11-24-2021, 12:32 | #78 (permalink) |
No Life Poster Join Date: Apr 2017 Location: GOLD SINDH
Member: 2705849 Status: Offline Thanks Meter: 664 | Many years have passed since the update of Qualcomm,Think of you and your team at Qualcomm,Or giving Qualcomm updates from another brand in a secret way |
The Following User Says Thank You to Iftakhar Rajper For This Useful Post: |
11-24-2021, 12:39 | #79 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
You not need do anything. MT2 handle all this by UltraFlash. We removed debug info from logs, so, if really something bad happen - sw warn you about. We remove also restriction for memtool in next version. | |
11-24-2021, 12:41 | #80 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Yeah, eltima ones. We will make fix in next release. Solution for now : Code: most probably it trigerring to eusbstub driver subsystem ( eltima, donglify and other similar usb to ethernet drivers ) Try remove named driver from system32, reboot PC and check result. Warning - such method of removing may damage whole usb subsystem, so, first remove such software, after remove and still issue present, possible to remove their left pieces |
11-24-2021, 13:41 | #84 (permalink) | |
Insane Poster Join Date: Oct 2017 Location: Addis Ababa
Member: 2768002 Status: Offline Thanks Meter: 10 | Quote:
smart card not have active module i cant open CM2MT2 v2.28 Serial No (S/N): 2181141D | |
11-24-2021, 13:43 | #85 (permalink) | |
No Life Poster Join Date: Feb 2003 Location: Somewhere
Member: 22466 Status: Offline Thanks Meter: 282 | eltima Quote:
fixed done | |
