Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > NSPRO
Old 10-10-2012, 22:39   #31 (permalink)
Elco's Avatar
Member: 19254
Sonork: 100.72990
Thanks Meter: 25,395
Originally Posted by waqas9 View Post
are you able to tell me where i can purchase this online please??
a quick google search returned this: NS Pro UART Cable for Samsung S7070
there are more: Google
Old 10-11-2012, 06:49   #32 (permalink)
cycofcgb's Avatar
Member: 1388004
Sonork: 100.1637034
Thanks Meter: 444
About that point, if I borrow nspro for test from a shop I know, may I use an other box as my useless eubox as comport until time I receive nspro cables or may that cause security problem ?
Old 10-11-2012, 07:26   #33 (permalink)
Elco's Avatar
Member: 19254
Sonork: 100.72990
NsPro software work only with Nspro box. You cant chose the com port on nspro software. so it work work with any other box.
The Following User Says Thank You to Elco For This Useful Post:
Old 10-11-2012, 07:27   #34 (permalink)
cycofcgb's Avatar
Member: 1388004
Sonork: 100.1637034
Thanks Meter: 444
Great, if test succeed, I buy one the minute after.
Old 10-17-2012, 15:20   #35 (permalink)
simlock's Avatar
Member: 14047
Thanks Meter: 166
hi bro i just checked these guys and they said it will work
Samsung S7070 / C3300 UART NS Pro / UFS Service Cable - Service & Data Cables cable is here with -+ leads thanks .................br
Old 10-17-2012, 18:22   #36 (permalink)
Elco's Avatar
Member: 19254
Sonork: 100.72990
? i never saw that cable with +/- leads...
Anyway, if the cable is made acording to NsPro schematic, it will work.
You wont need that +/- leads when using the cable with NsPro...
Old 10-18-2012, 02:04   #37 (permalink)
Member: 1414663
nspro great job
After messed about the imei with Z3x all my imei and SN became 004 and 0000, really made me jump, after few hours research over the internet found few solutions over the xda fourm and some chinese website but they are rather complicated then the NSpro. Bought this box for a while, never really using it for anything, but this time nspro I have to give u a A for your work.
Well done NS Pro team and keep up.
Old 10-18-2012, 23:34   #38 (permalink)
Crazy Poster
Member: 1435802
Thanks Meter: 7
hi using 6.4.2 root i9300 using the file on ns pro support followed the steps now imei 0049 any way to fix this? 2 phones the same i know i must be doing something wrong
Preparing Phone...
Resetting IMEI...
Connecting to phone UART...
Using Advanced MSL...
Bypasing Security...
Setting Serial Number...
Writing IMEI...
Resetting Phone...
Operation successfully completed
Old 10-19-2012, 14:28   #39 (permalink)
simlock's Avatar
Member: 14047
Thanks Meter: 166
hi bro can i ask do i need to reflash the fone before this imei repair ??? thanks......................................br
Old 10-19-2012, 14:51   #40 (permalink)
simlock's Avatar
Member: 14047
Thanks Meter: 166
hay bro can i send you pic of this cable i have please i need help to make shore its correct i dont thin it is the resiter in your support has resister on different side to wire but i dont know how to wire it corecly thanks ........................................br
Old 10-19-2012, 15:13   #41 (permalink)
simlock's Avatar
Member: 14047
Thanks Meter: 166
if i need resister which one do i buy i have **** 560k resister 1/4 wat (0.25w) or 560k 1/2 wat (0.25) which one do i need i have checked resister on cable i have bout and it dont look the same or are there dofferent types ????........................br
Old 10-19-2012, 17:34   #42 (permalink)
Elco's Avatar
Member: 19254
Sonork: 100.72990
you can use any resistor size. 0,25w is more indicated because is smaller.
Old 10-19-2012, 18:14   #43 (permalink)
simlock's Avatar
Member: 14047
Thanks Meter: 166
ok thanks i dont understand how to use schmatics for cable buold i have cable but it doesnt work just get failed do i need to flash the phone first the phone is rooted using nspro root and unlocked also when it say conect uart cable after restart my phone doesnt restart jsut stays on ???.........................br
Old 10-19-2012, 18:47   #44 (permalink)
Member: 37341
Originally Posted by nd20yktan View Post
After imei repair, can we flash or update the original software without losing the network, anyone tried..?
Thank you.
you can flash whatever you want, just make sure the modem in untouched
Old 10-19-2012, 18:48   #45 (permalink)
Member: 37341
Originally Posted by sameenshah123 View Post
if u change imei and after that update firmware and dont loose network.then nespro first in the world. there is no box sport not loose network after update firmware.
i have managed to update my firmware, change roms or whatever
just made sure the modem isnt touched and everything works gr8
Page generated in 0.19657 seconds with 9 queries
