10-19-2022, 10:31 | #1 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,001 | Infinity Chinese Miracle-2 CM2MT2 v2.38 Beta Code: !!! WARNING !!! Backup files storage structure changed, files and folders will be compressed. Software will convert files and folders at first run! If you have important data - make /backup/ folder copy for emergency case! Process may takes time, BE PATIENT! - META mode connection method revised - Check free disk space on Flash Read - Flash Read file selection method updated - Flash Read process termination revised - Error messages/hints updated - "SMART RESET EXTRA" error handling revised to recover after error - Check free disk space on startup - Snap to .png instead of .bmp - Device brand|model detection revised - Updates checker rebuilded - "Stop" process revised - MemTool selection mode for 128 Mb and 256 Mb in list - MemTool file selection revised - MemTool operations revised - "Flash" page minor ui changes - "Security" page minor ui changes - "NVRAM Read" operation revised - "NVRAM Write" operation revised - NVRAM backup file format changed - "Restore Backup" operation allow backup file selection - Check free disk space before backup - settings.ini new value [where] backup=backup\ - settings.ini new value [where] boot=boot\ - settings.ini new value [where] tools=..\tools\ - Files verification config option in "Settings" page - Files verification for nvram backup enabled - Memory management engine revised - Minor log text messages and ui changes - Required Dongle firmware version: 0153 https://dl1.infinity-box.com/00/pub/?dir=software/beta/ |
The Following 3 Users Say Thank You to Tanha0321 For This Useful Post: |
10-19-2022, 11:56 | #3 (permalink) |
Freak Poster Join Date: Sep 2011 Location: Sudan
Member: 1648903 Status: Offline Thanks Meter: 161 | === [19-10-2022 09:25:46 C:\InfinityBox\CM2MT2\CM2MT2.exe] === S/N: 0AF77168 v0153 Infinity [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.38 Load IDBase v723487 Ok Backup files: 18 dirs: 0 Check for updates... Installed v2.38 Latest v2.37 Required card v0153 No updates found Update configuration... Configuration [12060] updated Load IDBase v723487 Ok Operation : Reset Settings/Format FS [ v2.38 ] Mode: SMART RESET Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM_V1633 (Android) (COM3) MODE: PRELOADER PORT PORT: 3 Waiting BOOT ack... PRELOADER: ACK confirm FAIL BROM: Init BROM BROM init passed CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] BROM: SecLevel: 0x00000005 BROM: SecMode : SBC+SDA BROM: BROM|BL : 0xFF|0x03 BROM: PRELOADER PORT AGENT: 0_base : BASE_v2112 | Manual : Disabled AGENT: Looking for suitable BootChain in DA... AGENT: [0656ff20] C:\InfinityBox\CM2MT2\boot\0_base\BASE_v2112\MTK_A llInOne_DA.bin AGENT: Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... BROM: Reset Interface PTFN: MediaTek USB Port_V1633 (COM15) MODE: BOOTROM PORT: 15 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init BROM BROM init passed CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] BROM: MEID: 47D7587F8D1F82774F7BA93D84E14FEA BROM: SecLevel: 0x000000E5 BROM: SecMode : SBC+SDA+EXT BROM: BROM|BL : 0x05|0xFE BROM: BOOTROM BROM: SOCID: B2B0411C77111E51CECCC66BF09ED959A024C19A9D59BB28AF 95A74C6A42CDF7 BROM: SLA: Local Auth BROM: SLA: Starting Auth BROM: FF : Look for EMI BROM: FF : EMI found BROM: SLA: Auth Passed BROM: SEC: 0x000000E0 AGENT: 0_base : BASE_v2112 | Manual : Disabled AGENT: Looking for suitable BootChain in DA... AGENT: [0656ff20] C:\InfinityBox\CM2MT2\boot\0_base\BASE_v2112\MTK_A llInOne_DA.bin AGENT: Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... BROM: DA sent BROM: Transfer control to DA... DA: AGENT started DA: SYNC DA: MODE: BROM DA: EXT_RAM NOT initialized EMMC: CID: 150100514436334D42036C4D9BB69623 EMMC: VEN: Samsung : OEM: 0 : ID: 514436334D42 : PRV: 0x03 EMMC: VEN: Samsung : QD63MB EMMC: SNN: 1817025462 ( 0x6C4D9BB6 ) MF: 9/2019 EMI: FireFly preloader_s96116aa1.bin with 3 memory type(s) supported EMI: Init EMI from INTERNAL DB EMI: EXT_RAM CFG Passed DA: BOOT to 2nd DA... DA: 2ND stage confirmed DA: SYNC with DA passed DA: Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID: 150100514436334D42036C4D9BB69623 EMMC: VEN: Samsung : OEM: 0 : ID: 514436334D42 : PRV: 0x03 EMMC: VEN: Samsung : QD63MB EMMC: SNN: 1817025462 ( 0x6C4D9BB6 ) MF: 9/2019 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 21BAB6C44648499890D74A7891284E9 DA: USB: HIGH-SPEED Boot done SmartInfo: AndroidVer: 9 UserDataFS: 0x02 CacheFS: 0x02 Verify device config... Ok No loaders to verify Steps: 6 RESET PROTECTION... Format Ok: RESET PROTECTION USERDATA... Format Ok: USERDATA CACHE... Format Ok: CACHE USERDATA... Format Ok: USERDATA Done: 00:00:52 Reconnect Power/Cable now |
The Following 2 Users Say Thank You to rashidmohamm For This Useful Post: |
10-19-2022, 12:35 | #4 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,968 | I suggest you always make Identify before any other operation due to in this case you will have a backup created automatically. |
The Following 2 Users Say Thank You to YellowBoss For This Useful Post: |
10-19-2022, 18:01 | #5 (permalink) |
No Life Poster Join Date: May 2008
Member: 770503 Status: Offline Thanks Meter: 1,216 | Samsung A10s Frp Code: Operation : Memory Tool Init [ v2.38 ] Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM_V1632 (Android) (COM7) MODE: PRELOADER PORT PORT: 7 Waiting BOOT ack... PRELOADER: ACK confirmed BROM: Init BROM BROM init passed CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] BROM: SecLevel: 0x00000005 BROM: SecMode : SBC+SDA BROM: BROM|BL : 0xFF|0x03 BROM: PRELOADER PORT AGENT: 0_base : BASE_v2112 | Manual : Disabled AGENT: Looking for suitable BootChain in DA... AGENT: [0656ff20] C:\InfinityBox\CM2MT2\boot\0_base\BASE_v2112\MTK_AllInOne_DA.bin AGENT: Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... BROM: Reset Interface PTFN: MediaTek USB Port_V1632 (COM3) MODE: BOOTROM PORT: 3 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init BROM BROM init passed CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] BROM: MEID: A38EA64358E130414EF5FAB70B827217 BROM: SecLevel: 0x000000E5 BROM: SecMode : SBC+SDA+EXT BROM: BROM|BL : 0x05|0xFE BROM: BOOTROM BROM: SOCID: 157CE76EF11C6546D4A51B3601626E5F566158232F23EE1A0A4FC3D4223B40A6 BROM: SLA: Local Auth BROM: SLA: Starting Auth BROM: FF : Look for EMI BROM: FF : EMI found BROM: SLA: Auth Passed BROM: SEC: 0x000000E0 AGENT: 0_base : BASE_v2112 | Manual : Disabled AGENT: Looking for suitable BootChain in DA... AGENT: [0656ff20] C:\InfinityBox\CM2MT2\boot\0_base\BASE_v2112\MTK_AllInOne_DA.bin AGENT: Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... BROM: DA sent BROM: Transfer control to DA... DA: AGENT started DA: SYNC DA: MODE: BROM DA: EXT_RAM NOT initialized EMMC: CID: 150100515836334D42000ACFD40B5777 EMMC: VEN: Samsung : OEM: 0 : ID: 515836334D42 : PRV: 0x00 EMMC: VEN: Samsung : QX63MB EMMC: SNN: 181392395 ( 0x0ACFD40B ) MF: 5/2020 EMI: FireFly preloader_s96116ra1.bin with 8 memory type(s) supported EMI: Init EMI from INTERNAL DB EMI: EXT_RAM CFG Passed DA: BOOT to 2nd DA... DA: 2ND stage confirmed DA: SYNC with DA passed DA: Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID: 150100515836334D42000ACFD40B5777 EMMC: VEN: Samsung : OEM: 0 : ID: 515836334D42 : PRV: 0x00 EMMC: VEN: Samsung : QX63MB EMMC: SNN: 181392395 ( 0x0ACFD40B ) MF: 5/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 1FB5915E8E2681C1D68DA184250E0BD DA: USB: HIGH-SPEED Boot done Verify device config... Ok No loaders to verify MemTool storage: C:\InfinityBox\CM2MT2\phdata\ Make right mouse click to see commands Ready MemoryTool Operation: Erase Memory Wait... Erase selected partitions [1] [0] Erase partition: PERSISTENT Erase partition Ok Operation finished Close MemoryTool session Done: 00:00:58 Reconnect Power/Cable now |
The Following 2 Users Say Thank You to mbiborna For This Useful Post: |
10-19-2022, 18:05 | #6 (permalink) |
Member: 770503 Status: Offline Thanks Meter: 1,216 | WALTON Primo_NF4_2GB Code: Operation : Identify Device [ v2.38 ] Platform: MTK SmartPhone - MT65/67/68/81/83/87 | Helio G/P/X Mode: FLASH [+] SecureData Backup [+] AutoBoot [+] Read Deep Info: PRL, HW, DEBUG [+] FireFly : AutoEMI [+] FireFly : FireFly UNI-Proto [+] Smart Service [-] Local SLA [-] Force BROM Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM_V1632 (Android) (COM7) MODE: PRELOADER PORT PORT: 7 Waiting BOOT ack... PRELOADER: ACK confirmed BROM: Init BROM BROM init passed CHIP: MT6739 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0002 EVOL: 0x0000 HWC: 0x0699 CODE: Zion TYPE: MODERN [RAPHAEL] BROM: SecLevel: 0x00000000 BROM: SecMode : PLAIN BROM: BROM|BL : 0xFF|0x03 BROM: PRELOADER PORT AGENT: 0_base : BASE_v2112 | Manual : Disabled AGENT: Looking for suitable BootChain in DA... AGENT: [0656ff20] C:\InfinityBox\CM2MT2\boot\0_base\BASE_v2112\MTK_AllInOne_DA.bin AGENT: Found MT6739 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... BROM: DA sent BROM: Transfer control to DA... DA: AGENT started DA: SYNC DA: MODE: PRELOADER DA: EXT_RAM initialized DA: BOOT to 2nd DA... DA: 2ND stage confirmed DA: SYNC with DA passed DA: Receiving HW info SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID: 90014A4841473265050752004462765D EMMC: VEN: Hynix : OEM: 74 : ID: 484147326505 : PRV: 0x07 EMMC: VEN: Hynix : HAG2e EMMC: SNN: 1375749218 ( 0x52004462 ) MF: 7/2019 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3AB800000 [ 14.68 GB ] CHIP: MT6739 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0699 CODE: Zion TYPE: MODERN [RAPHAEL] RNID: 567B572EC232B196AA776D8DC89131F2 DA: USB: HIGH-SPEED Boot done Patch Level : PPR1.180610.011 Display ID : Primo_NF4_2GB_20190810_V12 SW Version : 82101 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2019-05-05 Build Time : 10.08.2019 Product Model : Primo_NF4_2GB Product Brand : WALTON Product Name : Primo_NF4_2GB Product Device : Primo_NF4_2GB CPU : armeabi-v7a,armeabi Product Manfct : WALTON Product Info : Primo_NF4_2GB SW : Primo_NF4_2GB-user 9 PPR1.180610.011 82101 release-keys Product Board : WALTON Board Platform : mt6739 USERDATA : FILESYSTEM : EXT4 with FDE ( Full Disk Encryption **) Verify device config... Ok No loaders to verify NVRAM: TK_MD_BASIC_MDBIN_PCB01_MT6739_S00.MOLY_LR12A_R2_MP_V74_15 NVRAM: Items: 0x9E Size: 0x08B6A1 NVRAM: State: Ok INFO : WiFi MAC: AA0036004400 INFO : BlTh MAC: 40DB5B94D556 INFO : IMEI[1]: 353376101413893 INFO : IMEI[2]: 353376101413901 Backup critical data [18] to C:\InfinityBox\CM2MT2\backup\MT6739__567B572EC232B196AA776D8DC89131F2\ [22] Read: NVRAM [8] Read: NVDATA [15] Read: PROINFO [23] Read: LK [7] Read: NVCFG [10] Read: PROTECT1 [1] Read: PGPT [13] Read: PERSIST [0] Read: PRELOADER Done Compact: C:\InfinityBox\CM2MT2\backup\MT6739__567B572EC232B196AA776D8DC89131F2\ Cleanup... Ok Verify nvram C:\InfinityBox\CM2MT2\backup\MT6739__567B572EC232B196AA776D8DC89131F2.zip Stored Ok STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : NOT Enabled! STORAGE : RPMB Status : eMMC : RPMB KEY PROGRAMMED [UNUSABLE] Scan preloader... Preloader: EMI: MT6739 preloader_primo_nf4_2gb.bin with 6 memory type(s) supported EMI[00] : eMMC : DDR3 : ID: 13014E51324A333643 : Ven: Micron | Dev: Q2J36C : RAM: [ 2.00 GB ] EMI[01] : eMMC : DDR3 : ID: 150100514536334D42 : Ven: Samsung | Dev: QE63MB : RAM: [ 2.00 GB ] EMI[02] : eMMC : DDR3 : ID: 150100523832314D42 : Ven: Samsung | Dev: R821MB : RAM: [ 2.00 GB ] EMI[03] : eMMC : DDR3 : ID: 90014A484147346132 : Ven: Hynix | Dev: HAG4a2 : RAM: [ 2.00 GB ] EMI[04] : eMMC : DDR3 : ID: 90014A484147326505 : Ven: Hynix | Dev: HAG2e : RAM: [ 2.00 GB ] EMI[05] : eMMC : DDR3 : ID: 150100524531424D42 : Ven: Samsung | Dev: RE1BMB : RAM: [ 3.00 GB ] Preloader saved to: C:\InfinityBox\CM2MT2\backup\PRELOADER\preloader_primo_nf4_2gb.bin Verify C:\InfinityBox\CM2MT2\backup\PRELOADER\preloader_primo_nf4_2gb.bin [297000dd]... Exist Ok Done Elapsed: 00:02:00 Operation : Read Firmware [ v2.38 ] [+] ExtSparse [-] ForceRead 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM_V1632 (Android) (COM7) MODE: PRELOADER PORT PORT: 7 Waiting BOOT ack... PRELOADER: ACK confirmed BROM: Init BROM BROM init passed CHIP: MT6739 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0002 EVOL: 0x0000 HWC: 0x0699 CODE: Zion TYPE: MODERN [RAPHAEL] BROM: SecLevel: 0x00000000 BROM: SecMode : PLAIN BROM: BROM|BL : 0xFF|0x03 BROM: PRELOADER PORT AGENT: 0_base : BASE_v2112 | Manual : Disabled AGENT: Looking for suitable BootChain in DA... AGENT: [0656ff20] C:\InfinityBox\CM2MT2\boot\0_base\BASE_v2112\MTK_AllInOne_DA.bin AGENT: Found MT6739 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... BROM: DA sent BROM: Transfer control to DA... DA: AGENT started DA: SYNC DA: MODE: PRELOADER DA: EXT_RAM initialized DA: BOOT to 2nd DA... DA: 2ND stage confirmed DA: SYNC with DA passed DA: Receiving HW info SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID: 90014A4841473265050752004462765D EMMC: VEN: Hynix : OEM: 74 : ID: 484147326505 : PRV: 0x07 EMMC: VEN: Hynix : HAG2e EMMC: SNN: 1375749218 ( 0x52004462 ) MF: 7/2019 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3AB800000 [ 14.68 GB ] CHIP: MT6739 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0699 CODE: Zion TYPE: MODERN [RAPHAEL] RNID: 567B572EC232B196AA776D8DC89131F2 DA: USB: HIGH-SPEED Boot done Patch Level : PPR1.180610.011 Display ID : Primo_NF4_2GB_20190810_V12 SW Version : 82101 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2019-05-05 Build Time : 10.08.2019 Product Model : Primo_NF4_2GB Product Brand : WALTON Product Name : Primo_NF4_2GB Product Device : Primo_NF4_2GB CPU : armeabi-v7a,armeabi Product Manfct : WALTON Product Info : Primo_NF4_2GB SW : Primo_NF4_2GB-user 9 PPR1.180610.011 82101 release-keys Product Board : WALTON Board Platform : mt6739 MT6739__WALTON__rimo_NF4_2GB__o_NF4_2GB_20190810_V12__1.180610.011__imo_NF4_2GB Read: preloader.bin Read: recovery.img Read: persist.img ExtSparse: Compression ratio: 75% Read: proinfo.img Read: md1rom.img Read: md1dsp.img Read: spmfw.img Read: mcupmfw.img Read: nvram.bin Read: lk.bin Read: loader_ext.img Read: boot.img Read: logo.bin Read: dtbo.img Read: tz.img Read: vendor.img ExtSparse: Compression ratio: 47% Read: system.img ExtSparse: Compression ratio: 20% Read: cache.img Read: userdata.img FW Size: 2.35 GB Android Info saved: _Android_info.txt Scatter: MT6739_Android_scatter.txt Saved to: C:\Users\mbibo\OneDrive\Desktop\MT6739__WALTON__rimo_NF4_2GB__o_NF4_2GB_20190810_V12__1.180610.011__imo_NF4_2GB\ Verify firmware [MT6739__WALTON__rimo_NF4_2GB__o_NF4_2GB_20190810_V12__1.180610.011__imo_NF4_2GB]... Firmware is unknown Please upload file this way https://infinity-box.com/?r=100020 Verify device config... Ok No loaders to verify Done Elapsed: 00:03:03 Operation : Reset Settings/Format FS [ v2.38 ] Mode: FRP [ RESET PROTECTION ] 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM_V1632 (Android) (COM7) MODE: PRELOADER PORT PORT: 7 Waiting BOOT ack... PRELOADER: ACK confirmed BROM: Init BROM BROM init passed CHIP: MT6739 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0002 EVOL: 0x0000 HWC: 0x0699 CODE: Zion TYPE: MODERN [RAPHAEL] BROM: SecLevel: 0x00000000 BROM: SecMode : PLAIN BROM: BROM|BL : 0xFF|0x03 BROM: PRELOADER PORT AGENT: 0_base : BASE_v2112 | Manual : Disabled AGENT: Looking for suitable BootChain in DA... AGENT: [0656ff20] C:\InfinityBox\CM2MT2\boot\0_base\BASE_v2112\MTK_AllInOne_DA.bin AGENT: Found MT6739 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... BROM: DA sent BROM: Transfer control to DA... DA: AGENT started DA: SYNC DA: MODE: PRELOADER DA: EXT_RAM initialized DA: BOOT to 2nd DA... DA: 2ND stage confirmed DA: SYNC with DA passed DA: Receiving HW info SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID: 90014A4841473265050752004462765D EMMC: VEN: Hynix : OEM: 74 : ID: 484147326505 : PRV: 0x07 EMMC: VEN: Hynix : HAG2e EMMC: SNN: 1375749218 ( 0x52004462 ) MF: 7/2019 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3AB800000 [ 14.68 GB ] CHIP: MT6739 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0699 CODE: Zion TYPE: MODERN [RAPHAEL] RNID: 567B572EC232B196AA776D8DC89131F2 DA: USB: HIGH-SPEED Boot done Verify device config... Ok No loaders to verify Format Ok: RESET PROTECTION Done Elapsed: 00:00:19 Reconnect Power/Cable now Operation : HW Report [ v2.38 ] HW Report Mode: eMMC 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM_V1632 (Android) (COM7) MODE: PRELOADER PORT PORT: 7 Waiting BOOT ack... PRELOADER: ACK confirmed BROM: Init BROM BROM init passed CHIP: MT6739 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0002 EVOL: 0x0000 HWC: 0x0699 CODE: Zion TYPE: MODERN [RAPHAEL] BROM: SecLevel: 0x00000000 BROM: SecMode : PLAIN BROM: BROM|BL : 0xFF|0x03 BROM: PRELOADER PORT AGENT: 0_base : BASE_v2112 | Manual : Disabled AGENT: Looking for suitable BootChain in DA... AGENT: [0656ff20] C:\InfinityBox\CM2MT2\boot\0_base\BASE_v2112\MTK_AllInOne_DA.bin AGENT: Found MT6739 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... BROM: DA sent BROM: Transfer control to DA... DA: AGENT started DA: SYNC DA: MODE: PRELOADER DA: EXT_RAM initialized DA: BOOT to 2nd DA... DA: 2ND stage confirmed DA: SYNC with DA passed DA: Receiving HW info SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID: 90014A4841473265050752004462765D EMMC: VEN: Hynix : OEM: 74 : ID: 484147326505 : PRV: 0x07 EMMC: VEN: Hynix : HAG2e EMMC: SNN: 1375749218 ( 0x52004462 ) MF: 7/2019 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3AB800000 [ 14.68 GB ] CHIP: MT6739 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0699 CODE: Zion TYPE: MODERN [RAPHAEL] RNID: 567B572EC232B196AA776D8DC89131F2 DA: USB: HIGH-SPEED Boot done Memory Info : CID: 90014A4841473265050752004462765D MEM: Ven: Hynix | OEM: 4A01 | Dev: HAG2e EXT_CSD Info: TRIM timeout : 0 ms Secure erase timeout : 6000 ms Secure trim timeout : 6000 ms HC erase unit size : 512 kbytes HC erase timeout : 600 ms HC write prot grp size: 8192 kbytes HC erase grp def. : 0h Sector count : 1d5c000h HS timing : 0h Bus width : 0h Erase memory content : 0h Partition config : 48h Boot partition size : 4096 kbytes Boot information : 7h Boot config protection: 0h Boot bus width : 0h Boot area write prot : 0h User area write prot : 0h RPMB size : 4096 kbytes H/W reset function : 1h FW version(low) : 70h Overall status : STORAGE : Life Status : eMMC : OK! RPMB : RPMB KEY PROGRAMMED [UNUSABLE] STORAGE : OTP Status : NOT Enabled! Done Elapsed: 00:00:33 |
10-20-2022, 00:12 | #7 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,787 | Quote:
if not - auto-make it, or force to do identify first ? that way even #1 noob can't say "cm2 killed my phone" not to mention that for full flash format - this should be a must. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
The Following 3 Users Say Thank You to Brka For This Useful Post: |
10-20-2022, 00:20 | #8 (permalink) | |
Member: 1043909 Status: Offline Thanks Meter: 60,968 | Quote:
Yes, just uploaded beta make backup during Identify and Reset and check is previous backup exist. Making step-by-step | |
10-20-2022, 08:56 | #9 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,428 | Oppo A1k Smart Reset Done V2.38 Operation : Reset Settings/Format FS [ v2.38 ] Mode: SMART RESET [+] Sensitive Data Backup Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device Waiting for device connection... PTFN: MediaTek USB Port_V1632 (COM3) MODE: BOOTROM PORT: 3 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init BROM BROM init passed CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] BROM: MEID: 63FD924825DBDAF1F2A63B59593A40AC BROM: SecLevel: 0x000000E5 BROM: SecMode : SBC+SDA+EXT BROM: BROM|BL : 0x05|0xFE BROM: BOOTROM BROM: SOCID: 20F33ED859636C29AA82DABD87B57EAA868ED78EC6067D522B 6D7B927594BB6E BROM: Sending FireFly FireFly: Starting... FireFly: Init Core FireFly: Core init done FireFly: Running : v05.05.05 on MT6765 FireFly: eMMC init passed EMMC: CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC: CSD: TEMP_WRITE_PROTECT: False EMMC: CSD: PERM_WRITE_PROTECT: False EMMC: CID: 150100514436334D4203DA5307CDB6ED EMMC: VEN: Samsung : OEM: 0 : ID: 514436334D42 : PRV: 0x03 EMMC: VEN: Samsung : QD63MB EMMC: SNN: 3662874573 ( 0xDA5307CD ) MF: 11/2019 EMMC: EXTCSD: rev1.8 ( eMMC 5.1 ) EMMC: EXTCSD [CONFIG] : 0x48 0x02 0x01 EMMC: EXTCSD [PARTITION_CONFIG] : 0x48 EMMC: EXTCSD [BOOT_BUS_WIDTH] : 0x02 EMMC: EXTCSD [RST_N_FUNCTION] : 0x01 EMMC: EXTCSD [PART_S_COMPLETED] : False EMMC: EXTCSD [SIZE] : Market : 32 GB EMMC: EXTCSD [SIZE] : Actual : 0x747C00000 [ 29.12 GB ] EMMC: EXTCSD [EOL] : EOL status : Normal ( Less than 80% reserved blocks used ) EMMC: EXTCSD [EOL_A] : SLC status : 10% - 20% used EMMC: EXTCSD [EOL_B] : MLC status : 10% - 20% used EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] DA: USB: HIGH-SPEED Boot done Reading... SmartInfo: AndroidVer: 9 UserDataFS: 0x02 CacheFS: 0x02 Verify device config... Ok No loaders to verify Backup already exist. Overwrite? No Steps: 6 RESET PROTECTION... Format Ok: RESET PROTECTION USERDATA... Format Ok: USERDATA CACHE... Format Ok: CACHE USERDATA... Format Ok: USERDATA Done: 00:01:06 Reconnect Power/Cable now |
The Following 2 Users Say Thank You to Akhtar Ali Jatt For This Useful Post: |
10-20-2022, 12:13 | #10 (permalink) |
Member: 770503 Status: Offline Thanks Meter: 1,216 | Realme C25s RMX3195 Code: Operation : Identify Device [ v2.38 ] Platform: MTK SmartPhone - MT65/67/68/81/83/87 | Helio G/P/X Mode: FLASH [+] SecureData Backup [+] AutoBoot [+] Read Deep Info: PRL, HW, DEBUG [+] FireFly : AutoEMI [+] FireFly : FireFly UNI-Proto [+] Smart Service [-] Local SLA [-] Force BROM Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device Waiting for device connection... PTFN: MediaTek USB Port_V1632 (COM9) MODE: BOOTROM PORT: 9 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init BROM BROM init passed CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] BROM: MEID: 3C494EF40ACEAC7D1B55151AD446DD13 BROM: SecLevel: 0x000000E5 BROM: SecMode : SBC+SDA+EXT BROM: BROM|BL : 0x05|0xFE BROM: BOOTROM BROM: SOCID: 1B3F03A5B03CB545EEAFA052593091B4C9C8410EA8369DC2096A6BF764B31741 BROM: SLA: Local Auth BROM: SLA: Starting Auth BROM: SLA: Auth Passed BROM: SEC: 0x000000E0 AGENT: 0_base : BASE_v2112 | Manual : Disabled AGENT: Looking for suitable BootChain in DA... AGENT: [0656ff20] C:\InfinityBox\CM2MT2\boot\0_base\BASE_v2112\MTK_AllInOne_DA.bin AGENT: Found MT6768 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... BROM: DA sent BROM: Transfer control to DA... DA: AGENT started DA: SYNC DA: MODE: BROM DA: EXT_RAM NOT initialized EMMC: CID: 150100445636444142028268CAC4A815 EMMC: VEN: Samsung : OEM: 0 : ID: 445636444142 : PRV: 0x02 EMMC: VEN: Samsung : DV6DAB EMMC: SNN: 2187905732 ( 0x8268CAC4 ) MF: 10/2021 EMI: FireFly preloader_k69v1_64.bin with 20 memory type(s) supported EMI: Init EMI from INTERNAL DB EMI: EXT_RAM CFG Passed DA: BOOT to 2nd DA... DA: 2ND stage confirmed DA: SYNC with DA passed DA: Receiving HW info SRAM: 0x00070000 [ 448.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID: 150100445636444142028268CAC4A815 EMMC: VEN: Samsung : OEM: 0 : ID: 445636444142 : PRV: 0x02 EMMC: VEN: Samsung : DV6DAB EMMC: SNN: 2187905732 ( 0x8268CAC4 ) MF: 10/2021 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x1D1EC00000 [ 116.48 GB ] CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] RNID: AB5270A8B8B4A37EB76915EBA9388179 DA: USB: HIGH-SPEED Boot done USERDATA : ENCRYPTED NVRAM: k69v1_64_2167A_MDBIN_PCB01_MT6768_S00.MOLY_LR12A_R2_TC16_PR11_SP_V2_P5 NVRAM: Items: 0xAA Size: 0x08CA0E NVRAM: State: Ok INFO : WiFi MAC: AA0036004400 INFO : BlTh MAC: 0C90435E7A88 Verify device config... Ok No loaders to verify Backup critical data [18] to C:\InfinityBox\CM2MT2\backup\MT6768__3C494EF40ACEAC7D1B55151AD446DD13\ [25] Read: NVRAM [17] Read: NVDATA [23] Read: PROINFO [37] Read: LK [16] Read: NVCFG [19] Read: PROTECT1 [1] Read: PGPT [18] Read: PERSIST [0] Read: PRELOADER [7] Read: OPPORESERVE3 [8] Read: OPPO_CUSTOM Done Compact: C:\InfinityBox\CM2MT2\backup\MT6768__3C494EF40ACEAC7D1B55151AD446DD13\ Cleanup... Ok: 11 Verify C:\InfinityBox\CM2MT2\backup\MT6768__3C494EF40ACEAC7D1B55151AD446DD13.zip Verified Ok STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! STORAGE : RPMB Status : eMMC : RPMB KEY PROGRAMMED [UNUSABLE] Scan preloader... Preloader: EMI: MT6752 preloader_k69v1_64.bin with 20 memory type(s) supported EMI[00] : eMMC : LP_DDR4X : ID: 150100445636444D42 : Ven: Samsung | Dev: DV6DMB : RAM: [ 4.00 GB ] EMI[01] : eMMC : LP_DDR4X : ID: 13014E53304A394B39 : Ven: Micron | Dev: S0J9K9 : RAM: [ 4.00 GB ] EMI[02] : eMMC : LP_DDR4X : ID: 150100444436384D42 : Ven: Samsung | Dev: DD68MB : RAM: [ 3.00 GB ] EMI[03] : eMMC : LP_DDR4X : ID: 150100444836444142 : Ven: Samsung | Dev: DH6DAB : RAM: [ 4.00 GB ] EMI[04] : eMMC : LP_DDR4X : ID: 90014A68433861503E : Ven: Hynix | Dev: hC8aP> : RAM: [ 3.00 GB ] EMI[05] : eMMC : LP_DDR4X : ID: 90014A684339615033 : Ven: Hynix | Dev: hC9aP3 : RAM: [ 4.00 GB ] EMI[06] : eMMC : LP_DDR4X : ID: 150100445036384D42 : Ven: Samsung | Dev: DP68MB : RAM: [ 3.00 GB ] EMI[07] : eMMC : LP_DDR4X : ID: 90014A68423861503E : Ven: Hynix | Dev: hB8aP> : RAM: [ 3.00 GB ] EMI[08] : eMMC : LP_DDR4X : ID: 1501003458364B4D42 : Ven: Samsung | Dev: 4X6KMB : RAM: [ 2.00 GB ] EMI[09] : eMMC : LP_DDR4X : ID: 450100444134313238 : Ven: Sandisk | Dev: DA4128 : RAM: [ 4.00 GB ] EMI[0A] : eMMC : LP_DDR4X : ID: 90014A68423861503E : Ven: Hynix | Dev: hB8aP> : RAM: [ 2.00 GB ] EMI[0B] : eMMC : LP_DDR4X : ID: 150100334836434142 : Ven: Samsung | Dev: 3H6CAB : RAM: [ 6.00 GB ] EMI[0C] : eMMC : LP_DDR4X : ID: 90014A68433861503E : Ven: Hynix | Dev: hC8aP> : RAM: [ 6.00 GB ] EMI[0D] : eMMC : LP_DDR4X : ID: 13014E47314A395238 : Ven: Micron | Dev: G1J9R8 : RAM: [ 4.00 GB ] EMI[0E] : eMMC : LP_DDR4X : ID: 13014E47314A395339 : Ven: Micron | Dev: G1J9S9 : RAM: [ 4.00 GB ] EMI[0F] : eMMC : LP_DDR4X : ID: 150100445836384D42 : Ven: Samsung | Dev: DX68MB : RAM: [ 3.00 GB ] EMI[10] : eMMC : LP_DDR4X : ID: 150100445036444142 : Ven: Samsung | Dev: DP6DAB : RAM: [ 4.00 GB ] EMI[11] : eMMC : LP_DDR4X : ID: 150100445636444142 : Ven: Samsung | Dev: DV6DAB : RAM: [ 4.00 GB ] EMI[12] : eMMC : LP_DDR4X : ID: 150100445636444242 : Ven: Samsung | Dev: DV6DBB : RAM: [ 4.00 GB ] EMI[13] : eMMC : LP_DDR4X : ID: 150100445036444242 : Ven: Samsung | Dev: DP6DBB : RAM: [ 4.00 GB ] Preloader exist: C:\InfinityBox\CM2MT2\backup\PRELOADER\preloader_k69v1_64.bin Verify C:\InfinityBox\CM2MT2\backup\PRELOADER\preloader_k69v1_64.bin [58d3950f]... Exist Ok Done: 00:01:37 Operation : Reset Settings/Format FS [ v2.38 ] Mode: FRP [ RESET PROTECTION ] Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device Waiting for device connection... PTFN: MediaTek USB Port_V1632 (COM9) MODE: BOOTROM PORT: 9 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init BROM BROM init passed CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] BROM: MEID: 3C494EF40ACEAC7D1B55151AD446DD13 BROM: SecLevel: 0x000000E5 BROM: SecMode : SBC+SDA+EXT BROM: BROM|BL : 0x05|0xFE BROM: BOOTROM BROM: SOCID: 1B3F03A5B03CB545EEAFA052593091B4C9C8410EA8369DC2096A6BF764B31741 BROM: SLA: Local Auth BROM: SLA: Starting Auth BROM: SLA: Auth Passed BROM: SEC: 0x000000E0 AGENT: 0_base : BASE_v2112 | Manual : Disabled AGENT: Looking for suitable BootChain in DA... AGENT: [0656ff20] C:\InfinityBox\CM2MT2\boot\0_base\BASE_v2112\MTK_AllInOne_DA.bin AGENT: Found MT6768 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... BROM: DA sent BROM: Transfer control to DA... DA: AGENT started DA: SYNC DA: MODE: BROM DA: EXT_RAM NOT initialized EMMC: CID: 150100445636444142028268CAC4A815 EMMC: VEN: Samsung : OEM: 0 : ID: 445636444142 : PRV: 0x02 EMMC: VEN: Samsung : DV6DAB EMMC: SNN: 2187905732 ( 0x8268CAC4 ) MF: 10/2021 EMI: FireFly preloader_k69v1_64.bin with 20 memory type(s) supported EMI: Init EMI from INTERNAL DB EMI: EXT_RAM CFG Passed DA: BOOT to 2nd DA... DA: 2ND stage confirmed DA: SYNC with DA passed DA: Receiving HW info SRAM: 0x00070000 [ 448.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID: 150100445636444142028268CAC4A815 EMMC: VEN: Samsung : OEM: 0 : ID: 445636444142 : PRV: 0x02 EMMC: VEN: Samsung : DV6DAB EMMC: SNN: 2187905732 ( 0x8268CAC4 ) MF: 10/2021 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x1D1EC00000 [ 116.48 GB ] CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] RNID: AB5270A8B8B4A37EB76915EBA9388179 DA: USB: HIGH-SPEED Boot done Verify device config... Ok No loaders to verify Steps: 1 RESET PROTECTION... Format Ok: RESET PROTECTION Done: 00:00:22 Reconnect Power/Cable now |
10-20-2022, 16:13 | #11 (permalink) |
Member: 770503 Status: Offline Thanks Meter: 1,216 | Oppo A83 Code: Operation : Reset Settings/Format FS [ v2.38 ] Mode: SMART RESET Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device Waiting for device connection... PTFN: MediaTek USB Port_V1632 (COM9) MODE: BOOTROM PORT: 9 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init BROM BROM init passed CHIP: MT6763 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x0690 CODE: Bianco TYPE: MODERN [RAPHAEL] BROM: MEID: C1CFBAB11BE7D5A2AD0DB89B269316F7 BROM: SecLevel: 0x000000E5 BROM: SecMode : SBC+SDA+EXT BROM: BROM|BL : 0x05|0xFE BROM: BOOTROM BROM: SOCID: F0ADADAAAA95B9B6FA7D44E988ACBEC68D5F218FBFB3C9867AE0DF7DAADDDA61 BROM: SLA: Local Auth BROM: SLA: Starting Auth BROM: SLA: Auth Passed BROM: SEC: 0x000000E0 AGENT: 0_base : BASE_v2112 | Manual : Disabled AGENT: Looking for suitable BootChain in DA... AGENT: [0656ff20] C:\InfinityBox\CM2MT2\boot\0_base\BASE_v2112\MTK_AllInOne_DA.bin AGENT: Found MT6763 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... BROM: DA sent BROM: Transfer control to DA... DA: AGENT started DA: SYNC DA: MODE: BROM DA: EXT_RAM NOT initialized EMMC: CID: 150100514536334D4203AB8CD21C35A1 EMMC: VEN: Samsung : OEM: 0 : ID: 514536334D42 : PRV: 0x03 EMMC: VEN: Samsung : QE63MB EMMC: SNN: 2878132764 ( 0xAB8CD21C ) MF: 3/2018 EMI: INFINITY PRELOADER_INFINITY_0 with 1 memory type(s) supported EMI: Init EMI from INTERNAL DB EMI: EXT_RAM CFG Passed DA: BOOT to 2nd DA... DA: 2ND stage confirmed DA: SYNC with DA passed DA: Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID: 150100514536334D4203AB8CD21C35A1 EMMC: VEN: Samsung : OEM: 0 : ID: 514536334D42 : PRV: 0x03 EMMC: VEN: Samsung : QE63MB EMMC: SNN: 2878132764 ( 0xAB8CD21C ) MF: 3/2018 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A3E00000 [ 14.56 GB ] CHIP: MT6763 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0690 CODE: Bianco TYPE: MODERN [RAPHAEL] RNID: 2AEF87A1D82FBF414F492BA4D4EA2895 DA: USB: HIGH-SPEED Boot done SmartInfo: AndroidVer: 7 UserDataFS: 0x01 CacheFS: 0x01 Verify device config... Ok No loaders to verify Steps: 6 RESET PROTECTION... Format Ok: RESET PROTECTION USERDATA... Format Ok: USERDATA CACHE... Format Ok: CACHE USERDATA... Format Ok: USERDATA Done: 00:00:50 Reconnect Power/Cable now |
The Following User Says Thank You to mbiborna For This Useful Post: |
10-20-2022, 19:04 | #12 (permalink) | |
10-21-2022, 19:17 | #14 (permalink) | |
Anyway updated "2.38h" version was uploaded short time ago, try it | |
10-22-2022, 06:49 | #15 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,428 | Jaz Digit 4G Music Smart Reset Done With 2.38H Beta Operation: Reset Settings/Format FS [ v2.38 ] Platform: MTK SmartPhone - MT65/67/68/81/83/87 | Helio G/P/X Mode: SMART RESET [+] Sensitive Data Backup Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device Waiting for device connection... PTFN: MediaTek USB Port_V1632 (COM3) MODE: BOOTROM PORT: 3 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init BROM BROM init passed CHIP: MT6739 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0002 EVOL: 0x0000 HWC: 0x0699 CODE: Zion TYPE: MODERN [RAPHAEL] BROM: MEID: F9D66CC3FA98D23D64D80CAA0B022DAB BROM: SecLevel: 0x00000000 BROM: SecMode : PLAIN BROM: BROM|BL : 0x05|0xFE BROM: BOOTROM BROM: SOCID: 89A8BA78BB12B13D9EE6C32AE189D1B6C5E7479F7590153100 05B6ECDB68A81B BROM: EMI: Search BROM: EMI: Found AGENT: 0_base : BASE_v2112 | Manual : Disabled AGENT: Looking for suitable BootChain in DA... AGENT: [0656ff20] C:\InfinityBox\CM2MT2\boot\0_base\BASE_v2112\MTK_A llInOne_DA.bin AGENT: Found MT6739 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... BROM: DA sent BROM: Transfer control to DA... DA: AGENT started DA: SYNC DA: MODE: BROM DA: EXT_RAM NOT initialized EMI: FireFly preloader_fise6731_kaio_m.bin with 6 memory type(s) supported EMI: Init EMI from INTERNAL DB EMI: EXT_RAM CFG Passed DA: BOOT to 2nd DA... DA: 2ND stage confirmed DA: SYNC with DA passed DA: Receiving HW info SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x20000000 [ 512.00 MB ] EMMC: CID: 90014A48344732611102250011C492FD EMMC: VEN: Hynix : OEM: 74 : ID: 483447326111 : PRV: 0x02 EMMC: VEN: Hynix : H4G2a EMMC: SNN: 620761540 ( 0x250011C4 ) MF: 9/2015 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0xE9000000 [ 3.64 GB ] CHIP: MT6739 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x0699 CODE: Zion TYPE: MODERN [RAPHAEL] RNID: ACBC89C395E4897130B880E8D59E890A DA: USB: HIGH-SPEED Boot done (1) Reading... SmartInfo: AndroidVer: 6 UserDataFS: 0x01 CacheFS: 0x01 Verify device config... Ok Backup sensitive data [18] to C:\InfinityBox\CM2MT2\backup\MT6739__F9D66CC3FA98D 23D64D80CAA0B022DAB\ [21] Read: NVRAM [8] Read: NVDATA [14] Read: PROINFO [22] Read: LK [7] Read: NVCFG [10] Read: PROTECT1 [1] Read: PGPT [0] Read: PRELOADER Done Compact: C:\InfinityBox\CM2MT2\backup\MT6739__F9D66CC3FA98D 23D64D80CAA0B022DAB\ Cleanup... Ok: 9 Verify C:\InfinityBox\CM2MT2\backup\MT6739__F9D66CC3FA98D 23D64D80CAA0B022DAB.zip Verified Ok Steps: 6 RESET PROTECTION... Format Ok: RESET PROTECTION USERDATA... Format Ok: USERDATA CACHE... Format Ok: CACHE USERDATA... Format Ok: USERDATA Done: 00:01:12 Reconnect Power/Cable now |
The Following User Says Thank You to Akhtar Ali Jatt For This Useful Post: |
