11-08-2018, 10:49 | #1186 (permalink) |
Junior Member Join Date: Jul 2017
Member: 2742457 Status: Offline Thanks Meter: 0 | Originally Posted by InfinitySupport View Post Hello, Have you fixed your PC according to instruction for error #57 (see first post in current thread) ? Yes, I fixed the error 57. And to make sure I installed cm2 to the new computer to test again, but not ok Hello |
11-08-2018, 18:19 | #1188 (permalink) | |
if you have a problem with software you should create new thread and explain the problem in details. | |
11-09-2018, 06:52 | #1189 (permalink) |
Insane Poster Join Date: Feb 2008
Member: 713735 Status: Offline Thanks Meter: 10 | only work is best exe --best 2..spd.mtk and other exe not open only work is best exe --best 2..spd.mtk and other exe not open sir i Registered: 19-Sep-2018; Expired: 20-Sep-2019; Support: Active previous ten days only work best exe other exe not open and no work i re install all soft best and cm2 only open best exe other exe not open and not any show error |
11-09-2018, 07:59 | #1190 (permalink) | |
Dear Sir, Current thread is related to dongle problems. Your dongle has no problem so please follow the advice that you have got earlier. If you have a problem with software you should create new thread and explain the problem in details. Thank you very much for your kind problem explanation ! | |
11-10-2018, 09:25 | #1195 (permalink) | |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Quote: What is your dongle support validity date ? How to check - https://www.infinity-box.com/doc/?r=17 If support is expired please contact to any seller and renew support. | |
11-10-2018, 12:06 | #1196 (permalink) |
Member: 713735 Status: Offline Thanks Meter: 10 | infinity team help sir already active - Type: Infinity [BEST] - Account Status: Active - Hardware Status: Ok Services - Activation 1: Infinity-Box/Dongle; Firmware Version: 0137; Registered: 19-Sep-2018; Expired: 20-Sep-2019; Support: Active - Activation 2: Infinity [BEST]; S/N: A45CA25F; Firmware Version: 0122 - More Services may be active but not listed https: //photos.app.goo.gl/EFS3F2mRMh9BRcWU8 |
11-10-2018, 15:32 | #1197 (permalink) | |
if you continue to attack servere with card update you will kill your card in 1 day. good luck ! | |
11-11-2018, 05:26 | #1198 (permalink) |
Member: 713735 Status: Offline Thanks Meter: 10 | Explain how the head will solve my problem Please do it Originally Posted by saghirdhadkan View Post sir already active - Type: Infinity [BEST] - Account Status: Active - Hardware Status: Ok Services - Activation 1: Infinity-Box/Dongle; Firmware Version: 0137; Registered: 19-Sep-2018; Expired: 20-Sep-2019; Support: Active - Activation 2: Infinity [BEST]; S/N: A45CA25F; Firmware Version: 0122 - More Services may be active but not listed https: //photos.app.goo.gl/EFS3F2mRMh9BRcWU8 your card is ok. if you continue to attack servere with card update you will kill your card in 1 day. good luck ! Explain how the head will solve my problem Please do it |
11-12-2018, 11:07 | #1199 (permalink) | |
if you have a problem you must create new thread and explain the problem well | |
