07-17-2004, 15:02 | #32 (permalink) |
No Life Poster Join Date: May 2004 Age: 45
Member: 65186 Status: Offline Thanks Meter: 0 | Now trying to read the flash from the V80 phone which alway display: Switching to flash mode ... failed I only can read the history. Can anyone tell me how to change my bios setting for the LPT so that I can use this clip on my Win XP Pro? |
07-17-2004, 17:20 | #33 (permalink) | |
Junior Member Join Date: Mar 2004 Age: 45
Member: 60239 Status: Offline Thanks Meter: 1 | Quote:
try to clean contacts, or charge the battery in the phone | |
07-17-2004, 20:55 | #35 (permalink) | |
Member: 65186 Status: Offline Thanks Meter: 0 | Quote:
07-17-2004, 23:55 | #36 (permalink) | |
Freak Poster Join Date: May 2004 Location: USA Age: 52
Member: 65975 Status: Offline Thanks Meter: 22 | Quote:
START-control Panel Click on System click on hardware On Device Manager - click on Device Mnager Click on The + pORT(COM & LPT) You should get : communication Port(com 1 ) communication Port(com 2 ) ECP Printer Port (LPT1)1) On communication Port(com 1 ) Click on it {communication Port(com 1 )} ON PORT SETTING -RESTORE IT TO DEFAULTS ON RESSOURCES -CHECK THE BOX THAT SAID USE AUTOMATIC SETTING AND CLICK OK 2)SAMETHING WITH communication Port(com 2 ) 3)ECP Printer Port (LPT1) click on PORT SETTING -CHECK THE BOX THAT SAID NEVER USE AN INTERRUPT AND CLICK OK Click on RESSOURCES -CHECK THE BOX THAT SAID USE AUTOMATIC SETTING AND CLICK OK | |
07-18-2004, 08:06 | #37 (permalink) |
Member: 65186 Status: Offline Thanks Meter: 0 | It still cant work. Still displayed the following below. I dun think this clip can work under Win XP Pro enviroment. Looking for clip at 0X378... Run under administor priviledge Clip not found |
07-19-2004, 00:13 | #39 (permalink) |
No Life Poster Join Date: Mar 2004 Location: uk Age: 54
Member: 59789 Status: Offline Thanks Meter: 16 | still can't do hiya m8 i have the ur instrution on it still won't do it for reason my p OPS XP HOME EDITION i hink i will a word wit my supply about this thanks for the help. |
07-19-2004, 00:29 | #40 (permalink) |
No Life Poster Join Date: Dec 2001
Member: 8102 Status: Offline Thanks Meter: 118 | Okay just so everybody knows, I have WINXP and Vitual PC WIN98SE (so with WIN98SE wont be able to connect with Internet ) The clip does not work with WINXP but works 100% WIN98SE (tried the read log in WIN98SE and reads 100%) So no doubt the authors of Smart-Clip are watching and working on a solution as I write Thanks people !! |
07-19-2004, 00:33 | #41 (permalink) |
No Life Poster Join Date: Jun 2004 Location: MACEDONIA
Member: 67805 Status: Offline Thanks Meter: 364 | don`t write that smartclip have no support with XP, because on my XP work very well. maybe problems are with cables or PC hardware configurations. wbr. |
07-19-2004, 00:43 | #42 (permalink) | |
Member: 8102 Status: Offline Thanks Meter: 118 | Quote:
I can use every single LPT unlocking device apart from this one and according to the posts there are a few people in the same boat as me. So come on dude tell us the setting !! EDIT: Just ran the SCreader in WIN98 compatability on WINXP and it works but cant get the update one to work as its an ActiveX (or whatever u cal it!) | |
07-19-2004, 01:17 | #44 (permalink) |
Member: 67805 Status: Offline Thanks Meter: 364 | Ok I found this setting in my BIOS. INTEGRATED PERIPHERALS: 1.Onboard Parallel Port = 378/IRQ7 2.Parallel Port Mode = SPP 3.ECP Mode Use DMA = 3 4.EPP Mode Select = EPP1.7 In ECP & EPP I can`t change anything because they are in grey color because mode is SPP selected. I/O Range 0378-037F wbr. |
07-19-2004, 13:38 | #45 (permalink) |
Member: 65186 Status: Offline Thanks Meter: 0 | Smart Clip Team once again solve my problem for my V80. So far I play with many unlock and flashing device but none of their support n services come close to Smart Clip Team. Thump up. Now I try with the Solution for Win XP see if its work for me. Solution by UHK. |
smart-clip updates ok but donfle not updated. | lalitjsraks | Smart-Clip | 2 | 01-12-2010 13:29 |
Today, after atempt to update Smart-Clip, Update Failed | Gubby_J | Smart-Clip | 5 | 12-09-2009 12:51 |
Scard Update FAILED Smart Clip Updated OK | Aamir_Zia | Smart-Clip | 1 | 07-12-2008 10:05 |
UBL TEAM LOOK SMART CLIP UPDATE AND UPDATE Too | denard | Ultima Box Light | 1 | 10-25-2007 20:20 |
smart clip update v1.19 | gamol | Smart-Clip | 0 | 07-30-2004 04:50 |
