01-14-2020, 17:37 | #1398 (permalink) |
Junior Member Join Date: Dec 2013
Member: 2090389 Status: Offline Thanks Meter: 1 | Box/Dongle type Infinity-Box/Dongle Generic EMV Smartcard Reader 0 HWID: 0001280F1F394082 Infinity-Box/Dongle Serial No (S/N): 0C55280F Firmware version: 0138.02 === Process started: 08-Jan-20 16:43:42 === Server connection successfully established DongleManager is up-to-date Authentication stage error: Server answer:[0031] Dongle identification data damaged. Need Help |
01-14-2020, 19:07 | #1399 (permalink) | |
01-28-2020, 12:39 | #1400 (permalink) |
Insane Poster Join Date: Dec 2009 Location: shahkot
Member: 1195673 Status: Offline Sonork: rehanisrar Thanks Meter: 2 | solve problem === DongleManager [Infinity] v1.72 [1/28/2020 16:36:38] === Searching... Card-Reader: FT SCR2000 0 HWID: 0102827B10321292 Box/Dongle is not found update error card next update == DongleManager [Infinity] v1.72 [1/28/2020 16:38:10] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: FT SCR2000 0 HWID: 0102827B10321292 === Process started: 1/28/2020 16:38:10 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 |
01-28-2020, 15:14 | #1401 (permalink) | |
Install required Card-Reader Drivers: - File with Drivers: CardReader_Fetian_FT2K.7z - File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 Download files - https://www.infinity-box.com/support/?r=6 OR Insert Smart-Card into another Card-Reader (good result for today is with Alcor Card-Reader) The next steps are: - run DongleManager - update Dongle firmware IMPORTANT: only ONE update try is allowed so in case of problem DO NOT try to update card again ! | |
02-27-2020, 14:34 | #1402 (permalink) |
Junior Member Join Date: Sep 2016
Member: 2630440 Status: Offline Thanks Meter: 0 | === DongleManager [Infinity] v1.72 [27/02/2020 15:30:57] === Searching... Card-Reader: FT SCR2000 0 HWID: 000358E400001942 Box/Dongle found: Infinity-Box/Dongle Serial No (S/N): 457E58E4 Firmware version: 0139.02 Box/Dongle misconfiguration Diagnostic code: 57 "UK Edition" status: On Last launched Application: 0032 v.0139 => Activations: - 00: Infinity-Box/Dongle v.0139 Diagnostic Key: 7FD3D3FAABF9C705 |
02-27-2020, 18:38 | #1403 (permalink) | |
Fix PC as per instruction from post #1 and then update dongle firmware with DongleManager. | |
05-20-2020, 20:09 | #1404 (permalink) |
Junior Member Join Date: Jun 2009 Location: Kazakhstan Lisakovsk
Member: 1055161 Status: Offline Thanks Meter: 1 | === DongleManager [Infinity] v1.80 [2020-05-21 1:03:05] === Searching... Card-Reader: USB CCID Smart Card Reader 0 HWID: 0001E5F200001942 Box/Dongle found: Infinity-Box/Dongle Serial No (S/N): 90BBE5F2 Firmware version: 0143.02 Box/Dongle misconfiguration Diagnostic code: 70 "UK Edition" status: Off Last launched Application: 0030 v.0143 => Activations: - 00: Infinity-Box/Dongle v0143 - 07: #7 => Options: - Infinity-Box/Dongle - Infinity SM |
05-20-2020, 20:12 | #1405 (permalink) | |
upload here fault.bin file from Infinity software folder | |
05-20-2020, 23:26 | #1406 (permalink) |
Junior Member Join Date: May 2009
Member: 1032636 Status: Offline Thanks Meter: 0 | === DongleManager [Infinity] v1.80 [21.05.2020 3:19:31] === Searching... Card-Reader: Gemalto e-gate Smart Card 0 HWID: 00032E6600001942 Box/Dongle found: Infinity-Box/Dongle Serial No (S/N): C2B72E66 Firmware version: 0143.02 Box/Dongle misconfiguration Diagnostic code: 70 "UK Edition" status: Off Last launched Application: 0030 v.0143 => Activations: - 00: Infinity-Box/Dongle v0143 - 03: [BEST] v0122 - 07: #7 => Options: - Infinity-Box/Dongle - Infinity SM |
05-20-2020, 23:46 | #1407 (permalink) | |
As I can see you have got an instruction via e-mail already. | |
05-21-2020, 02:44 | #1408 (permalink) |
Freak Poster Join Date: Dec 2017 Location: philippines
Member: 2785467 Status: Offline Sonork: 100.1679506 Thanks Meter: 28 | please give solution for this fault.bin with my infinity exe sir link https://mega.nz/file/aH5lhRqD#f_8xsh...kGyzFhMPIs069M |
The Following User Says Thank You to azofs For This Useful Post: |
05-21-2020, 12:43 | #1409 (permalink) |
Junior Member Join Date: Nov 2010 Location: algeria
Member: 1443647 Status: Offline Thanks Meter: 2 | fix my problem pleas === DongleManager [Infinity] v1.80 [2020-05-21 12:34:57] === Searching... Card-Reader: Alcorlink USB Smart Card Reader 0 HWID: 0107A67524881292 Box/Dongle found: [BEST] Serial No (S/N): 0DA2A675 Firmware version: 0122.02 Box/Dongle misconfiguration Diagnostic code: 70 "UK Edition" status: Off Last launched Application: 0030 v.0143 => Activations: - 00: Infinity-Box/Dongle v0143 - 03: [BEST] v0122 - 07: #7 => Options: - Infinity BEST - Infinity SM fault file https://mega.nz/file/9cFAQY6a#XxdRyP...1KRM1ezINYeH24 Last edited by bouzihak88; 05-21-2020 at 12:53. |
05-21-2020, 13:24 | #1410 (permalink) | |
Member: 1055161 Status: Offline Thanks Meter: 1 | Quote:
https://mega.nz/file/2yBVUQjK#qaicjv...czUyqGXXtH7rQU | |
