=== DongleManager [Infinity] v1.72 [23/01/2020 19:27:38] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Generic CCID Smart Card Reader 0 HWID: 00075A8C19801292 === Process started: 23/01/2020 19:27:38 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication successfull Service stage 1 confirmed Securing session... Session secured ok Upgrading dongle... Wait 4-5 minutes ! DO NOT disconnect Box/Dongle ! Error upgrading applets: Card returned error - 6982 at 1031/8681 |
i have infinity best dongal. and activated cm2 tool. but only working 1.58v version only . contact infinity team but not answer correct any help |
team always answer so if you get no answer it means you have used wrong way to contact ! what is the s/n ? |
serial this Quote:
sandunmobile === DongleManager [Infinity] v1.72 [1/24/2020 13:19:16] === Box/Dongle type selected: [BEST] Card-Reader: Generic EMV Smartcard Reader 0 HWID: 000137E07F634082 Box/Dongle found: [BEST] Reading... Serial No (S/N): 8F5737E0 Firmware version: 0122.02 === Process started: 1/24/2020 13:19:17 === Connecting to server Connection to server failedSocket Error # 10061 Connection refused. |
Why do you want to update it again ? |
please post here text from DongleManager window. |
=== DongleManager [Infinity] v1.72 [1/29/2020 20:15:20] === Searching... Card-Reader: FT SCR2000 0 HWID: 0003986C20281292 Box/Dongle found: [BEST] Serial No (S/N): 96DE986C Firmware version: 0122.02 "UK Edition" status: Off Last launched Application: 0030 v.0229 => Activations: - 00: Infinity-Box/Dongle v.0139 - 03: [BEST] v.0122 - 07: #7 - 0E: #14 => Box/Dongle misconfiguration. Contact to support ! after last update dongle manager freeze and close buy it self . now all infinity product work fine but hua not working |
Install required Card-Reader Drivers: - File with Drivers: CardReader_Fetian_FT2K.7z - File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 Download files - https://www.infinity-box.com/support/?r=6 OR Insert Smart-Card into another Card-Reader (good result for today is with Alcor Card-Reader) The next steps are: - run DongleManager - update Dongle firmware IMPORTANT: only ONE update try is allowed so in case of problem DO NOT try to update card again ! |
Hi After long time when todys i used infinity best i have face this problems ==== [30-Jan-20 14:59:09] ==== Smart-Card update process may takes up to 4-5 minutes to complete. During update process software may seem hanging but please DO NOT close or terminate forcely application. It may cause harm to your Smart-Card. Just let the process to be finished. - Connect Infinity Box/Dongle (Smart-Card) to PC - Disconnect all other Boxes/Dongles (Smart-Card) from PC - Update Smart-Card Reader drivers to latest version - Disable Antivirus and Firewall - DO NOT interrupt update process even if you think that software is freez ! === DongleManager [Infinity] v1.72 [30-Jan-20 14:59:14] === Searching... Card-Reader: FT SCR2000 0 HWID: 00058F7015BF1292 Box/Dongle is not found === DongleManager [Infinity] v1.72 [30-Jan-20 14:59:21] === Searching... Card-Reader: FT SCR2000 0 HWID: 00058F7015BF1292 Select Token Type: instead of Autodetect === DongleManager [Infinity] v1.72 [30-Jan-20 14:59:27] === Box/Dongle type selected: [BEST] Card-Reader: FT SCR2000 0 HWID: 00058F7015BF1292 === Process started: 30-Jan-20 14:59:27 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 Serial Number ==== [30-Jan-20 14:52:28] ==== Infinity-Box CardID v1.09 Card-Reader: FT SCR2000 0 ATR: 3B7D95000080318065B0831148C883009000 Card Manager: A000000018434D00 SerialNumber: 00058F70 ROM: Integrated Circuit Fabricator: 4250 Integrated Circuit Type: 3272 OS: Identifier: 1291 Release Date: 6181 Release Level: 0700 EEPROM: Fabrication Date: 3172 Serial Number: 00058F70 Batch Identifier: 15BF Module Fabricator: 1292 Module Packaging Date: 4252 IC Card Manufacturer: 2003 IC Em******* Date: 4252 Pre Personalizer: 2004 Pre Personalization Date: 4252 Pre Personalization Equipment Identifier: 00000044 Personalizer: 0000 Personalization Date: 0000 Personalization Equipment Identifier: 00000000 m_iopCard.Serial: 00058F7015BF1292 GP Version: 2.1.1 SCP Version: 1, Option: 5 Plz help Support Team |
i followed the step and work for me . |
Thank you for your reply frn but I tryed many card reader but my problems is not solved Sent from my Mi A1 using Tapatalk |
do you understand thisn perfect idea ? so I suggest you follow the previous instruction exactly ! |
