07-19-2004, 13:45 | #46 (permalink) | |
Freak Poster Join Date: May 2004 Location: USA Age: 52
Member: 65975 Status: Offline Thanks Meter: 22 | Quote:
07-19-2004, 13:47 | #47 (permalink) |
No Life Poster Join Date: Dec 2001
Member: 8102 Status: Offline Thanks Meter: 118 | I tried the settings as well but still no luck What I did nottice though that the SCReader works ok in WIN98SE and then when i use the SCReader on WINXP it works but after a while it stops working on WINXP and the red light flashes on Smart Clip and the green light goes off every time i try to connect. Got no where on the update server - just cant connect |
07-19-2004, 13:55 | #48 (permalink) | |
SIDE TO THE COMPUTER AND TO THE SMART DEVICE.USUALLY YOU HAVE TO TIED THE CABLE TO GET A GOOD COMMUNICATION. THERE IS DOUBT SMART-CLIP AND SCReader both WORK VERY GOOD ON WIN XP. | |
07-19-2004, 19:34 | #49 (permalink) | |
No Life Poster Join Date: May 2004 Age: 45
Member: 65186 Status: Offline Thanks Meter: 0 | Quote:
Thank for your reply. I still have the same problem cant operate on Win XP Pro. Really hope that it can be solved soon. Thank in advance | |
07-19-2004, 23:52 | #50 (permalink) | |
I WANT YOU TO MAKE SURE THAT YOU HAVE LOG IN COMPUTER AS ADMIN HOW TO DO THAT TURN OFF ALL USERS FOR YOUR COMPUTER.IF YOU LOG AS ADMIN YOU CAN MAKE CHANGING. You may also find it necessary to change the configuration of the port settings. To do so, access the Properties dialog box for your printer from within Device Manager . This time, select the Port Settings tab. Then, in the Filter Resource Method panel, select Use Any Interrupt Assigned To The Port. Next, check the Enable Legacy Plug And Play Detection box. MAKE SURE AFTER THAT YOUR PRINTER WORK. IF NOT RELOAD THE PRINTER DRIVER AGAIN.THEM TRY SMART-CLIP. PLEASE LET ME KNOW IF YOU FIX IT. BEST REGARDS. | |
07-20-2004, 00:21 | #51 (permalink) |
No Life Poster Join Date: Mar 2004 Location: uk Age: 54
Member: 59789 Status: Offline Thanks Meter: 16 | ME do the trick so to let everone no i have done a daul boot on one of my pc XP/ME connect the to XP noting happen so i connect on ME on the clip update in a flash i was happy to get it updated thanks to you all for suggestion on help i just hope it will update it when the next update is out. can the smart-clip team add the t730/t730i usa version this last update do the usa t720/t720i have look into it yea peace keep up the good work one luv evertime. Last edited by balLlroad; 07-20-2004 at 00:24. Reason: missig word |
07-20-2004, 19:38 | #52 (permalink) | |
No Life Poster Join Date: Dec 2003 Location: Karachi Pakistan Age: 38
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | Quote:
Read the Flash File by SReader & send it to Smart-Clip team they will add those models in their New Update | |
07-21-2004, 01:36 | #53 (permalink) |
Member: 59789 Status: Offline Thanks Meter: 16 | how first good day m8 i hav't got no t730/t730i so i can't read the flash file if anyone got these phone thy send it smart-clip team so thy can add it to thy next update. by the way how do you read the flash file from thephone can you send me details please thanks peace. |
07-23-2004, 20:31 | #56 (permalink) | |
I am hoping to be add in Next Update | |
07-24-2004, 15:01 | #60 (permalink) |
Freak Poster Join Date: May 2004 Location: Tunis Age: 39
Member: 65648 Status: Offline Thanks Meter: 5 | How i repair my clip???????? I have one smart clip when i try to update it to v1.15 it stop in write update step & now my smart clip is off.it connect only with server and show s/n and software versioon like in picture. i try to reupdate it but login is denied all of time what i must do??????? to repair my clip |
smart-clip updates ok but donfle not updated. | lalitjsraks | Smart-Clip | 2 | 01-12-2010 13:29 |
Today, after atempt to update Smart-Clip, Update Failed | Gubby_J | Smart-Clip | 5 | 12-09-2009 12:51 |
Scard Update FAILED Smart Clip Updated OK | Aamir_Zia | Smart-Clip | 1 | 07-12-2008 10:05 |
UBL TEAM LOOK SMART CLIP UPDATE AND UPDATE Too | denard | Ultima Box Light | 1 | 10-25-2007 20:20 |
smart clip update v1.19 | gamol | Smart-Clip | 0 | 07-30-2004 04:50 |
