There is a software conflict with this application: \program files\renesas electronics\usb 3.0 host controller driver\application\nusb3mon.exe - Disable this process - delete fault.bn file - update dongle firmware with DongleManager now and then run Infinity software. Team is working to fix this compatibility issue. |
Please attach here fault.bin file from Infinity software folder. |
https://gofile.io/d/IgNXvf can you do it from here sir? |
\program files\renesas electronics\usb 3.0 host controller driver\application\nusb3mon.exe What is the dongle S/N ? |
SN: 21098088 Br |
\program files\renesas electronics\usb 3.0 host controller driver\application\nusb3mon.exe - Disable this process - delete fault.bn file - update dongle firmware with DongleManager now and then run Infinity software. |
dongle error === DongleManager [Infinity] v1.80 [5/22/2020 0:51:34] === Searching... Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 0001232A21344082 Box/Dongle found: Infinity-Box/Dongle Serial No (S/N): F53F232A Firmware version: 0143.02 Box/Dongle misconfiguration Diagnostic code: 70 "UK Edition" status: Off Last launched Application: 0030 v.0143 => Activations: - 00: Infinity-Box/Dongle v0143 => Options:=== DongleManager [Infinity] v1.80 [5/22/2020 0:52:08] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 0001232A21344082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): F53F232A Firmware version: 0143.02 === Process started: 5/22/2020 0:52:09 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 Smart-Card misconfiguration!Contact to support - Infinity-Box/Dongle... |
Please attach here fault.bin file from Infinity CM2MT2 software folder. |
hi i need help for my problem === DongleManager [Infinity] v1.80 [21/05/2020 22:12:20] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Gemalto e-gate Smart Card 0 HWID: 00047889FF021982 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): 485E7889 Firmware version: 0143.02 === Process started: 21/05/2020 22:12:24 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 |
Card-Reader: Gemalto e-gate Smart Card 0 ATR: 3B759400006202020201 Card Manager: A0000000030000 SerialNumber: 00047889 ROM: Integrated Circuit Fabricator: 4090 Integrated Circuit Type: 0062 OS: Identifier: 0011 Release Date: 0202 Release Level: 0100 EEPROM: Fabrication Date: 8032 Serial Number: 00047889 Batch Identifier: FF02 Module Fabricator: 1982 Module Packaging Date: 8032 IC Card Manufacturer: 1983 IC Em******* Date: 8032 Pre Personalizer: 1984 Pre Personalization Date: 8032 Pre Personalization Equipment Identifier: 00030001 Personalizer: FFFF Personalization Date: FFFF Personalization Equipment Identifier: FFFFFFFF m_iopCard.Serial: 00047889FF021982 Extended info: Card returned error message . ISO7816 error 0x6A86 (Wrong parameter(s) P1-P2. Incorrect parameters P1-P2 ) |
