEI: 35942100014**** IMEI OTP status: locked Security area saved to "PDS for S Blank Neptune LTE2 359421000144506.mbk" Performing restore from temparary backup file C:\Program Files\GsmServer\SmartMoto\temporary backup\bkp_79299727999545FA.bk_ WARNING: Restore operation failed. Try to perform 'prepare phone' operation or flash the phone with full flash file again Preparing... "Prepare phone" operation failed io timeout |
08-25-2007, 10:20 | #2 (permalink) |
Freak Poster Join Date: Apr 2005 Location: Ketchery Bazar FSD Pakistan Age: 49
Member: 135718 Status: Offline Thanks Meter: 5 | friend v3r is simple phone for unlock twice i unlock it yesterday 1 also just get right test point cut it and inlock via test point it will be ok |
08-25-2007, 14:29 | #5 (permalink) |
No Life Poster Join Date: Feb 2005 Location: P A K I S T A N
Member: 113943 Status: Offline Thanks Meter: 73 | did u try again whole process with fully charged battery and wen message appears for rewrite bk look smart moto select same phone back up via imei click ok may be its help u to revive ur phone back up in orignal state m done so many phone with same process |
08-28-2007, 09:22 | #6 (permalink) |
Member: 162777 Status: Offline Thanks Meter: 1 | tried to repair pds and get the following message, it also says critical error on the lcd Searching for phone... found S Flash Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... A.30 Boot prepare... failed cheers DD |
08-28-2007, 09:29 | #7 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ Ddavez, To be able to perform Repair PDS procedure Prepare cycle should be used. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
08-29-2007, 10:38 | #11 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ Ddavez, Run Prepare cycle ("Unlock automatically" should be marked off), after that perform Repair PDS procedure and Full Flash the handset with the same firmware version like the handset originally had or higher one. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
09-12-2007, 16:26 | #12 (permalink) |
Member: 162777 Status: Offline Thanks Meter: 1 | Having almost all handsets I try to unlock using prepare method now don't work and I'm using latest updates and same method I have successfully used for the past year. Here's a log from a Z3 SmartMoto 2.30 S-Card: 42492**** Smart-Clip dongle, v 1.43, assigned Smart-Clip: 73359**** Europe, initializing... OK Clip serial: 73359****, version: 3.21, initializing... OK Searching for phone... found Motorola Phone (Z3), getting test interface... OK Model Z3 Firmware R452B_G_08.01.05R Switching to flash mode... OK [S Flash Neptune LTE2] Reading phone boot version... A.C0 Sending boot... OK Performing backup to temporary file Stored temporary backup to C:\Program Files\GsmServer\SmartMoto\temporary backup\bkp_F929A90E51996A20.bk_ Backup OK Searching for phone... no phone found Searching for phone... found Motorola Phone (Z3), getting test interface... OK Switching to flash mode... OK [S Flash Neptune LTE2] Reading phone boot version... A.C0 Sending firmware OK Searching for phone... found S Blank Neptune LTE2 Switching to flash mode... OK Reading phone boot version... 3.00 Reading flash id... Intel - 28F256L18B Reading flash id/2... Intel - 28F256L18T, OK Phone group: V235,V360,V360v,V3i,V3r,L7,L7e,L7v,L71,L72,L9,K1,W 510,Z3 Hardware IMEI: 35409101094**** IMEI OTP status: locked Security area saved to "PDS for S Blank Neptune LTE2 35409101094****.mbk" Performing restore from temparary backup file C:\Program Files\GsmServer\SmartMoto\temporary backup\bkp_F929A90E51996A20.bk_ WARNING: Restore operation failed. Try to perform 'prepare phone' operation or flash the phone with full flash file again Preparing... "Prepare phone" operation failed clip communication failed Tried and re tried to unlock using prepare no joy. There must be something making almost all my prepare phones do this. Any ideas I can try ?? Thanks Dave |
09-12-2007, 17:00 | #14 (permalink) |
Member: 162777 Status: Offline Thanks Meter: 1 | Thanks for that but the battery is full I tried to prepare with "unlock auto after" not ticked and it went through and gave a different message of "Security area saved to "PDS for Motorola 35409101094**** (3).mbk" Performing restore from temparary backup file C:\Program Files\GsmServer\SmartMoto\temporary backup\bkp_F929A90E51996A20.bk_ WARNING: Restore operation failed. Try to perform 'prepare phone' operation or flash the phone with full flash file again Now you can perform Repair PDS or Unlock operations. To get the handset back to the working condition, please flash it with boot file (boot_.mfw)." This is different to the usual prepare fail message Tried to go to unlock menu and it unlocked "Unlocking phone... OK" Still no power on, so tried repair PDS, keep getting the following "Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.00 Reading flash id... Intel - 28F256L18B Reading flash id/2... Intel - 28F256L18T, OK Phone group: V235,V360,V360v,V3i,V3r,L7,L7e,L7v,L71,L72,L9,K1,W 510,Z3 Hardware IMEI: 35409101094**** IMEI OTP status: locked Security area saved to "PDS for S Blank Neptune LTE2 35409101094**** (3).mbk" Login request... OK Writing flash section 2 of 2... 100% (65.9 Kb/sec) Restarting phone... OK Searching for phone... found S Blank Neptune LTE2 Switching to flash mode... OK IMEI OTP status: locked Repair PDS request... OK Performing PDS repair... clip communication failed" Smart clip has been working OK for over a year and is powered by 12V supply Gotta sort this out...there must be something causing this I can solve Cheers DD |
09-12-2007, 17:28 | #15 (permalink) |
No Life Poster Join Date: Jun 2004 Location: Kenya
Member: 70343 Status: Offline Thanks Meter: 38 | This is interesting... I have two phones, a V3r and V3i, both unlocked using prepare cycle, and both are now stuck in "phone code sig error". I have tried all that has been suggeted here, no change. When I try to flash with Scout, the process stops at 4%. When I try to flash with RSD, it stops at 8%. Why those specific percentages, I have no clue. Just to be clear, I have used this process many times before without a problem, and I am not quite a newbie They are driving me nuts, and I would be grateful for other ideas. |
Problem with 6300 unlocking with new methode | Bloedman | UID - Box | 10 | 10-24-2007 08:24 |
problem with v3r after unlock | rysiek | Smart-Clip | 4 | 06-03-2007 14:04 |
Motorola V3r Unlocking using testpoint (0A.52) | bbmad | Ultima Box Light | 20 | 03-13-2007 10:22 |
Problems with SX1 -> SIM Prepared | shax-sx1 | Phone Unlocking Codes & Maps | 1 | 12-18-2004 14:00 |
