10-28-2018, 08:41 | #1171 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
To avoid software conflicts in future please do not use "Hexframe" at the same time with Infinity software. What to do now: - Delete fault.bin file from software folder (if you have it there) - Install latest Infinity software updates - Run DongleManager - Update Dongle firmware IMPORTANT: only ONE update try is allowed so in case of problem DO NOT try to update card again ! | |
10-30-2018, 09:24 | #1172 (permalink) |
Junior Member Join Date: Aug 2016
Member: 2616144 Status: Offline Thanks Meter: 1 | misconfiguration error === DongleManager [Infinity] v1.70 [10/30/2018 1:03:16] === Searching... Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 000015B511384082 Box/Dongle found: Infinity-Box/Dongle Serial No (S/N): 9BE115B5 Firmware version: 0136.02 Box/Dongle misconfiguration Diagnostic code: 5A "UK Edition" status: On Last launched Application: 0030 v.0158 => Activations: - 00: Infinity-Box/Dongle v.0136 Diagnostic Key: 7F00C18AAB92F053 |
10-31-2018, 12:44 | #1173 (permalink) | |
11-01-2018, 06:08 | #1174 (permalink) | |
Freak Poster Join Date: Feb 2007 Location: cavite phils.
Member: 455665 Status: Offline Thanks Meter: 36 | Goodmorning Infinity CM2 support, I have similar problem, how can I fix this? and where can I found the fault.bin? Thank you. Quote:
11-01-2018, 11:33 | #1175 (permalink) | |
fault.bin file is in folder with CM2 software module that you have run last time. Attach file here or send info and file via e-mail: help [at] infinity-box.com | |
11-02-2018, 06:22 | #1176 (permalink) | |
Member: 455665 Status: Offline Thanks Meter: 36 | I found at CM2QLM folder Quote:
11-03-2018, 05:41 | #1178 (permalink) |
Member: 455665 Status: Offline Thanks Meter: 36 | Infinity Team/support. I remember last time, I installed "drivesecurity-installer.exe" for usb security and after that, this was happen to my cm2. Thank You, My problem is solved. |
11-06-2018, 04:58 | #1181 (permalink) |
Junior Member Join Date: Jul 2017
Member: 2742457 Status: Offline Thanks Meter: 0 | Hello. pls help me i change pc new and update fw but not ok === DongleManager [Infinity] v1.72 [06/11/2018 10:51:18] === Searching... Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 000093EF1CC74082 Box/Dongle found: Infinity-Box/Dongle Serial No (S/N): 196093EF Firmware version: 0137.02 Box/Dongle misconfiguration Diagnostic code: 57 "UK Edition" status: On Last launched Application: 0030 v.0137 => Activations: - 00: Infinity-Box/Dongle v.0137 - 07: #7 Diagnostic Key: 7F90468EC3D871C7 |
11-06-2018, 07:54 | #1182 (permalink) | |
Have you fixed your PC according to instruction for error #57 (see first post in current thread) ? | |
11-07-2018, 10:44 | #1184 (permalink) |
Insane Poster Join Date: Feb 2008
Member: 713735 Status: Offline Thanks Meter: 10 | infinity team please solve my problom (only BEST is work)best2 spd qlm mtk and all other not work best dongle is active Token - Type: Infinity [BEST] - Account Status: Active - Hardware Status: Ok Services - Activation 1: Infinity-Box/Dongle; Firmware Version: 0137; Registered: 19-Sep-2018; Expired: 20-Sep-2019; Support: Active - Activation 2: Infinity [BEST]; S/N: A45CA25F; Firmware Version: 0122 - More Services may be active but not listed when tried update dongle manager DongleManager [Infinity] v1.72 [11/7/2018 11:09:42] === Searching... Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 0003A25F18201292 Box/Dongle found: [BEST] Serial No (S/N): A45CA25F Firmware version: 0122.02 "UK Edition" status: On Last launched Application: 0030 v.0229 => Activations: - 00: Infinity-Box/Dongle v.0137 - 03: [BEST] v.0122 === DongleManager [Infinity] v1.72 [11/7/2018 11:09:48] === Box/Dongle type selected: [BEST] Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 0003A25F18201292 Box/Dongle found: [BEST] Reading... Serial No (S/N): A45CA25F Firmware version: 0122.02 === Process started: 11/7/2018 11:09:49 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0007] No updates found for your Smart-Card. DO NOT try more today ! |
11-08-2018, 07:23 | #1185 (permalink) |
Member: 713735 Status: Offline Thanks Meter: 10 | infinity team please solve my problom infinity team please solve my problom (only BEST is work)best2 spd qlm mtk and all other not work best dongle is active Token - Type: Infinity [BEST] - Account Status: Active - Hardware Status: Ok Services - Activation 1: Infinity-Box/Dongle; Firmware Version: 0137; Registered: 19-Sep-2018; Expired: 20-Sep-2019; Support: Active - Activation 2: Infinity [BEST]; S/N: A45CA25F; Firmware Version: 0122 - More Services may be active but not listed when tried update dongle manager DongleManager [Infinity] v1.72 [11/7/2018 11:09:42] === Searching... Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 0003A25F18201292 Box/Dongle found: [BEST] Serial No (S/N): A45CA25F Firmware version: 0122.02 "UK Edition" status: On Last launched Application: 0030 v.0229 => Activations: - 00: Infinity-Box/Dongle v.0137 - 03: [BEST] v.0122 === DongleManager [Infinity] v1.72 [11/7/2018 11:09:48] === Box/Dongle type selected: [BEST] Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 0003A25F18201292 Box/Dongle found: [BEST] Reading... Serial No (S/N): A45CA25F Firmware version: 0122.02 === Process started: 11/7/2018 11:09:49 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0007] No updates found for your Smart-Card. DO NOT try more today ! |
