04-12-2017, 11:34 | #13651 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Romania,Sinaia
Member: 637351 Status: Offline Thanks Meter: 167 | Code: Using library Brom_DLL_v5.1316.1 Searching phone; (for some models keep SPACE or * (STAR) key pressed before inserting the cable) Phone detected (MediaTek USB Port (COM35)) Preparing to start meta mode; Requesting authorization; Done; Meta mode entered; Baseband Chip: MT6260 Sw version: MAUI.11B.W13.08.MP.V4.F54 Hw Version: JRDHZ60A_11B_HW Reading phone info; IMEI: 014253-00-56xxxx-x Reading security; Done; Checking; Preparing; Writing security; Phone unlocked; Remove battery and cable; Time needed - 00:00:22 |
04-12-2017, 11:40 | #13652 (permalink) |
Member: 637351 Status: Offline Thanks Meter: 167 | v685 UNLOCKED SUCCESSFULLY Code: Using library Brom_DLL_v7.1413.5 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM25)) Preparing to start flash mode; Preparing to open COM25 Connecting; Downloading DA; Initializing; Rid: 5ea9c63afb64b2390265e1c1a5accab4 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver\x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM42; DEVICE INFO: BB CHIP: MT6572_S00 [CA01, 00, 6572, FF] HW_STORAGE_EMMC: 0x4E000115 0x4D5A5835 0x73A40142 0xA5812EE0 [SIZE=0xE9880000] IMEI1 [OTP 0001]: 354459-06-74XXXX-X IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: V685-2AVDRO1 USRDATA INFO: 0x61B80000 SIZE: 0x87D00000 Searching data; Locked to [SIM1]: 226-01 code_cat_n: 32400133 enabled: yes tries: 10 code_cat_ns: 31942239 enabled: no tries: 10 code_cat_sp: 30973654 enabled: no tries: 10 code_cat_c: 31377691 enabled: no tries: 10 code_cat_sim: 34142728 enabled: no tries: 10 code_cat_ns_sp: 53297761 enabled: no tries: 5 code_cat_sim_c: 86817778 enabled: no tries: 5 Phone unlocked; Remove battery and cable; |
04-13-2017, 16:52 | #13653 (permalink) |
Freak Poster Join Date: Jan 2015
Member: 2329547 Status: Offline Thanks Meter: 15 | lg h440n unlock done Software engine version: 1.0.0.10469 Searching phone ... MODEL: LG Leon 4G LTE COMPILED DATE :Jun 13 2015 17:26:00 RELEASE DATE :Mar 31 2015 01:00:00 FIRMWAREINFO:MPSS.DPM.2.0.c11-00018M8936FAAAANUZM-1 IMEI : 3588190602XXXX-5 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; WORKING; DONE; CALC 0 CALC 1 CALC 2 CALC 3 CALC 9 CALC 10 SIM_LOCK REMOVED ! Time needed - 00:00:36 Last edited by pasc; 04-13-2017 at 17:01. |
04-13-2017, 20:24 | #13654 (permalink) |
No Life Poster Join Date: Nov 2015 Location: DHAKA
Member: 2489690 Status: Offline Thanks Meter: 289 | huawei lua-l02 unlock in seconds (insert the USB cable in the powered off phone) Phone detected (MediaTek PreLoader USB VCOM (Android)) Preparing to start MTK debug mode; Searching for debug port... (be sure drivers from support were installed!) MTK debug mode entered Baseband Chip: MT6735M,S01 Sw version: Hw Version: ALPS.L1.MP3.V2.95_OT6735M.35GU.LU.L1_P1 Baseband Chip: MT6735, E00 Sw version: MOLY.LR9.W1444.MD.LWTG.MP.V48.P8 Hw Version: OT6735_65C_LU_L1_HW Reading info... IMEI 1: 869821020985353 IMEI 2: N/A Open port success! 2017-04-13 21:13:23.619 Reading data from server... 2017-04-13 21:13:24.835 Reading data from server success! Reading simlock info; Gathering info; Simlock ok; SIM1 Locks cleared; Simlock ok; SIM2 Locks cleared; Simlock read end; |
The Following User Says Thank You to chadzar For This Useful Post: |
04-14-2017, 09:51 | #13655 (permalink) |
Member: 2489690 Status: Offline Thanks Meter: 289 | huawei y550-l01 unlock done in seconds Before detection connect cable to usb and enable Manufacture mode ! *#*#2846579#*#* ProjectMenu 1.Background setting 2.USB ports setting Select Manufacture mode Select DBAdapter Reserved Interface COM port 2017-04-14 10:48:38.722 Start read phone info! 2017-04-14 10:48:38.768 Open port COM45 (DBAdapter Reserved Interface (COM45))... 2017-04-14 10:48:38.878 Phone authorize start 2017-04-14 10:48:38.878 Connecting to server... 2017-04-14 10:48:41.623 Connected! 2017-04-14 10:48:41.623 Read data from server... 2017-04-14 10:48:43.355 Read data from server success! 2017-04-14 10:48:44.977 Phone authorize success! 2017-04-14 10:48:44.993 Read secure info... 2017-04-14 10:48:45.055 Read basic info... 2017-04-14 10:48:45.102 Detect phone done! Model: Y550-L01 IMEI: 865170028026297 SUB_IMEI: 865170028026297 Firmware ver.: Y550-L01V100R001C00B256_AMSS May 7 201515:26:55 SN: A3B7N15531001521 Custom SN: 7N2VGP155P069855 WiFi MAC: F4:8E:92:4D:E4:B2 BlueTooth MAC: F4:8E:92:4D:F0:A7 Vendor: mascom Country: bw SL: 00000000 Y550-L01V100R001C00B256_BOOT Y550-L01V100R001C00B256_AMSS May 7 201515:26:55 Y550-L01_C00B110_EFS_RFNV_C05 HL3Y550M_VERC Y550-L01V100R001C00B256_APPSBOOT Y550-L01V100R001C00B256_KERNEL Y550-L01V100R001C00B256_SYSTEM IMEI 1 Sim Lock status: NET: locked, unlock retry counts: 1 NETSUB: unlocked SP: unlocked 2017-04-14 10:48:52.918 Open port COM45 (DBAdapter Reserved Interface (COM45))... 2017-04-14 10:48:53.042 Connecting to server... 2017-04-14 10:48:55.055 Connected! 2017-04-14 10:48:55.070 Read data from server... 2017-04-14 10:48:56.724 Read data from server success! 2017-04-14 10:48:57.114 Phone authorize start 2017-04-14 10:48:58.892 Phone authorize success! 2017-04-14 10:48:58.908 Read secure info... 2017-04-14 10:48:58.970 Read secure info success! 2017-04-14 10:48:58.986 Read basic info... 2017-04-14 10:48:59.017 Read basic info success! 2017-04-14 10:48:59.033 Unlocking start 2017-04-14 10:49:00.374 Read data from server... 2017-04-14 10:49:03.307 Read data from server success! 2017-04-14 10:49:03.323 Writing security data... 2017-04-14 10:49:03.448 Write security data success! 2017-04-14 10:49:03.838 Unlock done! 2017-04-14 10:49:03.853 Job finished! |
04-14-2017, 12:37 | #13656 (permalink) | |
No Life Poster Join Date: Jul 2001 Location: Planet earth
Member: 5169 Status: Offline Thanks Meter: 684 | Quote:
Same here: Searching phone; Phone detected (@oem311.inf,%vcom_preloader%;MediaTek PreLoader USB VCOM (Android)) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on MediaTek USB VCOM (Android) (COM10); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6580B, E00 Sw version: MOLY.WR8.W1449.MD.WG.MP.V57.P3 Hw Version: SR6580_WE_M_HSPA_HW Reading phone info; IMEI: 359072-07-060xxx-2 Reading simlock info; Locked to: C1C-1C code_cat_n: 12345678 enabled: no tries: 5 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 11112222 enabled: no tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Time needed - 00:01:05 Log file saved to: LOG_14_04_2017_12_35_00.txt | |
04-15-2017, 17:09 | #13657 (permalink) |
Freak Poster Join Date: Jul 2005 Location: Philippines
Member: 161547 Status: Offline Thanks Meter: 241 | Alcatel 2036A Successfuly Unlocked by SPD Service Tool New Version. TEST REPORT.. Phone Locked to LIME Use Navigation UP and DOWN then insert USB cable to detect the phone.. Searching phone; For an successful connection do the following: 1. Remove battery and usb cable 2. Insert the usb cable in the phone 3. Keep pressed the boot key and insert the battery Phone detected (@oem267.inf,%dvcdsc%;SCI USB2Serial) Preparing to sync; Port opened [COM73]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: Spreadtrum Boot Block version 1.1 Starting FDL2; FDL2 sent; Chip type: 7702 FdlStat: 0000 Starting auth; Memory NAND [CS0]: 0098:00B1 - SIZE : 08000000 EFUSE HASH: 0000000000000000000000000000000000000000 HW IMEI : 000000-00-000000-0 Reading phone info; PHONE INFO: 2036A-3BCIJM1 BT ADDR: BC:2A:6F:51:AA:57 SW IMEI[0]: 014407-00-163177-0 SW IMEI[1]: 352751-01-265893-0 SW IMEI[2]: 358570-01-010389-3 SW IMEI[3]: 910575-60-140046-8 SIMLOCK FLAG: ON FIXED NV BASE: 40040000 Reading NV; NV saved to : NV_000000-00-000000-0_014407-00-163177-0_77020000_15_04_2017_11_02_17.spd IMEI: 014407-00-163177-0 UNLOCK CODE: 58128810 Re-programming; NV programmed; Done; Phone unlocked; Remove battery and cable; Log file saved to: LOG_15_04_2017_11_02_42.txt Time needed - 00:00:34 Br Hagard |
04-16-2017, 13:54 | #13658 (permalink) |
No Life Poster Join Date: Jan 2010 Location: iraq
Member: 1215266 Status: Offline Thanks Meter: 129 | Alcatel 1016 unlock done Searching phone; For an successful connection do the following: 1. Remove battery and usb cable 2. Insert the usb cable in the phone 3. Keep pressed the boot key and insert the battery Phone detected (@oem151.inf,%dvcdsc%;SCI USB2Serial) Preparing to sync; Port opened [COM16]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: (c)2014, FuriouSTeaM GSM DEVELOPEMENT Chip type: 6531 FdlStat: 0001 Starting auth; HW IMEI : 000000-00-000000-0 Memory [CS0]: 00EF:0040:0016 - SIZE : 00400000 Reading phone info; PHONE INFO: 1016G-3AE8GB1 BT ADDR: FF:FF:FF:FF:FF:FF SW IMEI[0]: 359160-06-974772-2 SW IMEI[1]: 352751-01-952326-7 SW IMEI[2]: 358570-01-010389-3 SW IMEI[3]: 910575-60-140046-8 SIMLOCK FLAG: ON FIXED NV BASE: 303C0000 Reading NV; NV saved to : NV_000000-00-000000-0_359160-06-974772-2_65310001_16_04_2017_05_43_11.spd IMEI: 359160-06-974772-2 UNLOCK CODE: 31524696 Re-programming; NV programmed; Done; Phone unlocked; Remove battery and cable; Log file saved to: LOG_16_04_2017_05_43_30.txt Time needed - 00:00:28 |
04-17-2017, 16:54 | #13659 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Dominican Republic
Member: 2382052 Status: Offline Thanks Meter: 1,511 | ALCATEL 6055U UNLOCK DONE Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@oem408.inf,%qcdownloaddiag%;Qualcomm HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM29 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22F8 IMEI: 01465800059274-0 PTH: 09 PTS: CAC PROV_ID: 6055U-2ARKUSC-2 SBTADDR: 20:A9:0E:E3:84:29 SWIFIADDR: 20:A9:0E:F5:36:B9 HS_PN: SAA363AAS11C SSN: F5KA11CB9KZ0171 Work id: 00FE90FB Done; SECURITY: X1C0UC00BX10 Size: 000002BF Backup saved to: 01465800059274-0 Backup file(s) removed; Unlocking; SIM_LOCK REMOVED ! Log file saved to: LOG_17_04_2017_11_51_41.txt Time needed - 00:29:34 |
04-18-2017, 07:05 | #13660 (permalink) |
Freak Poster Join Date: Nov 2009 Location: Mirpur Azad Kashmir Age: 34
Member: 1154111 Status: Offline Sonork: 100.1620855 Thanks Meter: 158 | vfd 300 unlock done furious gold pack 6 otsmart Using library Brom_DLL_v7.1522.2 Searching in normal mode; [connect the powered off to the usb cable] detected (MediaTek PreLoader USB VCOM () (COM51)) Preparing to mode; Preparing to open COM51 Connecting; Downloading DA; Initializing; Rid: bcec25b94d5240c459dd60ba3c1af9f5 Requesting baudrate ; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem181.inf,%vcom_da%;MediaTek DA USB VCOM ()) TRYING TO OPEN COM22; DEVICE INFO: BB CHIP: MT6580_S00 [CA00, 00, 6580, FF] HW_STORAGE_EMMC: 0x30000111 0x45473430 0x91270030 0xFD43CC77 [SIZE=0xEC480000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: V300-2BVDGB2 USRDATA INFO: 0x47000000 SIZE: 0x60000000 Searching data; Locked to [SIM1]: 234-15 code_cat_n: 9654589826597762 enabled: yes tries: 0 code_cat_ns: 4957604761903047 enabled: no tries: 10 code_cat_sp: 9077146077025256 enabled: no tries: 10 code_cat_c: 2327674908451254 enabled: no tries: 10 code_cat_sim: 9409919598990412 enabled: no tries: 10 code_cat_ns_sp: 8391823918787605 enabled: no tries: 5 code_cat_sim_c: 8313251747747286 enabled: no tries: 5 ed; Remove battery and cable; Time needed - 00:00:07 Log file saved to: LOG_18_04_2017_11_01_56.txt |
04-18-2017, 12:16 | #13661 (permalink) |
Member: 637351 Status: Offline Thanks Meter: 167 | vodafone 795 unlocked successfuly Code: Using library Brom_DLL_v7.1522.2 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM25)) Preparing to start flash mode; Preparing to open COM25 Connecting; Downloading DA; Initializing; Rid: a50b000c81ec4b8ee89d9f8b342f2223 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver\x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM42; DEVICE INFO: BB CHIP: MT6735M_S00 [CA00, 00, 335, FF] HW_STORAGE_EMMC: 0x51000115 0x4D533237 0x57B10042 0x37136696 [SIZE=0x1D2880000] IMEI1 [OTP 0001]: 352185-07-4xxxxx-x IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: V795-2AVDRO1 USRDATA INFO: 0x99000000 SIZE: 0x39880000 Searching data; Locked to [SIM1]: 226-01 code_cat_n: 2603712406310259 enabled: yes tries: 10 code_cat_ns: 1842905233155273 enabled: no tries: 10 code_cat_sp: 1500162048049001 enabled: no tries: 10 code_cat_c: 3206666641892794 enabled: no tries: 10 code_cat_sim: 6926172653115369 enabled: no tries: 10 code_cat_ns_sp: 6926172653115369 enabled: no tries: 5 code_cat_sim_c: 6926172653115369 enabled: no tries: 5 Phone unlocked; Remove battery and cable; Time needed - 00:00:07 |
04-18-2017, 12:23 | #13662 (permalink) |
Member: 637351 Status: Offline Thanks Meter: 167 | huawei y330 unlocked done [CODESearching phone; Phone detected (MediaTek PreLoader USB VCOM (Android)) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on MediaTek USB VCOM (Android) (COM248); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6572, E01 Sw version: MOLY.WR8.W1315.MD.WG.MP.V15.P10 Hw Version: HUAWEI72_WE_JB3_HSPA_HW Reading phone info; IMEI: 865705-02-1xxxxx-x Reading simlock info; Locked to: FFF-FF code_cat_n: FFFFFFFF enabled: no tries: 10 code_cat_ns: 56781234 enabled: no tries: 10 code_cat_sp: 11112222 enabled: no tries: 10 code_cat_c: 33334444 enabled: no tries: 10 code_cat_sim: 55556666 enabled: no tries: 10 code_cat_ns_sp: 77778888 enabled: no tries: 10 code_cat_sim_c: 99990000 enabled: no tries: 10 [/CODE] |
04-18-2017, 12:24 | #13663 (permalink) |
Member: 637351 Status: Offline Thanks Meter: 167 | huawei u2800 unlocked Code: Searching phone ... MODEL : Q62xx-OSBL- STARTING; OK; LOADING; DONE; STARTING AUTHORISATION; AUTHORISATION PASSED; INIT NAND ROUTINES; NAND INIT MADE; LOOKING SENSITIVE DATA; OK; DONE; IMEI : 861941010xxxxx-x READING; SP_SAVED_TO: SP_861941_E77_14.38.23_15.02.2017_HUAWEI.bin ERASING; WRITING; SIM_LOCK REMOVED ! DONE ! RESET ! Time needed - 00:01:25 |
04-18-2017, 12:26 | #13664 (permalink) |
Member: 637351 Status: Offline Thanks Meter: 167 | another vf795 unlocked done Code: Using library Brom_DLL_v7.1522.2 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM25)) Preparing to start flash mode; Preparing to open COM25 Connecting; Downloading DA; Initializing; Rid: 8377714e60f6deb9bf0b2baaaaeb2617 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver\x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM42; DEVICE INFO: BB CHIP: MT6735M_S00 [CA00, 00, 335, FF] HW_STORAGE_EMMC: 0x51000115 0x4D533237 0x7E6D0042 0x274372F2 [SIZE=0x1D2880000] IMEI1 [OTP 0001]: 352185-07-xxxxxx-x IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: V795-2AVDRO1 USRDATA INFO: 0x99000000 SIZE: 0x39880000 Searching data; Locked to [SIM1]: 226-01 code_cat_n: 7377498910786000 enabled: yes tries: 10 code_cat_ns: 4207184104536760 enabled: no tries: 10 code_cat_sp: 7624782543353152 enabled: no tries: 10 code_cat_c: 2756758344431240 enabled: no tries: 10 code_cat_sim: 6832547845223548 enabled: no tries: 10 code_cat_ns_sp: 6832547845223548 enabled: no tries: 5 code_cat_sim_c: 6832547845223548 enabled: no tries: 5 Phone unlocked; Remove battery and cable; Time needed - 00:00:06 |
04-18-2017, 18:47 | #13665 (permalink) |
Member: 2382052 Status: Offline Thanks Meter: 1,511 | ALCATEL 6039A UNLOCK DONE Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@oem408.inf,%qcdownloaddiag%;Qualcomm HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM29 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22D4 IMEI: 01436800047165-1 PTH: 24 PTS: AK7 PROV_ID: 6039A-2ARGDO7 SBTADDR: 1C:CB:99:6FC:63 SWIFIADDR: 1C:CB:99:6FC:64 HS_PN: SAA34D1AC10C SSN: PVKL16BBVNY02KO Work id: 14E8B7B4 Setup 1; Done; Setup 2; Done; Setup 3; Done; Uploading; Done; SECURITY: X1A0NJ00BQ10 Size: 00000430 Backup saved to: 01436800047165-1 Backup file(s) removed; Checking the simlock; Magic ok; Unlocking; SIM_LOCK REMOVED ! Log file saved to: LOG_18_04_2017_13_40_08.txt Time needed - 00:00:43 |
