06-15-2018, 13:33 | #1021 (permalink) | |
No Life Poster Join Date: Mar 2009 Location: earth
Member: 992568 Status: Offline Sonork: kulit Thanks Meter: 231 | Quote:
06-16-2018, 12:31 | #1023 (permalink) | |
before this happened i iwas remember if i not mistaken i use the dongle for read buckup cherry mobile phone i dont remember if s4 or s3 2days after that i open my cm2 tab and thats what happen is show warning misconfiguration and i also install latest cm2 r4 2days before that accident after my read opartion i installed cm2 new version i check it and it open then im contented to exit and wait till have customer thats the story | |
06-16-2018, 13:35 | #1024 (permalink) | |
06-16-2018, 14:23 | #1025 (permalink) | |
here http://forum.gsmhosting.com/vbb/f296...40/index2.html i dont know whos that person is the 0ne were i bought my dongle | |
06-16-2018, 14:31 | #1026 (permalink) | |
Let me ask you once again - please use only one thread for the same problem. Thank you ! | |
06-17-2018, 12:25 | #1027 (permalink) |
Junior Member Join Date: Jun 2018
Member: 2844611 Status: Offline Thanks Meter: 0 | === DongleManager [Infinity] v1.72 [2018/6/17 19:15:17] === Searching... Card-Reader: FT SCR2000 0 HWID: 0003597100001942 Box/Dongle found: Infinity-Box/Dongle Serial No (S/N): 44F75971 Firmware version: 0136.02 Box/Dongle misconfiguration Diagnostic code: 52 "UK Edition" status: On Last launched Application: 0030 v.0136 => Activations: - 00: Infinity-Box/Dongle v.0136 Diagnostic Key: 7F2527381AE260BC Sir when i open CM2 in backgroud, I open the USBTrace for another reason.I didn't notice that will effect CM2.I have already uninstall my USBTrace,but it didn't fix the problem. I am sorry for that! Please help me sir, thanks! |
06-18-2018, 07:26 | #1028 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
What to do: 1. Install required Card-Reader Drivers: - File with Drivers: CardReader_Fetian_FT2K.7z - File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 Download files - http://www.infinity-box.com/support/?r=6 OR 1. Insert Smart-Card into another Card-Reader (good result for today is with Alcor Card-Reader) The next steps are: 2. Run DongleManager 3. Update Dongle firmware - DO NOT update Smart-Card many times otherwise your account will be locked automatically after 3 tries for 24 hours - DO NOT use any kind of usb sharing/trace/spy/debug software to avoid problem with Dongle ! | |
06-20-2018, 19:29 | #1029 (permalink) |
Freak Poster Join Date: Jul 2014 Location: Erode TAMILnadu INDIA
Member: 2231748 Status: Offline Sonork: whatsapp 09942395196 Thanks Meter: 107 | cm2scr required firmware update so i try to firmware update, but failed also my cm2 activated cdma tool card not work see my update log....help me Box/Dongle found: CDMA-Tool Serial No (S/N): 2BFB7C85 Firmware version: 0122.02 "UK Edition" status: Off Last launched Application: 0030 v.0158 => Activations: - 00: Infinity-Box/Dongle v.0136 - 01: CDMA-Tool v.0122 - 07: module #07 === DongleManager [Infinity] v1.70 [6/20/2018 21:56:01] === Box/Dongle type selected: CDMA-Tool Card-Reader: FT SCR2000 0 HWID: 02007C851D041292 Box/Dongle found: CDMA-Tool Reading... Serial No (S/N): 2BFB7C85 Firmware version: 0122.02 === Process started: 6/20/2018 21:56:03 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication successfull Service stage 1 confirmed Securing session... Session secured ok Upgrading dongle... Wait 4-5 minutes ! DO NOT disconnect Box/Dongle ! Card returned error - 0000 at 1103/9937 Error upgrading applets: Card returned error - 0000 at 1103/9937 Disconnected now it says == DongleManager [Infinity] v1.70 [6/20/2018 23:42:24] === Box/Dongle type selected: CDMA-Tool Card-Reader: FT SCR2000 1 HWID: 02007C851D041292 === Process started: 6/20/2018 23:42:25 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 |
06-21-2018, 12:01 | #1030 (permalink) | |
06-21-2018, 18:23 | #1031 (permalink) | |
Member: 2231748 Status: Offline Sonork: whatsapp 09942395196 Thanks Meter: 107 | Quote:
Is there any bugs or driver updation must? coz, the card worked in the same dongle before update any how, thanks for quick response | |
06-22-2018, 10:09 | #1032 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | You are replying to post with instruction and links to SPECIAL drivers, so answer is: yes, you should install special drivers or you can use another card-reader type in case of any problem with update. |
06-26-2018, 10:00 | #1033 (permalink) |
Junior Member Join Date: Sep 2016 Location: philippines
Member: 2622128 Status: Offline Thanks Meter: 0 | Hello sir please fix my cm2 always Dongle misconfiguration.. === DongleManager [Infinity] v1.72 [6/26/2018 16:55:50] === Searching... Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 0001172E13114082 Box/Dongle found: Infinity-Box/Dongle Serial No (S/N): 8DC1172E Firmware version: 0136.02 Box/Dongle misconfiguration Diagnostic code: 54 "UK Edition" status: On Last launched Application: 0030 v.0158 => Activations: - 00: Infinity-Box/Dongle v.0136 Diagnostic Key: 7FB783A55CA8BDD6 |
06-27-2018, 11:15 | #1034 (permalink) | |
To avoid software conflicts in future please do not use "snoopy flashtool" at the same time with Infinity software. What to do now: - Delete fault.bin file from software folder (if you have it there) - Install latest Infinity software updates - Run DongleManager - Update Dongle firmware | |
07-11-2018, 11:12 | #1035 (permalink) |
Major Poster Join Date: Jul 2015
Member: 2432275 Status: Offline Thanks Meter: 6 | === DongleManager [Infinity] v1.70 [11.07.2018 11:54:45] === Searching... Card-Reader: Generic EMV Smartcard Reader 0 HWID: 00003B4B12534082 Box/Dongle found: Infinity-Box/Dongle Serial No (S/N): ABEF3B4B Firmware version: 0137.02 Box/Dongle misconfiguration Diagnostic code: 5A "UK Edition" status: Off Last launched Application: 0034 v.0137 => Activations: - 00: Infinity-Box/Dongle v.0137 - 07: module #07 Diagnostic Key: 7F87889115E5C1C3 |
