1 Attachment(s) in file of cm2mtk i found fault.bin |
need help in infinity team and help |
There is a software conflict with this application: \program files\avast software\avast\aswidsagent.exe Try to disable it and then run Infinity software again. |
thank you yellowboss for help i disable avast and reset fault.bin and i try they work but i will be delete avast and install other antivirus to be work good |
try To Update Cm2,getting error now no connect I used the latest dongle manger update, tried some processing that error was given, now dongle is not connected nor getting updated Now I am opening Cm2 Mtk Qualcomm B, so smart-card is not active, it is not coming open. https://i.imgur.com/lGYB15Q.png === DongleManager [Infinity] v1.76 [25/04/2020 09:50:37] === Searching... Card-Reader: FT SCR2000 0 HWID: 0108AF7524881292 Select Token Type: instead of Autodetect |
Do you see dongle type selection ? |
Card-Reader: Generic EMV Smartcard Reader 0 HWID: 0000343B12B94082 Box/Dongle found: Infinity-Box/Dongle Serial No (S/N): 85D2343B Firmware version: 0139.02 Box/Dongle misconfiguration Diagnostic code: 57 "UK Edition" status: Off Last launched Application: 0034 v.0100 => Activations: - 00: Infinity-Box/Dongle v.0139 Diagnostic Key: 7F63713C23E2D2ED |
After that update dongle firmware with DongleManager. |
Hi not open cm2 mt2. error downgle firmware version v0136 downgle firmware version is outdated download downgle manager from support and update please help Thank you. |
You can download DongleManager here - https://www.infinity-box.com/support/?s=6 |
Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 000069F01FDB4082 Box/Dongle found: Infinity-Box/Dongle Serial No (S/N): F27869F0 Firmware version: 0143.02 Box/Dongle misconfiguration Diagnostic code: 5A "UK Edition" status: Off Last launched Application: 0030 v.0158 => Activations: - 00: Infinity-Box/Dongle v0143 => Options: - Infinity-Box/Dongle |
To avoid software conflicts in future please do not use "Hexframe" at the same time with Infinity software. What to do now: - Delete fault.bin file from software folder (if you have it there) - Install latest Infinity software updates - Run DongleManager - Update Dongle firmware IMPORTANT: only ONE update try is allowed so in case of problem DO NOT try to update card again ! |
