09-10-2007, 09:41 | #2 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ baturay, Please show full log file, it will spread some light at your problem. Don't forget to hide your serial number. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
09-15-2007, 00:50 | #3 (permalink) |
No Life Poster Join Date: Oct 2004 Age: 47
Member: 86579 Status: Offline Thanks Meter: 70 | error D3 applying patch v3i r4441d im getting the same error here is the log: Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.00 Reading flash id... ST - M30L0R8000B0 Reading flash id/2... ST - M58LR128FT, OK Phone group: V235,V360,V360v,V3i,V3r,L7,L7e,L7v,L71,L72,L9,K1,W 510,Z3 Hardware IMEI: 357692001008724 IMEI OTP status: locked Security area saved to "PDS for S Blank Neptune LTE2 357692001008724 (8).mbk" Login request... OK Writing flash section 2 of 2... 100% (28.7 Kb/sec) Restarting phone... OK Searching for phone... found S Blank Neptune LTE2 Switching to flash mode... OK IMEI OTP status: locked Repair PDS request... OK Performing PDS repair... OK Writing flash section 1 of 1... 100% (16.2 Kb/sec) Please write a corresponding Full_flash file to phone to complete repair Writing flash section 2 of 2... 100% (69.9 Kb/sec) Flash completed! Applying IMEI patch, please wait (up to 2 minutes!)... error D3 and this is the flash file i used: V3i_R4441D_G_08.02.05R_lp0034_full_flash.mfw BR Gee4234 |
09-17-2007, 09:41 | #4 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ gee4234, Please tell us what is wrong with the phone. Why you want to perform Imei Patch procedure? Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
10-13-2007, 19:47 | #5 (permalink) |
Member: 86579 Status: Offline Thanks Meter: 70 | reason why i want to patch i want to patch this phone because when i flash with this flash file phone works fine but the imei is changed like if this flash was allready patched. BR Gee4235 |
10-13-2007, 23:37 | #6 (permalink) | |
No Life Poster Join Date: May 2005 Age: 40
Member: 440163 Status: Offline Thanks Meter: 2,470 | Quote:
10-15-2007, 08:08 | #7 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ gee4234, First of all use fully charged battery or another one, as ..::TELEMASTER::.. have already told. Also, the handset suppose to be turned on for IMEI patch procedure to be completed successfully. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
01-31-2008, 03:59 | #8 (permalink) | |
Registered User Join Date: Mar 2006 Location: Aserver sl3 Age: 43
Member: 241148 Status: Offline Thanks Meter: 38 | I have same problem! sure battery is full. Plz help me LOG HERE Quote:
01-31-2008, 08:26 | #9 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ kenny81, Please tell us what is wrong with the phone. Why you want to perform Imei Patch procedure? Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
02-01-2008, 11:32 | #10 (permalink) |
Member: 241148 Status: Offline Thanks Meter: 38 | @ Mr.Tinkkertrain: My phone not power on but press "* + # + power" phone in to bootloader ok. Because Hardware IMEI: 957CF9082726938. I need patch IMEI |
02-01-2008, 11:47 | #11 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ kenny81, Perform Repair PDS and Full Flash the phone (with the same platform, but higher firmware version) via Prepare cycle. After that perform IMEI Patch and restore Original IMEI. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
02-02-2008, 03:35 | #12 (permalink) |
Member: 241148 Status: Offline Thanks Meter: 38 | @ Mr.Tinkertrain: Perform Repair PDS, Full Flash and IMEI Patch but phone not ok! Applying IMEI patch, please wait (up to 2 minutes!)... error D3 I used FlashFile V3i_R4441D_G_08.02.05R_lp0034_full_flash.mfw I thinking problem my phone is Hardware. tks for reply! |
02-02-2008, 12:50 | #13 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ kenny81, It looks like the handset has hardware malfunction. Most probably that Flash Chip has to be replaced. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
09-03-2008, 18:54 | #15 (permalink) |
Member: 86579 Status: Offline Thanks Meter: 70 | mine doenst have hardware problem the phone was originally r4441d G_08.02.05r, i flashed it with that exact version that i downloaded from bootloader. But now the Imei is different and i cant patch it (error D3). I tried using a different version, like G-08.03.03r, but the phone doenst turn on, as a matter of fact, it only turns on with that firmware (G-08.02.05r), but with different imei. I keep having the same problem over and over again, everytime i flash an r4441d and i dont know what to do. That flash in bootloader has the imei changed and there is no other flash i can use. I would really aprecciated some help Mr Tinkertrain. thanks |
V3i Bootloader Screen-help Me To Flash | zonetrichur | Ultima Box Light | 4 | 10-15-2007 12:24 |
V3i warming.Please help me! | olajosadri | Smart-Clip | 2 | 11-04-2006 03:03 |
V3i Unlocking.. plz help me | atiisgr8 | Motorola P2k | 0 | 07-02-2006 13:15 |
V3i dead plz help me | -KimoAlex- | Motorola P2k | 0 | 02-16-2006 15:55 |
