03-06-2010, 04:50 | #1 (permalink) |
Freak Poster Join Date: Apr 2006 Location: Inside GSM World in Asia-Pacific
Member: 260002 Status: Offline Thanks Meter: 8 | V975 error in unlocking please help SmartMoto 4.05 S-Card: 559140xxx Smart-Clip dongle, v 3.03, assigned Smart-Clip: 962465xxx Europe, initializing... OK Clip serial: 962465xxx, version: 5.02, initializing... OK Searching for phone... found Motorola Phone (V975), getting test interface... OK Model V975 Firmware R245_U_82.31.56.06P Switching to flash mode... OK [S Flash Rainbow POG] Reading phone boot version... 6.12 Reading flash id... Intel - 28F256L18B (x2) Phone group: E770,E1000,E1070,V3x,V975,V1050 Hardware IMEI: 354993000212082 IMEI OTP status: locked Security area saved to "PDS for Motorola V975 354993000212082.mbk" Writing flash section 1 of 1... 100% (19.7 Kb/sec) Turning phone off... OK Searching for phone... found S Blank Rainbow POG Switching to flash mode... OK error C2 now when i press *+#+power on, the screen will display"error:0x1DE" when i try to press again the remove the rsa button phone will not connect anymore. "Searching for phone...not found" "Connect phone to Smart-Clip before proceeding" how can i repair this phone? im planning to flash the phone with TP procedure so that it will power on again, correct me if im wrong. and if im able to power it on again after flashing i will repeat the procedure. using the step by step unlocking procedure. as of this moment the phone will not power on but if i press *+#+power on button it will just display this "error:0x1DE" i cant connect the phone anymore for flashing or unlocking. please help. tia |
The Following User Says Thank You to baywalker For This Useful Post: |
03-06-2010, 08:30 | #2 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | if phone displays "Error 0x1DE" need to go to "Unlock" Bookmark and press "Remove RSA". Phone must be connected via Smart-Clip for that and taken into boot mode using *#PWR ON key combination (with standard cable) or using repair cable without keys combination. ___ Best Regards GsmServer Team www.smart-clip.com www.scoutdongle.com http://www.boot-loader.com Become a Boot-Loader v2.0 Fan Become a Smart-Clip Fan |
The Following User Says Thank You to Mr.Tinkertrain For This Useful Post: |
08-07-2010, 09:44 | #4 (permalink) | |
Junior Member Join Date: Dec 2006
Member: 418230 Status: Offline Thanks Meter: 8 | Quote:
thank you i unlock the phone now | |
6210n unlock please help me please | AVCITHETCNC | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 03-29-2010 18:21 |
V3re Reconnect error in unlocking.Pls help | maeane | Smart-Clip | 9 | 02-19-2009 17:17 |
C975 error in unlock plz help | urromeo | Motorola P2k | 8 | 09-04-2006 17:00 |
