09-05-2008, 11:35 | #31 (permalink) |
No Life Poster Join Date: Oct 2004 Age: 47
Member: 86579 Status: Offline Thanks Meter: 70 | thank you for responding to my post but allready done what they said flashed with both those flashes the mfw and pcf r444ad.o8.02.o5r lp0015 mr tinkertrain please V3i_R4441D_G_08.02.05R_lp0034_full_flash.mfw BR Gee4234 |
09-05-2008, 12:08 | #32 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Central Europe Age: 39
Member: 239548 Status: Offline Thanks Meter: 2,781 | So, you say that you have flashed with this version R4441D_G_08.02.05R? The phone powers on normally? So, what is the result? What is your IMEI after flashing (*#06#)? |
09-05-2008, 13:36 | #33 (permalink) |
Member: 86579 Status: Offline Thanks Meter: 70 | if you read the thread you will see what my imei is when i power on the phone with the only flash that works with this phone.i have all ready explained everything here BR Gee4234 |
09-05-2008, 14:22 | #34 (permalink) |
Member: 239548 Status: Offline Thanks Meter: 2,781 | Have you redownloaded the file MFW\V3ie\R4441D_G_08.02.05R\V3ie\China Mobile\V3ie_R4441D_G_08.02.05R_lp0015_full_flash.m fw and flashed the phone with it ??? If it works for me then it has to work for you. |
09-05-2008, 14:46 | #35 (permalink) |
Member: 86579 Status: Offline Thanks Meter: 70 | hey this is the flash tinkertrain ask me to redownload V3i_R4441D_G_08.02.05R_lp0034_full_flash.mfw problem is is they removed it yesterday and never uploaded it again.i downloaded the one you specified yesterday and pds repaired and flashed and phone doesnt power on. it only takes this flash V3i_R4441D_G_08.02.05R_lp0034_full_flash.mfw but the problem is the imei is changed in the flash and when you try to patch it you get error d3 and if i just try to change the imei then i smartmoto tells me to patch the phone first. so im stuck i download all the mfw for r4441d and many pcf but i cant get the phone to power with any other flash but that one. mr tinkertrain please add V3i_R4441D_G_08.02.05R_lp0034_full_flash.mfw unpatched so i can flash phone and return it to the customer.when the customer brought the phone to me it was working with its original imei the only problem is it didnt have t9 for spanish. thanx for your help mcandre. also mr tinkertrain i see you guys removed V3i_R4441D_G_08.02.05R_lp0034_full_flash.mfw from bootloader i guess that means you found the problem with the flash can you please upload that exact same flash but unpatched or repair that one please!!!!!!!!!!!!!!!!!!! BR Gee4234 |
09-05-2008, 14:48 | #36 (permalink) |
Member: 86579 Status: Offline Thanks Meter: 70 | hey mcandre if you want i will post a link to rapid share with V3i_R4441D_G_08.02.05R_lp0034_full_flash.mfw and if you have a v3ie r4441d platform to try out you will see what i mean. BR GEE4234 |
09-05-2008, 15:21 | #37 (permalink) |
Member: 239548 Status: Offline Thanks Meter: 2,781 | I must say that this is a very strange story, but there should be some logical explanation! Let's understand the situation. Ok, you say that you've redownloaded this China Mobile branded flash file and flashed the phone with it. V3ie_R4441D_G_08.02.05R_lp0015_full_flash.mfw - this file? And you say that the phone isn't turning on after that? Do I understand you correctly? If yes, then flash the phone with your old flash file V3i_R4441D_G_08.02.05R_lp0034_full_flash.mfw to revive it and after that flash with pcf file R4441D_G_08.02.05R_PDS005_LP0015_DRM0101_VSTMANDAR IN_PRC206US_ENGLISH206_JPJAVA_G_08_V3e_03_00_02R_G SVSLQAET678SU078_1FF[CMCC NSL China].pcf Don't forget to show your logs without serial numbers from SmartMoto and Scout! |
09-05-2008, 16:34 | #39 (permalink) | |
Member: 86579 Status: Offline Thanks Meter: 70 | Quote:
here is smartmoto log Searching for phone... found S Flash Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... A.30 Sending boot... OK Erasing flash memory OK Sending firmware OK Searching for phone... found S Blank Neptune LTE2 Switching to flash mode... OK Reading phone boot version... 3.00 Reading flash id... ST - M30L0R8000B0 Reading flash id/2... ST - M58LR128FT, OK Phone group: V235,V360,V360v,V3i,V3r,L7,L7e,L7v,L71,L72,L9,K1,U 3,W5,W490,W510,Z3 Hardware IMEI: 359414008776841 IMEI OTP status: locked Security area saved to "PDS for S Blank Neptune LTE2 359414008776841 (33).mbk" Unlocking phone... OK To get phone to work, you should write flash into the phone Writing flash section 2 of 2... 100% (79.6 Kb/sec) Flash completed! Turning phone off... OK phones turns on after this flash then i flash R4441D_G_08.02.05R_PDS005_LP0015_DRM0101_VSTMANDAR IN_PRC206US_ENGLISH206_JPJAVA_G_08_V3e_03_00_02R_G SVSLQAET678SU078_1FF[CMCC NSL China].pcf and phone does not turn on. BR GEE4234 | |
09-05-2008, 16:55 | #40 (permalink) |
Member: 86579 Status: Offline Thanks Meter: 70 | here are images of scout and smartmoto this one is after flash with smartmoto phones turns on this one is after flash with scout phone does not turn on BR Gee4234 Last edited by gee4234; 09-05-2008 at 17:02. |
09-08-2008, 13:49 | #42 (permalink) | |
Member: 239548 Status: Offline Thanks Meter: 2,781 | Quote:
09-08-2008, 14:54 | #45 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ gee4234, Show us full log file, please. Don't forget to hide your serial numbers. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
V3i Bootloader Screen-help Me To Flash | zonetrichur | Ultima Box Light | 4 | 10-15-2007 12:24 |
V3i warming.Please help me! | olajosadri | Smart-Clip | 2 | 11-04-2006 03:03 |
V3i Unlocking.. plz help me | atiisgr8 | Motorola P2k | 0 | 07-02-2006 13:15 |
V3i dead plz help me | -KimoAlex- | Motorola P2k | 0 | 02-16-2006 15:55 |
