Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > NSPRO
Old 10-20-2012, 09:44   #46 (permalink)
Kanwalgee's Avatar
Member: 68392
Sonork: 100.100701
Thanks Meter: 658
Preparing Phone...
Resetting IMEI...
Connecting to phone UART...
Using Advanced MSL...
Bypasing Security...
Setting Serial Number...
Writing IMEI...
Resetting Phone...
Operation successfully completed
Yes tested working on rooted phone.
Old 10-20-2012, 12:16   #47 (permalink)
simlock's Avatar
Member: 14047
Thanks Meter: 166
very nice bro where did you buy your cable ??................................................ ................br
Old 10-20-2012, 12:28   #48 (permalink)
Member: 515637
Thanks Meter: 13
Hi, i need repair imei damage, 004999.....
Resisto in cable is 560 k or 130 k,,tnk in advance
http://www.subirimagenes.net/show-im...af376fc4632d40
Old 10-20-2012, 12:58   #49 (permalink)
Member: 515637
Thanks Meter: 13
Preparing Phone...
Resetting IMEI...
Operacion no completada!
Old 10-20-2012, 16:50   #50 (permalink)
el-polaco's Avatar
Member: 1057178
Sonork: Kfe~Labs Co.-
Thanks Meter: 569
Originally Posted by otrebor2 View Post
Preparing Phone...
Resetting IMEI...
Full 100% Cable Problem. Cant conect the Phone
By ELCO
(just make sure you are using NsPro S7070 cable and will work just fine)
Tested Many time
br
Polaco
Old 10-20-2012, 23:07   #51 (permalink)
simlock's Avatar
Member: 14047
Thanks Meter: 166
Subir Imagenes Gratis - Free Image Hosting
hi bro resister 560 k NOT 130 the pic is good share thanks .......................br
Old 10-22-2012, 11:48   #52 (permalink)
simlock's Avatar
Member: 14047
Thanks Meter: 166
i9300 cable correct wired ?
hi i bought this cable from completefonesolution can anyone tell me if it is correctly wired as uart for imei repair i9300 ............and can tell me correct way if its not thanks ................................................br
Old 10-22-2012, 16:39   #53 (permalink)
simlock's Avatar
Member: 14047
Thanks Meter: 166
Originally Posted by simlock View Post
hi bro i just checked these guys and they said it will work
Samsung S7070 / C3300 UART NS Pro / UFS Service Cable - Service & Data Cables cable is here with -+ leads thanks .................br
ok all my problems solved thanks to nspro team my customer is very happy i fixed his 004900 problem
i flashed my phone with flash from support dont know if i needed to but i did
i rooted the phone with rooted file form support
i keyed in *#7284#
top one is put uart modem
bottom one i left usb pda
i conected to nspro and wrote original imei and original serial
when it asked uart i conected and all is good
the cable i bought from above was perfect so if your in the uk get it hope this helps anyone else trying to fix this problem........................................... ..br
The Following User Says Thank You to simlock For This Useful Post:
Old 10-23-2012, 12:40   #54 (permalink)
mrfixit's Avatar
Member: 60899
Thanks Meter: 792
not 560 it must be 530 kohm (check with meter)
Old 11-04-2012, 13:36   #55 (permalink)
tareen's Avatar
Member: 80475
Thanks Meter: 6
where is i9300 patch file in support area i cant find it also root file when downloaded is not comming as zip file
Old 11-04-2012, 15:16   #56 (permalink)
el-polaco's Avatar
Member: 1057178
Thanks Meter: 569
are you download a last version?
http://forum.gsmhosting.com/vbb/f475...added-1561052/
br
polaco
Old 11-04-2012, 18:12   #57 (permalink)
Elco's Avatar
Member: 19254
Sonork: 100.72990
Thanks Meter: 25,395
The patch was removed because is incompatible with latest i9300 firmware versions.
You must use Root file instead.
About
please READ!!! the message on the top of Support area page:
Old 11-13-2012, 16:35   #58 (permalink)
00aa's Avatar
Member: 508100
Sonork: 1600934
Thanks Meter: 189
hi elco,
need your help.. i have fixed my i9300 imei (which was damaged 004456) now imei is good sn number is also ok but there is no network
need urgent help..
Old 11-13-2012, 16:50   #59 (permalink)
Elco's Avatar
Member: 19254
Sonork: 100.72990
Originally Posted by 00aa View Post
hi elco,
need urgent help..
1. Flash the phone with original firmware
2. Root the phone with root file from NsPro support area
3. Write IMEI again using NsPro v6.5.1
After writing IMEI by NsPro, the phone network will be OK
If still no network after IMEI write by NsPro, check the phone for hardware problems.
Next time when you post about a problem with Nspro, plz post a screenshot with Nspro software operation so i can see what chould be the problem.
IMEi write is tested and 100% working on NsPro.
Also the phone network is OK after IMEI write:
Old 11-23-2012, 20:00   #60 (permalink)
karlux's Avatar
Member: 1218089
Sonork: 100.1615672
Thanks Meter: 8
in my case, i can only repair the serial number, the imei stills 00499901... and i have network but when i call to my s3 from other phone, i cant reach it.
Page generated in 0.20810 seconds with 9 queries
